[ Total Views: 650 | Total Replies: 7 | Thread Id: 92742 ]
Author: Subject:  Timing a 009
MemberGazza265
Threads: 43
Mood: Mostly jovial
posted on September 19th, 2011 at 08:41 PM
Timing a 009
Hi all,
It has been a long time since I have needed help..thankfully.
Can anyone tell me the correct amount of degrees BTDC or ATDC that I should set the timing to with a timing light.
The engine is bog standard apart from being a 1300 case with 1600 barrels and pistons.
Fixer upperer of daughter's '69 Bug "Oscar"
Gazza
MemberBrian
Threads: 9
posted on September 19th, 2011 at 09:24 PM
7 to 10 degrees BTDC initial , ie static or at idle with most 009's but you really need to check the total advance and set it at about 30deg BTDC
info.gif posted on September 19th, 2011 at 09:32 PM
wote an answer to this but tried to download a pic which was too big and deleted my post...
As Brain says You can start around 8 degrees BTDC at idle
but the 009 MUST be set at the top advanced setting
28 BTDC or 30 BTDC [You can try both]
with a timing light...
with the engine revving at maximum advance..
if You have a degree pulley its easy...
If Not I can give You measurements..
MemberGazza265
Threads: 43
Mood: Mostly jovial
posted on September 19th, 2011 at 09:38 PM
Thanks Lee, yes it has a degree pully the same as yours...only it is missing the red rings...lol
Will having it run around set to 8 deg BTDC do any damage till I get to change it next saturday?
Gazza
info.gif posted on September 19th, 2011 at 09:41 PM
No that is OK...
it may even be where the idle ends up after timing it...
its just that you need to tune it at maximum advance
as they can be different at idle...
MemberGazza265
Threads: 43
Mood: Mostly jovial
posted on September 19th, 2011 at 09:46 PM
Thank heaven's for that, and pray tell how do I go about timing it at maximum advance when it is a mechanical 009?...then again...what else do I have to do to time it??
Gazza
MemberBrian
Threads: 9
posted on September 19th, 2011 at 10:01 PM
rev the the to about 2500rpm and set it at 30BTDC with a timing light
posted on September 19th, 2011 at 11:55 PM
Just rev the engine with the timing light attached to the spark plug lead,..
and move the distributor
so it reached but won't go over 28 or 30 BTDC...
when its revved... and tighten the dizzy screw...
and forgot about the idle setting....
PS: check out http://www.vw-resource.com/
