[ Total Views: 666 | Total Replies: 8 | Thread Id: 91724 ]
Author: Subject:  What is this pressed area with hole for in luggage area
MemberCamo
A.k.a.: Kev
Threads: 209
posted on July 22nd, 2011 at 07:42 PM
Hi all,
can someone please tell me what this pressed area with the hole is for (arrow pointing at it). Its in the cargo area of a beetle and there is two, one on each side. This is obviously looking from under the car.
http://img.photobucket.com/albums/v63/levin4kevin/CopyofIMG_0199.jpg
Thanks, Kevin
MemberCraig S
A.k.a.: Craig
Threads: 83
Mood: In the mood for change
posted on July 22nd, 2011 at 07:52 PM
From my own experience they are there purely to allow moisture into the luggage area and cause rust. I discovered these holes after the painful experience of removing the original sound deadening and associated glue. I then discovered the rust that was beginning to spread from them.
Unless there is a compelling reason not to, I will be welding them up.
1969 Beetle - June
1974 L Bug - Gwendolyn
2002 Bora V6 4Motion - Anita
Membervwjon
Threads: 101
Mood: oily n thirsty
posted on July 22nd, 2011 at 07:59 PM
i believe they are child seat anchor points, they should have a larger plate and a captive bolt welded on there.
3 1959 cadillacs
1 musso
2 early notchbacks
2 split kombis
2 split panels
1 split ute
1 low light panel
1 ex-pmg bay
1 country buggy
1 beetle ute
1 14" syncro caravelle
1 16" syncro doka
1 golf cabrio
1 vw camper trailer
2 3meter bombs
MemberCraig S
A.k.a.: Craig
Threads: 83
posted on July 22nd, 2011 at 08:03 PM
That would make sense, and yes there was a metal plate, about the size of a 10 cent piece covering each of them, but they weren't welded in place, and the plate was also rusted.
1969 Beetle - June
MemberCamo
A.k.a.: Kev
Threads: 209
posted on July 22nd, 2011 at 08:47 PM
I believe my car body is an original 61 model and would be surprised if they came out with child restraint anchor points.
But then again, I have already been wrong once this year - just ask my wife :lol::lol::lol::lol::lol::lol:
Thanks, Kev
posted on July 23rd, 2011 at 09:43 AM
i think they are holes for carring the shell in the factory when the body shell was made
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on July 23rd, 2011 at 10:18 AM
Kev. for more than 50 years [I worked on them when they were NEW] it has eluded me! The only thing that I can think of is that they were a part of the 'jigging' of the body sheet-metall assembly process.
Don't weld them up - it will ruin the paint job. Put a couple of 'blind' rubber grommets in, to keep the water and dust out.
posted on July 23rd, 2011 at 10:31 AM
And we have a winner.
They aren't mounts for anything, just pressing for use on assembly line.
They have metal plugs in them and are covered over in seam sealer.
http://cache2.artprintimages.com/p/LRG/27/2704/8AFND00Z/art-print/james-whitmore-volkswagen-plant-assembly-line.jpg
MemberCamo
A.k.a.: Kev
Threads: 209
posted on July 23rd, 2011 at 11:53 AM
Thanks for the replies and letting me know what they are for. Mine never had any metal plates or similar over them when I pulled up what I think was the original lining.
Anyway, will plug them as mentioned to keep water and dirt out.
Thanks, Kev.
