[ Total Views: 529 | Total Replies: 6 | Thread Id: 99904 ]
Author: Subject:  Working on 1600 T1 motor in bay kombi
Memberpfillery
posted on November 30th, 2012 at 04:51 PM
Quick question.
Do you have to drop the engine out of a bay kombi to give it a freshen up ie do the basic seals including the oil cooler seals and take off the tinware in order to paint said tinware? It is on my "to do" list but I would rather remove a few bits a couple of times over a couple of weekends than drop the engine if it isn't needed.
There seems to be a heck of a lot of room in there plus the access panel from the top as well so has anyone done it and can it be done?
MemberKlaus
Threads: 100
Mood: Heavily modified
posted on November 30th, 2012 at 08:47 PM
drop it out , doesnt take long and u can do rear main seal and check clutch at the same time
Memberwaveman1500
Also rides a Honda
posted on November 30th, 2012 at 09:51 PM
Dropping the engine is very quick. It's really worth it!
Memberpfillery
posted on December 1st, 2012 at 02:41 PM
Clutch is 12 months old so should be ok. I'm just concerned that getting it out and back in in a weekend will be pushing it and I'd hate to be stuck on monday with no engine!
Memberwaveman1500
Also rides a Honda
posted on December 1st, 2012 at 04:26 PM
If you know what you're doing, then you should be able to get the engine out and back in within about 45 minutes. The first time I took a Beetle engine out, it took half a day. The second time, it took half an hour. The difference was knowing what to do!
Memberpfillery
posted on December 3rd, 2012 at 07:36 AM
Originally posted by waveman1500If you know what you're doing, then you should be able to get the engine out and back in within about 45 minutes. The first time I took a Beetle engine out, it took half a day. The second time, it took half an hour. The difference was knowing what to do!
It has been about 23 years since I dropped one out and that was a very early type 3 motor dropped out of a 62 wagon, so probably more complicated than a bus. Mind you I did the type 3 on the front lawn of my house with a borrowed trolley jack on the grass and stored/moved the motor around on my old billy cart (I was 16 at the time).
I have a pair of ramps, some axle stands and a small to medium trolley jack - will that do it? I still want to keep to the adage of trying to keep it simple ie not doing stuff that isn't necessary but I'm yet to even find the time to degrease the engine and do some of the basics so living in hope that this may happen.
Memberwaveman1500
Also rides a Honda
posted on December 3rd, 2012 at 04:21 PM
Can you unbolt a panel at the back of the Kombi to roll it out? If not, you will need to get the back very high in the air in order to slide the engine out. On mine, I had to buy extra-high axle stands (4wd style ones, rated to 4000kg) and use about 3 thick wooden blocks (sleeper offcuts) on top of my jack to get the height.
http://i386.photobucket.com/albums/oo304/waveman1500/Superbug/P1000669.jpg
If your ramps can get the back of the car about 700mm off the ground, then you should be fine.
http://i386.photobucket.com/albums/oo304/waveman1500/17-05-09_1502.jpg
The stands on the left are the regular pin-type ones, even on wooden blocks they weren't tall enough.
