[ Total Views: 795 | Total Replies: 5 | Thread Id: 91485 ] |
nsuwift
Threads: 27
posted on July 10th, 2011 at 07:23 AM |
flywheel rubbing on gaerbox bellhousing
Have pulled the engine and rear end out of my car. Inside the bell housing of the gearbox was brass shavings from the starter motor bush. Also there
is a groove been ground into the gearbox has been rubbing on the outside edge of the flywheel. What would likely cause this?
vlad01
Mood: Side ways
posted on July 10th, 2011 at 09:19 AM |
was the engine to gearbox bolts loose?
or perhaps someone fitted a 200mm flywheel into what was originally a 6V 180mm flywheel gearbox?
71 notchback,
nsuwift
Threads: 27
posted on July 10th, 2011 at 01:19 PM |
The bolts were all tight but one was missing. Gearbox has 113 301 103 on it with 40 and C as well.
matberry
posted on July 10th, 2011 at 03:47 PM |
Maybe rear main bearing has excessive clearance. Like heaps excessive .
Is the engine in generally excellent, good, fair or poor condition?
bevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
posted on July 10th, 2011 at 07:55 PM |
Could be a combination of all of those. Sounds like a 12v flywheel in a 6v gearbox, a solid brass starter bush sounds like a conversion bush. The
gearbox case may have been clearanced properly but the starter bush has failed and pushed up a burr on the gear teeth that may have cut a new
“track” that you can now see. File the burrs off the flywheel before you put it back in, after replacing the starter bush, and checking the rear
main bearing’s fit in the case. While it’s out you’ll be putting a new silicone rear seal in of course?
I’ve also seen a clutch pressure plate break a retainer strip, it swing out, and cut the bell housing off. You would see that though.
Good luck, Tony.
nsuwift
Threads: 27
posted on July 11th, 2011 at 08:43 AM |
motor is in good/fair condition I guess. This is my first attempt at working on a vw engine. How would I check the main bearing clearance. I really
don't to have to pull the case apart). It looks like the starter bush has a ctually been chewed by the flywheel. The bellhousing looks like it has
been attacked by a grinder by a previous owner. Possibly to fit a 200ml flywheel.
