| [ Total Views: 5372 | Total Replies: 22 | Thread Id: 88766 ] |
Redbackemu
| posted on February 15th, 2011 at 08:57 PM |
counrty buggy suspension on baja
Is it a good option to put country buggy suspension on a Baja. What are the good & bad points?
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
| posted on February 15th, 2011 at 10:54 PM |
The front spindles are great, they give you almost 3" lift over standard with no change to suspension geometry or stiffness.
Using the CB swingaxle reduction box transaxle will give you lift at the rear, and far lower gear ratios. This means better crawling, but, depending
on your tyre size you might not see much more than 100km/h flat out.
You will also have problems with the rear end tramping running the reduction boxes. And the back of the car will lift under acceleration instead of
squatting like a normal car.
This can be a good and a bad thing while offroading, depends what situation you're in.
I have a set of CB spindles to put on the front of my buggy.
If you have the time/skills/money I would recommend converting the rear end to CVs and running the spindles on the front. The swingaxle with redux
boxes, in my opinion, is not worth the hassles if you can afford to go to IRS.
Smiley
Redbackemu
| posted on February 16th, 2011 at 06:20 AM |
Thanks I don't know much about suspension are the front spidles you are refering to the whole suspension for the front or only a certain part? What
is country buggy suspension worth ? Irs sounds good, how do you get the extra lift with them? What is the cost of this? I would have a go at
installing it myself.
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 16th, 2011 at 12:16 PM |
posted by Redbackemu
Just the spindles, from the trailing arms out. I have heard that the link pins might need to be a different diameter, so that would be something to
look into as well.
This is a CB spindle.
They only fit onto King and Link Pin front end vehicles, so if you have balljoint you have to get something else. What year model is your car? And do
you know if it's balljoint or King and Linkpin?
Country buggy spindles are rare and very expensive. of the 1900 cars built only 800 odd were sold in Australia. Spindles normally sell from a minimum
of $500 to well over a $1000 and often need a full rebuild. Good luck finding them if you don't have a set already.
"IRS" is a term used to describe the later model double jointed rear suspension. In reality swing axle is also an IRS suspension. But one is called
swingaxle and one IRS to avoid confusion.
IRS suspension is very easy to lift, you just need to adjust the rear torsion bars a few splines until you get it sitting how you want it. Don't go
with to much lift or you will ruin your down travel. IRS suspension doesn't really give you any more lift than the swingaxle suspension, it just does
so in a much safer and better handling manner.
When lifted a swingaxle gets lots of positive camber at the tyres. This causes the car to be very twitchy to drive, and sometimes quite dangerous.
Converting to IRS is a very involved process. First of all you are going to need all the parts to make it happen. The gearbox, axles/cvs, diagonal
trailing arms, spring plates, torsion bars etc etc.
Then you will need to weld pivot boxes onto the rear torsion housing in the right place. You will need a jig for this, and I'm not sure if it
requires the body to be removed from the floorpan. Having it off would make the job a lot easier.
The shock towers also need to be modified to allow for full travel of the suspension.
Pivot boxes can be bought from the likes of CVD
http://www.customveedub.com.au/store/index.php?act=viewProd&productId=22
They can also do the entire conversion for you
http://www.customveedub.com.au/store/index.php?act=viewProd&productId=23
Now I have a few questions for you.
Firstly, could you update your profile information so we know where you are located? It's no use me recommending CVD if you are in Perth.
Can you post up some pictures of your Baja?
What suspension etc is it currently running?
What year model is it?
What do you intend to use it for?
Where would you like it to be and what are you aiming for?
I hope my rambling has at least displaced some information.
Smiley
PS - The above picture of the spindle was taken from Nils' build here
http://www.shoptalkforums.com/viewtopic.php?f=28&t=126314
His Baja goes through a gradual evolution, he starts of with stock swingaxle/linkpin, goes to reduction box CB suspension, then up to IRS at the rear.
The build is well documented and very informative. In my opinion easily one of the best Bajas in Australia. Might be a good read for you.
