[ Total Views: 30175 | Total Replies: 442 | Thread Id: 64504 ]
 Pages:  1  ..  12  13  14  15
Author: Subject:  71 Fastback turbo EFI 2332cc(Dyno done and no breakages!)
Memberdangerous
Mood: 591
posted on May 13th, 2010 at 05:12 AM
CB perfomance supply the case already bored and clearanced.
Originally posted by westi
That's mad Alan.
posted on May 13th, 2010 at 09:06 AM
Yep, you wouldn't see any of those sharp corners if it was done by the best up this way :).
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on May 13th, 2010 at 06:22 PM
So CB did that machining in the pic....and the face of the case?..............yikes
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on May 13th, 2010 at 07:48 PM
I thought you used crankshaft engineering for that type of work
Member2443TT
A.k.a.: Ian
Threads: 69
posted on May 13th, 2010 at 08:06 PM
Man that sucks. Its the reason why I decided to use an oxy boxer case.
I still have an alloy CB alloy case here sitting on the shelf that has a similar issue. I was having some tig welding done on the case to modify the oil control, and parts of the case where the welding was being done were just colapsing with porosity. In the end after the welding was done the porosity was fixed, but it didnt leave me with a lot of confidence in the case.
How are you going to fix this Dave? Tig and then machine the case again?
posted on May 13th, 2010 at 08:13 PM
Yep, sure do Troy, CE do all my case and crank machining work. When I said 'done by the best up this way', I meant done by Crankshaft Engineering, being north of the border. The machining quality is one of the trade offs for the superior strength of the aftermarket cases.
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on May 14th, 2010 at 05:57 PM
the case thats in rod richardsons car is the same but his was really good where mine was rough around the barrells but even with the crack i will run it and see what happens, at least being aluminum i can weld it up later if it gets worse
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on May 24th, 2010 at 08:22 PM
dave and i have sealed everything up as best we can, crack shouldnt be a issue for now so i should have it running again later this week so soon will see if any oil leaks, lets hope
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on May 31st, 2010 at 06:00 PM
engine is back in and running again, just having a few problems with miss firing or something. Will spend sometime and we find whats happening then book the dyno for july
posted on May 31st, 2010 at 08:43 PM
:tu::tu::tu:
Nice to have the beast back on the road Troy. :)
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 1st, 2010 at 04:49 PM
yeah matt, would be even better if it just ran properly but that cars for you. I suspect i have a manifold leak myself after checking all the connections so will do some more tests this week and should be fixed up this weekend
MemberSides
A.k.a.: Dave Sidery
posted on June 1st, 2010 at 05:32 PM
Good stuff !!!
Gotta ask tho... and I've read your last few posts several times over Troy... but which car did the engine go into ???
:smilegrin:
My toys
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 1st, 2010 at 06:28 PM
Its all good, dangerous has the engine at the moment and said it will be ok, its just not real good in that area when it was cast. He will seal it all up and put it back together and just see how it goes..
typethreeking, a while back there was a vw trike up the top of the hill at edens landing. last time i drove past recently, it had disappeared. was that yours? Near the water tower. :tu:
(ô_!_/ô) (ô_!_/ô)
Member20bkombi
Threads: 26
posted on June 1st, 2010 at 10:21 PM
The engine will stay in the type three until after warwick Troy tells me.
Have you tried the spark plugs yet?
The injectors have a gauze filter in the top aswell.
Hope you find it before you go to the dyno, to save money.Good luck fella!
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on June 2nd, 2010 at 08:02 PM
Make sure those bloody injector rails are seating properly. You know how much of a mongrel they are to get access to in the car and once you stick your hand in that small space you see nothing....
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 2nd, 2010 at 08:04 PM
bajachris88, no thats not my trike, i live three streets back from where that trike was. Well looks like a manifold leak was the problem, i sprayed inox around the manifold near the head while it was running and noticed a change straight away so i have removed manifolds, made gaskets and reinstalled them, just have to refit injectors tomorrow and fire it up, hope it behaves it self!!!
Member20bkombi
Threads: 26
posted on June 2nd, 2010 at 08:38 PM
Good work!!!! :yes:
Ph 0402 233 027
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 3rd, 2010 at 06:47 PM
well for once things went to plan and car is running well with only minor oil leaks from a few fittings, now to clean up and get ready for the dyno next month
Membershaven
Threads: 67
Theme: UltimaBB Powder
posted on June 4th, 2010 at 04:32 AM
just had a look @ your Fasty Brennden. mate very fcuking noice...
whats it feel like to be waiting @ a set of lights & a P plater pulls up in his ... of course very cool pimped out VL running odd rear tyres on the back... & looks across @ you:crazy::crazy::crazy:
do the knuckles turn white:lol:
"When the character of a man is not clear to you, look at his friends"
posted on June 4th, 2010 at 06:35 PM
It's my brother's car mate - Troy. I have been in it with such an occasion occurring - give them a head start and be nice LOL
Troy pics of the burn on the arm for all to see need to be posted up.........
MemberStanley
Threads: 270
posted on June 5th, 2010 at 03:41 AM
Glad to hear all is better now Troy...now get to work on the other car.
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 5th, 2010 at 12:53 PM
yeah thanks stanley, just booked the dyno for the 1st of july for more boost then just valla and warwick this year and then i will be starting on the tube chassis car. i will post up the pic of my nice burn on my arm after touching the header pipe while trying to get the engine running again properly after putting it back in.
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 5th, 2010 at 12:59 PM
http://i658.photobucket.com/albums/uu310/type3king/burn.jpg
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 5th, 2010 at 01:01 PM
cant what till this engine is in the tube chassis car, will have plenty of room to work with burning myself..haha
Memberdangerous
Mood: 591
posted on June 5th, 2010 at 02:44 PM
How'd you get a burn like that on your right arse cheek?!:lol:
"hello is that the doctor?,
...yes, hello doc, I burnt my arse,
and now I have this huge crack in my butt!"
That's mad Alan.
Memberdangerous
Mood: 591
posted on June 5th, 2010 at 02:49 PM
...."and while you are down there Doc, perhaps you can take a look at the big mole"
That's mad Alan.
Member20bkombi
Threads: 26
posted on June 5th, 2010 at 10:02 PM
better shave it first!!:lol::lol::lol:
Sorry Troy, that looks painful.
Ph 0402 233 027
posted on June 6th, 2010 at 07:30 AM
Got to agree with you Dangerous pic does kinda look a bit suss LOL
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 6th, 2010 at 03:34 PM
haha everyones a comedian!!!!!
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on June 30th, 2010 at 07:01 PM
car is loaded up on the trailer ready for the dyno tomrrow, will see what horsepower difference will be with the different turbo then will slowly increase the boost and see how it goes
[ Queries: 40 ] [ PHP: 9.6% - SQL: 90.4% ]
