[ Total Views: 652 | Total Replies: 10 | Thread Id: 94311 ]
Author: Subject:  Clutch shudder
Memberjaksc
Threads: 49
posted on December 14th, 2011 at 04:42 PM
Clutch shudder
I have just installed a freshly built 1776 with a brand new clutch and machined fly wheel. I seem to get clutch shudder under load from take off. Any ideas?? Aaron
Memberdonn
Threads: 428
Mood: LAID BACK AND CONFUSED
posted on December 14th, 2011 at 05:07 PM
the bowden tube (at least I think that's what it's called) probably needs adjusting, that fixed mine
Memberbevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
posted on December 14th, 2011 at 08:37 PM
I’m with Donn, it’s almost always the Bowden tube.
Once that’s done the next one is that the bolts that hold the pressure plate to the flywheel are done up too tight. I know it sounds strange but it’s true, easy mistake. They need to done up nice and softly with a tension wrench, or the clutch shudders, strange but true. I hope that’s not it.
Good Luck
Tony
Country Buggy King & Link Pin Overhauls, Type 1 & 2 King Pins, General Machining.
http://forums.aussieveedubbers.com/viewtopic.php?tid=74138
My car is KO813
Memberjaksc
Threads: 49
posted on December 14th, 2011 at 09:37 PM
How do you mean the Bowden tube needs adjusting. Aaron
Membercnfabo
Threads: 140
posted on December 14th, 2011 at 10:41 PM
the bowden tube needs a bend in it "in the middle"..im not sure how much a bend but someone here would be able o let u know. i think the bend is maybe like 50mm but cant quite remember off the top of my head.....
did u touch the bowden tube at all when u had the engine out??
Membernarumi
I'll do it tomorrow
Threads: 8
Theme: UltimaBB Psyche Red
posted on December 14th, 2011 at 11:10 PM
did u put new engine mounts in?
posted on December 15th, 2011 at 05:56 AM
yep engine mounts or possibly the clutch arm is bent or cracked
Memberbtc-er
Threads: 25
posted on December 15th, 2011 at 02:01 PM
You know, I was getting a lot of clutch shudder recently too. Usually as I was taking off from a standing start, particularly uphill. I had reason to adjust the mixture settings on my carb recently as I was running too rich. Now the shuddering has pretty much gone. :crazy:
Memberempi
A.k.a.: Empstar
Mood: thunderous
posted on December 15th, 2011 at 02:11 PM
Clutch cable tube needs an s bend in it, undo the clutch cable at the gear box and add a few washers to the clutch conduit tube (Bowden) this should sort it.
Memberempi
A.k.a.: Empstar
Mood: thunderous
posted on December 15th, 2011 at 02:13 PM
http://www.thesamba.com/vw/forum/viewtopic.php?t=444813
I think this guy used too many washers.... u get the idea
Memberjaksc
Threads: 49
posted on December 15th, 2011 at 05:59 PM
Changed the Bowden cable as suggested. All shudder gone. I needed a longer one. Thanks again guy,s for the advice. Aaron