Redbackemu
| posted on February 16th, 2011 at 05:29 PM |
Read Nils'build what an excellent job he has done, would love something like that but my skills aren't that good. I have updated my profile, in the
process of buying 58 baja, not signed & sealed yet, currently has stock suspension, option of counrty buggy front & rear suspension, hence my
inquiry. It seems the cb suspension limits the road speed a lot and gives better low down grunt in the heavy stuff, is this right ? I would like to
drive it on roads legally, say 50/50 off road - on road. Keen to do work on it myself, but the irs converion does seem to be a big job
vwjon
Threads: 101
Mood: oily n thirsty
| posted on February 16th, 2011 at 05:59 PM |
i think it would be better to use 181 vw thing/ trekker parts, get them here or in europe. ball joint as well!
3 1959 cadillacs
1 musso
2 early notchbacks
2 split kombis
2 split panels
1 split ute
1 low light panel
1 ex-pmg bay
1 country buggy
1 beetle ute
1 14" syncro caravelle
1 16" syncro doka
1 golf cabrio
1 vw camper trailer
2 3meter bombs
Redbackemu
| posted on February 16th, 2011 at 07:31 PM |
Is there much difference between country buggy & 181 thing suspension and price?
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 16th, 2011 at 07:50 PM |
posted by vwjon
This really isn't an option because the car is a king and link pin, and that would require a framehead swap. If you aren't confident doing an IRS
conversion I wouldn't recommend attempting a framehead switch.
Unless you bought a later model car that is balljoint that's really out of the question.
I'm not sure on the prices on the Thing Spindles. They aren't as dear as the CB ones but still aren't very cheap. Plus you have to import them from
America.
Probably buy your car to begin with, then you can start deciding on what you want to do with it/what needs upgrading.
Smiley
Redbackemu
| posted on February 16th, 2011 at 08:40 PM |
The bloke is looking for $900 each for front & rear cb suspension, which adds a lot to the car price
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 16th, 2011 at 08:44 PM |
Personally I wouldn't bother spending that much on the reduction box setup. If you can afford it buy the spindles.
Smiley
matberry
| posted on February 16th, 2011 at 09:58 PM |
Good advice Smiley
If you put CB spindles in the front but leave the rear swing, I think the car will have a very nose up attitude and will have trouble getting the back
up enough.
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 16th, 2011 at 10:11 PM |
posted by matberry
Good advice Smiley
up enough.
This also depends on your tyres sizes.
If you have 31"s on the back and the front at stock height with the spindles I don't think the front would be a great deal higher than the rear, but
it all depends entirely on the height of your front wheels. And you could always tweak the back an extra inch or so to get them even.
Smiley
Redbackemu
| posted on February 17th, 2011 at 06:16 AM |
Would that give enough clearance, how does it effect things if you have higher tires on the back than the front to get a better look/ride
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 17th, 2011 at 10:11 AM |
Depends what you're using it for. As you said you only want to use it maybe half on road half offroad.
I currently have 31" on the back and roughly 25" tall wheels on the front of my Baja. My front end has adjusters that are screwed up about an inch
or two. My car does have a little nose down attitude, so far I haven't had any handling problems etc. But if you have to much rake on the car it
starts to throw out the front end castor, which can effect your handling
I'd say if you leave your front end stock except for the spindles. Raise your rear end an inch or so. Run 30-31" tall tyres on the rear, and 26-28"
tall ones on the front. You should have a fairly level vehicle that will be quite capable offroad.
You will be pleasantly surprised by how well these little rigs perform offroad. My Baja is very basic, swingaxle rear, front height has a very small
lift, small wheels up front and 31"s on the rear, 1300 single port engine. And I still manage to mess around on some pretty gnarly tracks and climb
some big hills.
And even with my low front end (by offroad VW standards) I still have more clearance than a 4WD running 31" tyres. So if I go out with some friends
that have 4WDs I have sometimes found that I have more clearance than they do and don't have to straddle ruts/avoid rocks as much.
