| [ Total Views: 1106 | Total Replies: 7 | Thread Id: 97101 ] |
Weeds
A.k.a.: Ross
Threads: 22
| posted on May 27th, 2012 at 06:46 AM |
Spare Parts....
Hello,
Was just curious what spare parts you carry with you in your Beetle for the event of a break down. I am currently making up a spares box and am
currently throwing in the following items:
- fan belt.
- fuel hose and hose clamps.
- fuel filter.
- 2 x spark plugs
- light bulbs.
What other items should be included, ie clutch cables etc
1965 VW Beetle
tar76
Threads: 95
| posted on May 27th, 2012 at 07:14 AM |
set of points.
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
ancientbugger
Threads: 191
| posted on May 27th, 2012 at 09:44 AM |
None, I'm an optomist (sounds like I check eyes!)
69bug
Threads: 24
| posted on May 27th, 2012 at 10:18 AM |
Spark plug, test light and a stocking + globes
1969 1500
waveman1500
Also rides a Honda
| posted on May 27th, 2012 at 01:39 PM |
What I carry in my bug:
Fan belt
Spare tyre
Spare fuses - I bought a couple of packets and put them in the ashtray. I've helped other VW drivers in the past by giving them ceramic fuses.
Wheel bolts x4 - I have had wheel bolts back out before and they were caught in the hubcap. The threads were mangled but purely by chance I happened
to have four extra wheel bolts in the car to swap them with. I make sure to do them up tight now!
Bottle of oil - just in case. I keep a 5 litre bottle in there, often whatever is left over after an oil change.
Cable ties, electrical tape and duct tape - handy for fixing your car and a thousand other uses. For example, in the past I have had a fan belt snap
whilst driving. As it went, the fan belt ripped big holes in the heater tubes from the fan housing to the heat exchangers. I taped these up with duct
tape, replaced the fan belt and was on my way again in about five minutes.
Tools I carry:
600mm breaker bar with socket for wheel bolts, it lies flat across the fuel tank and takes up almost no space. Much better than a little wheel brace.
Set of combination spanners and usually a 3/8" drive socket set.
A #2 philips head screwdriver and a medium sized flathead.
Side cutters and needle-nose pliers.
Factory jack, although when I'm going to motorsport events and intending to change tyres, I bring a hydraulic trolley jack.
Weeds
A.k.a.: Ross
Threads: 22
| posted on May 27th, 2012 at 09:18 PM |
Thanks guys
1965 VW Beetle
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
| posted on May 27th, 2012 at 09:24 PM |
John Muir's idiot book has a good section on tools.
Worth a read.
BiX
Threads: 154
| posted on June 1st, 2012 at 02:25 PM |
RACQ Card plus spare, tire lever and jack for general driving (very little)
at the track is a different matter.....
Go hard or go home!!!!
