| [ Total Views: 1494 | Total Replies: 15 | Thread Id: 95730 ] |
DubbyDo
A.k.a.: Dave
Threads: 45
Mood: need more compreshunn!
| posted on March 8th, 2012 at 04:28 PM |
34 pict carb and 009 dizzy
Was looking Carbies in general on CIP1's site when I saw a 34 PICT description saying not recommended to run these with a 009 type distributor,
something about the advance curve is too slow which will create a flat spot on initial acceleration. Has anyone run this combo and had dramas? I have
just ordered a new 009style distributor and cant afford new carbs just yet
Matt Ryan
A.k.a.: Matt Ryan
Mood: Fweemin
| posted on March 8th, 2012 at 06:57 PM |
Have a look here: http://www.vw-resource.com/009_dizzy-34_carb.html
Regards,
Matt.
DubbyDo
A.k.a.: Dave
Threads: 45
| posted on March 9th, 2012 at 12:33 PM |
Thanks Matt, looks like I might be having to upgrade me carburation sooner rather than later. When is too early to ask for an early christmas
present????
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on March 9th, 2012 at 04:25 PM |
I have a 009 on a 1300, works fine
Just set max advance at 30
DubbyDo
A.k.a.: Dave
Threads: 45
| posted on March 9th, 2012 at 07:01 PM |
Do I need to buy an indexed crank pulley or are there marks on the original pulley? I think I have found aTDC mark but not owning a digital timing
light that I can advance, or a protractor could make it difficult to set it at 30deg total
Matt Ryan
A.k.a.: Matt Ryan
Mood: Fweemin
| posted on March 9th, 2012 at 07:10 PM |
The following is courtesy of vw-resource.com
More info here:http://www.vw-resource.com/tune-up.html
The arc distances that follow are based on a pulley diameter of 175mm, thus a radius of 87.5mm. Be sure to measure the diameter of your pulley and use
the radius of your pulley in the following calculations.
009 and SVDA distributors: Measure on the rim of the crankcase pulley 11.5 mm to the right of the TDC notch. This is 7.5o BTDC; mark this point with
white paint. This is the point at which the centrifugal advance (009) and single-vacuum dual-advance (SVDA) distributors are preliminarily timed (the
maximum advance at 3500 rpm will be the final timing point for these distributors).
Maximum advance: From the TDC mark, measure on the rim of the crankcase pulley 46 mm (for a 175 mm diameter pulley) to the right of the TDC notch.
This is 30o BTDC; mark this point also with white paint. This is the maximum advance point at 3500 rpm, the timing point for 009 and SVDA
distributors.
Regards,
Matt.
DubbyDo
A.k.a.: Dave
Threads: 45
| posted on March 9th, 2012 at 07:18 PM |
Cheers for that Matt. ! more day of work then I can get into it. will let you know how it goes
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
| posted on March 10th, 2012 at 08:59 PM |
I can confirm that the 009 doesn't work with the 34pict carb. Flat spots like a bas786rd.
30/31pict is good with 009-good response and great to drive but lacks top end power.
34 pict works okay with SVDA distributor.
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on March 11th, 2012 at 01:25 AM |
i gave up with the 34 pict. My old stromberg is as happy as larry with the 009. My mate is currently going through the familiar hesitation issues.
Regardless of the maxxed out setting on the accelerator pump and it squirting right, and regardless of the pop rivet in the butterfly, the issue still
exists.
SVDA made a world of a difference with the 34 pict though, can't beat what the factory intended.
(ô_!_/ô) (ô_!_/ô)
matberry
| posted on March 11th, 2012 at 08:08 AM |
Yep, 34 PICT and 009 are not happy together.
DubbyDo
A.k.a.: Dave
Threads: 45
| posted on March 12th, 2012 at 09:38 PM |
posted by matberry
This isnt sounding too good, Ive already ordered the distributor with electronic module. So, seeing as I am intending to build a new motor in the
(hopefully near) future, what would be a good carb setup to look for on ebay, to A: remove any flatspot/hesitation issue, B: maybe give it a little
more oomph and C: not cost too much because they will probably be redundant when the new engine is fitted.
Thanks for all your comments guys, I got it going again with a condenser from a 68 Dodge truck (the closest I could find at our only garage!!!)and set
the timing after marking the pulley as per Matts post. Running even sweeter now so If hesitation becomes a bad issue can go back to std, nice to
improve on things though
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on March 12th, 2012 at 10:05 PM |
34 hasnt been happy since it was introduces its my least favourite carby. didnt even work that well with the stock dissy.
DubbyDo
A.k.a.: Dave
Threads: 45
| posted on March 16th, 2012 at 11:08 PM |
posted by Matt Ryan
distributors.
Regards,
Matt.
| that worked a treat Matt , checked the timing with the original dizzy after marking it out and what a difference. Smoother
runining and easier to start. Might leave the new distributor in the cupboard for now!!! Cheers mate
57 oval
Oval type 4 Fuel Injected
Threads: 48
Mood: Oval
| posted on March 17th, 2012 at 05:27 AM |
Have a look at this page, It sounds very helpful in making the two compatiable, Ive never tried it, but all makes sense
http://www.aircooledtech.com/34pict3_modification/
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on March 17th, 2012 at 08:33 AM |
^ yep that works.
h
| posted on March 17th, 2012 at 10:12 AM |
I had a pict 34 o'hauled by peter richards at sourh west rocks many years back
he did some mods to it so I could run a 009 successfully on my 1600 without flatspotting
I have used it on both sp and dp 1600 with 009 dizzy and works a treat
it is currently on my beach buggy working fine
so it is doable but obviously not a common combo
