[ Total Views: 574 | Total Replies: 12 | Thread Id: 99200 ] |
Aussie
Threads: 43
posted on October 13th, 2012 at 07:08 PM |
Fuel tank repair
Seems my fuel tank has a very small leak around the threaded fitting at the base. What is the best way to repair? I am assuming something like brazing
would be best. What about the repair epoxy type stuff from super cheap etc?
vwo60
Threads: 71
Mood: good
posted on October 13th, 2012 at 07:33 PM |
I have brazed a couple up with good resalts, it would be permanent repair if done correctly.
20bkombi
Threads: 26
posted on October 13th, 2012 at 08:29 PM |
Could take it to a radiator shop they soldered some fittings on to my bus tank. Was $30 for 3 fittings
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
gordysbeetle
Threads: 19
posted on October 13th, 2012 at 09:01 PM |
soldering is the safest way. brazing uses a naked flame, to use this method you must purge the tank.
Aussie
Threads: 43
posted on October 13th, 2012 at 09:41 PM |
Quote: | Originally
posted by 20bkombi
Where abouts did you take it? Was it on the coast?
Aussie
Threads: 43
posted on October 13th, 2012 at 09:48 PM |
Quote: | Originally
posted by gordysbeetle
I am guessing this is different to standard electrical solder?
vwo60
Threads: 71
Mood: good
posted on October 13th, 2012 at 09:49 PM |
simply block the filler neck up and fill the tank with water, just leave the part that needs repair out of the water. worked every time.
20bkombi
Threads: 26
posted on October 13th, 2012 at 09:54 PM |
It was done here
http://mobile.whereis.com.au/qld/southport/QLD/Ashmore/1/-7-Hinde-St/yellowId...
Ph 0402 233 027
psimitar
Threads: 148
posted on October 14th, 2012 at 12:22 AM |
Quote: | Originally
posted by vwo60
^^^WHS.
Solder isn't really meant for long term exposure to such a corrosive liquid so brazing is the best way to do it and how they would have done it back
in the 50-60's. Even welding can be done on a tank using the water method following a good few washes and flushes with degreaser and washing up
liquid.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on October 14th, 2012 at 07:11 AM |
Quote: | Originally
posted by vwo60
Doesn't work EVERY time, trust me! Tank MUST be purged, as gordysbeetle says.
vwo60
Threads: 71
Mood: good
posted on October 14th, 2012 at 08:50 AM |
Worked every time for me. simply filling the tank with water is actually purging it as it displaces all the flamable gas.
matberry
posted on October 14th, 2012 at 09:06 AM |
Quote: | Originally
posted by HappyDaze
Quote: | Originally
posted by vwo60
| IMO a recipe for a trip to the hospital. This is NOT 100% fail safe. I've heard of them still exploding using this method.
Beware!Quote: | Originally
posted by vwo60
Aparently there is some residual gasses/compounds that stay. Even if it's only 1 in a hundred......I wouldn't take the chance.
Use epoxy putty or POR 15 tank repair kit or get a professional to do it.
My 2c
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
posted on October 14th, 2012 at 09:54 AM |
Even a washed tank can explode when welding as the heat drives fuel from the pores of the metal.
Proper preparation prior to welding a tank requires HOT pressure cleaning for a decent period of time. Like an hour or more.
Even then, danger is still there. Best to fill it with an inert gas like nitrogen.
I have heard of people hooking a hose to the tailpipe of a running car and purging the air that way.
May be okay in an emergency, but I wouldn't want to risk it myself.
I would just buy a kit from POR15 and seal the entire tank forever.
No rust, no holes. What more could you want?
