| [ Total Views: 2032 | Total Replies: 36 | Thread Id: 100210 ] |
| Pages: 1 2 |
gordysbeetle
Threads: 19
| posted on December 23rd, 2012 at 12:39 PM |
they have the bump stop under the sleeve. just the empi copy wheels.
vwo60
Threads: 71
Mood: good
| posted on December 23rd, 2012 at 01:18 PM |
I will have a set of genuine 16" porsche fuch's for sale in the near future as i will be changing these out for a set of composite wheels. if you
were close you could have tried them.
psimitar
Threads: 148
| posted on December 23rd, 2012 at 04:40 PM |
I still think those lower BJ's don't sit into the spindle taper far enough especially if you take a look at how the top BJ sits, The boot is
properly compressed and the BJ thread is more exposed than the lower BJ.
Also that lower BJ taper boss on the spindle does look like it sits lower than I've seen on other lowered spindles. Others I've seen don't sit
right at the bottom of the casting.
I also forgot to say that you should invert the ARB clamps so the bolts point upwards and hence no chance of being caught on any bumps in the road.
madness is in the eye of the beholder
gordysbeetle
Threads: 19
| posted on January 1st, 2013 at 07:08 PM |
Update.
Replaced upper and lower balljoints ( third set now ) with a different brand. Problem solved. The balljoint shaft was shorter giving me 4mm clearance
from the rim. Now to replace the new tie rod ends when the suppliers open again the new ones I purchased have perrished and I haven't used them yet.
Some aftermarket gear is total crap. Have a good new year everyone.
1303Steve
| posted on January 1st, 2013 at 07:58 PM |
Nice car, I couldn't see it the photo but do you have the notch on the camber adjuster pointing to the front?
This can affect the stub axle position.
psimitar
Threads: 148
| posted on January 2nd, 2013 at 12:27 AM |
| Quote: | Originally
posted by gordysbeetle
Update.
glad I was on the right track for you and you got it sorted
vlad01
Mood: Side ways
| posted on January 4th, 2013 at 08:33 AM |
| Quote: | Originally
Update.
wow! reminds me of the ball joints and tie rod ends I had on the the daily. same thing happen but worse as they filled with dirt and seized. I had
locked front suspension
not even 6 months they lasted.
I use road safe branded ball joints and tie rod ends if genuine isn't available.
they are good and last forever. haven't had one fail or wear out yet and the boots are still soft and supple.
71 notchback,
| Pages: 1 2 |
