[ Total Views: 903 | Total Replies: 10 | Thread Id: 98278 ] |
jimmybay
Threads: 10
posted on August 10th, 2012 at 04:13 PM |
Engine builder SA (stroker)
Getting a bit ahead of myself here but always godd to be ahead i spose.
Im just after an engine builder in SA that could build a strong 2110 or a bit bigger to fit in an oval i am soon to aquire.
I know i could get one crated from another state but i would prefer that the builder tuned and installed the engine to avoid the old "Na the bloke
that fitted ittuned it stuffed up".
Any help would be greaty thanks
Didyoubringdemgumnutsin?
jimmybay
Threads: 10
posted on August 10th, 2012 at 11:21 PM |
F it 36 and a judson it is SA performance vw scene pick your game up
snitz
Threads: 37
Theme: UltimaBB Psyche Red
Mood: "Bug"gered
posted on August 10th, 2012 at 11:43 PM |
Send Debiasi4 a PM (Adam Debiasi).His dad may be interested in building you an engine for you or discuss an engine como with you.
He works from home in the Adelaide Hills now and no longer runs a workshop.My wifes 70 beetle runs a 1916 built by Peter Debiasi running a block and
cnc ported heads supplied by Rod Penrose.Its a grunty little combo that we are very happy with.
Weather you go 1916 or stroker you will need to have the carbys (IDFs/IDAs or whatever..) jetted anyway so more than likey you will need to visit a
tuner rather than an engine builder at some stage..
jimmybay
Threads: 10
posted on August 11th, 2012 at 01:16 AM |
Thanks mate i have been trying to get a hold of Deiasi at the workshop that explains the phone being cut off.
Yeah i gathered a trip to a dyno would be needed but would be good to have the builder in the same state
Cheers for the help
snitz
Threads: 37
Mood: "Bug"gered
posted on August 11th, 2012 at 01:22 AM |
I have Peters number but try and PM adam first. If you have no luck I'll give it to you.I dont want to hand it out to everyone..just out of respect
for Peter..Cheers Jason.
Governor
Threads: 23
Mood: yes please
posted on August 11th, 2012 at 07:24 AM |
A good engine builder doesnt need a Dyno as he will tune the carbies to suit the engine, good builders know what they are doing.
A good builder will ask you what you want out of the engine, will fit it and also tune it so your happy.
matberry
posted on August 11th, 2012 at 09:11 AM |
Quote: | Originally
posted by Black64
| x2
What about Dave Prior. SA I think(?)
snitz
Threads: 37
Mood: "Bug"gered
posted on August 11th, 2012 at 01:25 PM |
Im sure Peter knows what combos work with cams etc and has documented jetting required for certain combos running whatever carbys..But he cant speak
for himself because hes not on here..
vwo60
Threads: 71
Mood: good
posted on August 11th, 2012 at 05:58 PM |
If you invest in a expensive engine it is a good reson to put it on the dyno to fine tune the combination, no engine builder no matter how good they
are can take into account all the small difference's in each build, my 2276 is running fantasticly but will get a vist to the dyno to check on my
choice of jetting and curve the distribuator to suit the engines characteristic.
snitz
Threads: 37
Mood: "Bug"gered
posted on August 11th, 2012 at 09:18 PM |
Exactly.
jimmybay
Threads: 10
posted on August 12th, 2012 at 10:35 AM |
Thanks snitz
Quote: | Originally
posted by vwo60
spot on mate
