[ Total Views: 1107 | Total Replies: 1 | Thread Id: 91985 ]
Author: Subject:  beetle 1500/1968 model.....seats again
Membermet9
Threads: 3
posted on August 5th, 2011 at 05:26 PM
hi,
i am in the process of taking the old original seats out of my beetle 1500....1968 model.
im pretty new to these cars and i am looking to undo the bolts that attach the seat frame runners to the body.....which i believe they do not exist as they would in a conventional car.
so because of this, am i to assume the seats would just slide back enough and simply detach from the runners?
i could try this now, but i though i would post a question first just in case i might have overlooked something that might cause more grief.
i still havent worked out which front seats to go with to replace the fronts, but i figured i could start by taking the originals out, cleaning up the rust to the floor pan and by then....i hope to have worked on the choice.
in the mean time if anyone can confirm what i am suspecting with the seat removal procedure?.....much appreciated.
met.
Membergrumble
Mood: happy all the time
posted on August 5th, 2011 at 05:59 PM
The seats slide forward for removal,there may be a locking plate that needs to be depressed to allow the seat past the full forward position. This will be located next to the slide if applicable. The seats are held to the frame by metal clips/tabs that can be lifted after releasing the wire on the trim and lifting it.
[ Queries: 40 ] [ PHP: 11.5% - SQL: 88.5% ]
