[ Total Views: 580 | Total Replies: 5 | Thread Id: 95923 ]
Author: Subject:  play in 68 steering
MemberDubCrazy
A.k.a.: steff
posted on March 19th, 2012 at 10:42 PM
play in 68 steering
on the second new trw box and still it has the same freeplay and its driving me nuts!!
u can turn the steering wheel a good 2cm before it takes up the slack which can be a bloody scary thing at speed... pretty much everything has been replaced so i dont know what to do...
the only thing thats not stock is its running 2.5 droped spindles.
tryed tightening the box and nothing, made sure everything is tight and in the right spot... u can see the movment on thw input shaft so it has to be something to do with the box..
anyideas would be grand
steff............
MemberOllie
A.k.a.: Ollie Clarke
Yeah Buddy
Threads: 122
posted on March 20th, 2012 at 04:07 PM
I've just come to accept that steering play is part of a classic bug :p
Follow the Photo Fun:
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on March 20th, 2012 at 04:42 PM
Rack and pinion time!!!
I've started looking into it again since we spoke the other day :D
Smiley :)
Membergreedy53
Threads: 468
Mood: strung out
posted on March 20th, 2012 at 06:37 PM
have you used the ajuster screw also check all steering componets i had run in with my kombi turned out iyt was the ideler arm fitted a new 1 no goes where i want
MemberDubCrazy
A.k.a.: steff
posted on March 20th, 2012 at 06:57 PM
Smiley :) [/quotes/]
Seriously looking at it smiley!!
Tell u what u trial and error it on urs and when u have it worked out u can come and fit it to mine, I'm sure u will be in need for some paint work as payment :o)
Steff.....
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on March 20th, 2012 at 11:19 PM
Steff.....
It's going to be different on mine cause it's Link Pin, Country Buggy front and yours is ball joint.
I might be able to do you up a kit once I get that 1500 I'll have a Balljoint pan to play around with.
Smiley :)
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