Smiley
PHAT BUG
Dave says Bini's a fool
Threads: 192
Mood: Drippin
| posted on February 17th, 2011 at 03:49 PM |
In my opinion the reduction box's are the best improvement I've made to my Baja,
Before hand with the 31's, it had no low down grunt out bush and struggled at 100kph in 4th. The improved ground clearance and lower gearing is
awesome on and off road, now it'll happily sit on 70mph and accelarates up hills.
I have a cut and turned front which matches the rear height nicely, sure spindles would be nice, but I'd hardly reccomend buying them over the rear
end, the front is easy to get up high,
you need clearance at the rear (under engine) and the only way on a swing axle is to use redux, otherwise you'll end up with a stupid amount of
positive camber trying to achieve it.
But the biggest advantage in my opinion would be the gearing, It's great now, I can't believe how much better it is to drive.
Before.....
After........
Redbackemu
| posted on February 17th, 2011 at 06:50 PM |
Smiley what year is your Baja ? do you have any photos you could post?
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 17th, 2011 at 10:26 PM |
It's a 1965 on a 1972 superbug pan that's been converted to King and Link Pin.
My build diary is here if you want to have a long read. Of course it's still a work in progress like all VWs
http://forums.aussieveedubbers.com/viewtopic.php?tid=80275&page=1
And here's some pictures of the last 9 months since I finished her.
I just realised that's a lot of pictures.
Enjoy.
Smiley
ancientbugger
Threads: 191
| posted on February 18th, 2011 at 10:21 AM |
Loved 'em!
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
| posted on February 18th, 2011 at 08:10 PM |
You obviously give the baja a fun and adventurous life smiley!
How do you attach so many photos in one post. I can only attach 3 at a time.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
Redbackemu
| posted on February 19th, 2011 at 02:44 PM |
Great info looks like you have done a power of work Smiley, have you kept a record of your costs not including labour? DO you know how many hours you
spent on it? What would it be worth now ?
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 19th, 2011 at 03:25 PM |
posted by baghall
And it's only 9 months old!! Poor thing, I've been taking it easy the last month or so because the engine is very much on the way out. And I need it
to last until I build a replacement.
Pictures are done using a Photobucket account.
You get the link for the picture and put [img] [/img] either side of it.
So it looks like something like [img]link[/img] Then that puts the picture in for you. Can put as many as you want.
I have a big pile of receipts sitting all over the top of my desk, haven't really been bothered to add it all up.
DO you know how many hours you spent on it?
I honestly have no idea. In the last 3 weeks when I was putting it together before rego I spent probably 6-10 hours on it every afternoon after work
plus every waking second of the weekend. I did have a heap of help prepping it for paint from a friend.
But there are a lot of hours in it, all the small jobs add up and take 3 times as long as you expect. When I do my buggy build I might try and keep
track of the hours I do on it.
I don't how many it would be worth, when I first finished the car I probably could have insured it for maybe $10000 tops. It's probably a bit less
than that now because she's a bit knocked around and paint is scratched/chipped, fibreglass has cracked, engine is rooted etc.
But honestly the car is priceless to me, it has given me so many great memories and I've only had it nine months! Those pictures are just a small
number out of the thousands I have. I've met some great people and had fantastic experiences along the way, all thanks to this car, I wouldn't trade
it for anything in the world.
Smiley
Redbackemu
| posted on February 21st, 2011 at 08:03 PM |
Just been reading slowly thru your log, just blows me away the work you have done, great insperation, where did you get all the info on the work you
have done from ? I think I will invest in a new welder after seeing all your welds, I only have an old hand me down stick welder from my father, what
sort of welder did you use ?
Smiley
Threads: 110
Mood: Synchro'd
| posted on February 21st, 2011 at 10:34 PM |
Aww shucks. Thanks man.
The info on the work I have done? I had a lot of help from the people on here. Ask as question in the tech section and you get lots of answers. I also
had a lot of help from Andrew Westwood while he was in Yeppoon, especially with the framehead swap. The rest I just winged it.
The welder I have is is a 175 WIA Mig. It wasn't cheap but worth every cent when I use it.
Smiley
