[ Total Views: 994 | Total Replies: 3 | Thread Id: 95012 ]
Author: Subject:  No tinware on drag engines?
MemberDubbyFan
Threads: 193
Mood: Better to be late than dead on time
posted on January 26th, 2012 at 01:34 PM
Been cruising around the net and noticed a lot of VW drag engines have no tinware, why so?
Going to attempt to answer my question, obviously you eliminate the drag of driving the fan and I guess the engine doesn't get hot enough in the short time it is running.
Is this the reason or is there any other reasons you don't see tinware on VW drag engines? Thanks........
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on January 26th, 2012 at 03:57 PM
You have answered your own question. Some still run some form of cooling system so they can drive back to pits and to just cool heads down as well. Those using methanol rely on the fuel to help cool heads as it is a lot denser fuel and doesn't generate as much heat on combustion.
For those running methanol have I got this right to some degree??
MemberSides
A.k.a.: Dave Sidery
posted on January 26th, 2012 at 04:25 PM
There's also the weight factor... generators and alternators are HEAVY !!!
Probably 5 kg or so in the tinwear too at a guess.
"To add speed, add lightness"
:D
My toys
MemberSides
A.k.a.: Dave Sidery
posted on January 26th, 2012 at 04:28 PM
Have to be some truth in that I'd think... know from guys I race with who've switched across to E85 that they use 20-30% more fuel, but the engine runs 10+ deg C cooler.
My toys
[ Queries: 40 ] [ PHP: 12.3% - SQL: 87.7% ]
