[ Total Views: 1383 | Total Replies: 11 | Thread Id: 86737 ]
Author: Subject:  62 kg wiring loom
Membergrogy
Threads: 344
posted on October 23rd, 2010 at 09:33 PM
62 kg wiring loom
hi, i want to replace my 62 ghia wiring loom. i have a new loom from usa [lhd] i still have the old loom in the car. who has done it, how did u do it. any hints pictures anything or problems encountered will help. thanks greg
MemberL469
Threads: 15
posted on October 24th, 2010 at 05:08 PM
:lol: thats a heavy wiring loom 62 kg
Membergrogy
Threads: 344
posted on October 24th, 2010 at 06:15 PM
ah jus when i thought nonone knew hahah
Memberisky
Threads: 40
Mood: awesome....
posted on October 24th, 2010 at 08:54 PM
wow i didn't even know there was a left and right hand drive wiring loom...:spin:
my Karman looks worse than my avatar....seriously!
...but i love it more than words can say
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1998 Transporter LWB
1992 Nissan Maxima
http://www.iskyC96.com  (awesome corsets ;))
http://www.moonstarmagic.com
Membergrogy
Threads: 344
posted on October 24th, 2010 at 10:35 PM
hahaha u guys r funni,............... so who has done it. who has pulled another wiring loom thru the small hole up inside the bonnet compartment into behind the rear side trim n thru the hole there out under the back of the car. i was thinkin of tying the old loom to the new one n try to pull it thru. but i dont want to start without hearing if anyone has tried n it got stuck. the loom i have is in 4 sections and seems too big to fit and it says to do it in its 4 diff parts ex part a part b part c part d
posted on October 25th, 2010 at 07:31 AM
you may have to lengthen some of the wires to make the loom fit
Super ModeratorYogie
Threads: 108
posted on October 25th, 2010 at 07:55 AM
I have done it on a beetle. I threaded the biggest one through first and then just threaded the smaller ones through after that. The front was the hardest as the hole at the back was larger. It prpbably doesn't hurt to put some talcum powder on the rubber grommet as well to help them slide through.
Yogie
Membervwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on October 25th, 2010 at 11:18 AM
i would personally tie the old wiring loom to some fairly thick steel wire(fencing or so, something which flexes easy enough) pull the old through and then tie the new to the wire and pull through, rub a bit or grease or something on to help it
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
Membergrogy
Threads: 344
posted on October 26th, 2010 at 06:23 AM
thanks for the replies. the kit is made by american autowire and sold by watson streetworks, very nice setup. i found the fuse box and rest of the stuff, read the instructions about 10times. hopefully the old loom will come out easily and their be enuff room for the new one. vw must have never thought the old would ever be replaced when u look at where the kg exits from behind the dash.the lhd cars ran down from the drivers side and across the rear, so hopefully it will be long enuff since rhd is all on same side of the car [fuseboxfront/starter rear same side.but is is for abug, i might have to lengthen as dave said hope not.
Membersputnick60
Threads: 2
posted on October 28th, 2010 at 09:21 PM
Wrong,
Up to August 1965 the wiring loom was run in the sills on the right hand side. In a tube actually. After August 1965 the wiring loom ran down the left side of the car but inside under the kick plate on top of the sill. RHD and LHD cars weren't different except for the part under the dash.
So for a '62 the wires for a LHD car would extend across the car. So if you had to use a loom for a RHD car you would need to SHORTEN the loom under the dash to make it work. If were the case for a '66 model, then you'd have to lengthen it. I've got a '66. I've that problem.
When you pull out the loom have a trace wire pull through with it. You can use that race wire to drag in the new loom.
There is a mob in Melbourne who claim they make a 62 loom for about $500 for RHD Ghias.
Good luck
Nicholas
Membergrogy
Threads: 344
posted on October 28th, 2010 at 10:30 PM
the drivers side of a lhd is the left side, if u look at the pics on jbugs site u can see the 56-73 is on the drivers side of a lhd car.
Membersputnick60
Threads: 2
posted on October 31st, 2010 at 12:02 PM
Yeah I had a look at Jbugs and I see what you say. Still I think the picture is wrong. The fact remains, no matter where the steering wheel is, 56-65 loom runs on the RHS, 66 to 74 loom runs on the LHS .
This is a picture of a Passenger side Sill from a RHD '65. That tube is the one I mentioned earlier on the LHS of a RHD car.
http://images.thesamba.com/vw/gallery/pix/157649.jpg
Here's a photo of a RHD 1960. you can see the loom coming past the glovebox and under the radio where it is held by a steel band to the underdash. Where the sheath ends you can see the thick red wire to the light switch. (right next to the radio). The other end of that connection is on the battery + (or regulator output) Clearly this shows it running down the RHS of the car and shows why I think the Jbugs drawing is wrong.
http://images.thesamba.com/vw/gallery/pix/523468.jpg
You are in the lucky position of having a pre 66 RHD car and you can get by with the LHD loom. You only will need to shorten the lengths under the dash. That's much better than having to splice stuff on.
Nicholas
[ Queries: 40 ] [ PHP: 15.0% - SQL: 85.0% ]
