[ Total Views: 644 | Total Replies: 8 | Thread Id: 91212 ]
Author: Subject:  Spark plug leads?
Membersmithy68
posted on June 23rd, 2011 at 09:06 PM
Spark plug leads?
I have ordered a SVDA dizzy with electric points from Aircooled.net and want to know, should I buy the standard Bosch wires or get some other wires?
What do people recommend?
The motor is a stock rebuilt 1300cc S/P.
posted on June 23rd, 2011 at 10:01 PM
use the stock leeds
info.gif posted on June 23rd, 2011 at 11:14 PM
You can buy the original type of leads which are quite inexpensive from all the VW shops.
These are the wire type that use the resistor plug on the end of the wires that go to the plugs..
these are what was on the beetle engines originally...
You can of course buy any type of leads that fit Your beetle
the silcone leads that are available in different colors can break [inside] very easily , and do break down due to heat..
Membersander288
"Bolt-on Master"
Threads: 183
posted on June 24th, 2011 at 03:52 PM
Originally posted by vw54
use the stock leeds
Just use the stock leads, HT leads etc havn't been shown to produce much difference anyway the stock ones are best because they have the right rubber around the tinware etc...
I got some Beru ones from boris at vintage I've used el-cheapo blue ones, top gun leads (from Repco) and the stock ones are by far the best
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersmithy68
posted on June 24th, 2011 at 07:54 PM
cheers guys, stock leads it is :)
info.gif posted on June 24th, 2011 at 10:14 PM
use the stock leeds
Just use the stock leads, HT leads etc haevn't been shown to produce much difference anyway the stock ones are best because they have the right rubber around the tinware etc...
The original leads have copper wire with no resistance at all
and the other types [silicone] have some resistance but not enough to hurt the spark ... everything being equal ..
I bought some Eagle ones on ebay NOS and they have excellent air seals on them...
I would like a set of spiral ones that are too expensive for Me
lol
also to stop Radio interference [VHF radio]...
PS: the VW-Bosch rotor button has a resistor built into it ,
also it can burn out , so a spare is good to carry...
Memberstagvee40
Threads: 14
posted on June 28th, 2011 at 10:48 AM
Dont be fooled with copper leads, they were the bee's knees 20 years ago, but plug lead technology has come a long way since then. I use a modern NGK lead with an inner spiral and have never had any problems. Though copper wont be worse i guess.
posted on June 28th, 2011 at 01:30 PM
Yes,
the old copper leads are very basic...
but they still work great....
they don't burn out....
can only short out, same as most leads...
I would like a good set of spiral type leads but the ones I want are just too expensive... lol
posted on June 28th, 2011 at 02:19 PM
stock leads like beru will be the best set up
they work
[ Queries: 40 ] [ PHP: 3.0% - SQL: 97.0% ]
