[ Total Views: 540 | Total Replies: 4 | Thread Id: 99092 ] |
Aussie
Threads: 43
posted on October 6th, 2012 at 08:07 PM |
Fuel tank fitting
Does anyone know if there is a fuel tank fitting (simple barb like on a late beetle) that bolts onto the outlet and would eliminate the reserve tank
control valve on an Oval bug tank? Mine seems to be leaking slightly so I want to sort it out.
Aussie
Threads: 43
posted on October 15th, 2012 at 08:15 PM |
Bump?????? Would a late model fitting bolt straight onto an early tank?
psimitar
Threads: 148
posted on October 19th, 2012 at 11:55 PM |
You just need to check out the thread size and then look for hydraulic/oil brass connection. Maybe even the aluminium areoquip braided hose fitting
would come in that size.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on October 20th, 2012 at 07:20 AM |
I tapped the outlet hole in the tank to 1/4" BSP....plenty of grease on the tap to collect the bits of metal. A 1/4" BSP hose tail to suit your
rubber hose will be easy to find [Pirtek, etc.], and your original tap can always be re-fitted, if required.
matberry
posted on October 20th, 2012 at 08:11 AM |
Or replace the tap fitting with a normal beetle fitting as you suggested, they are interchangable. Or you can tap out a nomal outlet to 3/8 BSP for a
barbed fitting similar to what Greg has suggested but into the fitting instead of the tank. Or buy one of these, available in -6 or -8. http://www.piersideparts.net/CB3288.html
