[ Total Views: 410 | Total Replies: 1 | Thread Id: 96241 ]
Author: Subject:  Swing axle - axle seal gasket question.
MemberSpecial Air Service
Chief "Gunna"
Threads: 210
posted on April 6th, 2012 at 09:11 AM
Morning all,
Whats the real story with the swing axle seal kits?
They are supplied with 2 x paper gaskets, which would make you think that one of these fit either side of the backing plate. In my experience they dont actually fit on the back side of the backing plate (between backing plate & axle).
Are they both supposed to be fitted on the outer face of the backing plate? I have a bentley manual that shows 2 different variation of the exploded view.... one with gasket positioned between the backing & axle...... and the other shows the gasket postioned between the backing plate & the outer seal carrier.
Should they have aviation sealant applied to them or applied dry? (I have also seen a video showing them being greased before they are put on???).
http://www.justkampers.com/videos/watch/rear_hub_reassemble
Or can they be left out altogether.....with sealant used instead.
Have done a few searches & there seems to be conflicting versios of the hows & why's?
Tahnks in advance for you help
Brendan
[size=5]
Click Below
[/size]
[size=6]
Mid North Coast VW
[/size]
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on April 6th, 2012 at 09:16 AM
Just one between the bearing cap and backing plate with sealant on both sides. I like to put it on the backing plate and set that in place, then put the big oring over
Oil the small oring and inside the outer spacer so not to pinch it as the cap goes down.
Load the outer spacer into the seal on the bearing cap, then put it on........Dont place the spacer on the axle the try tighten the cap/seal over the spacer.
If youve had the bearing out , it's nice to use an extra spacer or two and tighten the nut down to push (ie pull axle back out) and have the bearing in place with the inner spacer behind (as a dry run without seals).......this way you can place the small oring onto the axle and it will be past the splines so it doesnt get pinched
make sense?
