[ Total Views: 2991 | Total Replies: 44 | Thread Id: 22309 ]
Author: Subject: Air locker for Vw
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on May 13th, 2004 at 10:59 AM
I could have used either of these on Monday.... got stuck chasing goats alongside the road (its a long story). The point is, I could have walked out of this no probs if I'd had a locker or LSD fitted....
Kruizin Kol
Memberseagull
Threads: 752
posted on May 15th, 2004 at 10:54 PM
Do you think so ! looks like a big hole
Member11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on May 22nd, 2004 at 06:50 PM
VW's factory vac locker
Here's a pic of the vac locker in the locked position
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Member11CAB
Threads: 321
Mood: Beach'n
posted on May 22nd, 2004 at 06:51 PM
and unlocked
65 Meyers Manx
68 Baja Bug
Member11CAB
Threads: 321
Mood: Beach'n
posted on May 22nd, 2004 at 06:57 PM
So who has a CAD program and CNC machine?? Looks simple enough........
65 Meyers Manx
68 Baja Bug
Memberseagull
Threads: 752
posted on May 24th, 2004 at 11:47 PM
yes I wish I had one I would be there now making them .This one is from a vw ? and what box ?
Member11CAB
Threads: 321
Mood: Beach'n
posted on May 25th, 2004 at 07:45 PM
It is a factory VW locker from a T3 Syncro.....091 side shift trans.
Graham
65 Meyers Manx
68 Baja Bug
MemberMickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on May 25th, 2004 at 07:54 PM
How available are the side shift 091's with the locker???? Why not just use one of these and convert it to a "normal" shift??:)
tssnq.com.au
Memberseagull
Threads: 752
posted on May 25th, 2004 at 08:46 PM
yep may be dont tell every one but ! who has a cad pdf format .I need to have a look .
MemberBoozer
Demented But Determined
Threads: 129
Mood: What the crap?
posted on September 4th, 2004 at 06:05 PM
any update on this???
Memberseagull
Threads: 752
posted on September 5th, 2004 at 01:04 AM
No I sold the gear off due to
time
I dont think any one would pay for it any way .
The air locker has lots of problems its in the O ring seals , diff temp goes up > air leaks out the diff breather , have seen them all and repared most of them .
I still working on the HSV holden one , so if you see one stolen in the bush , go your own way , if you get my drift ;)
MemberFlintstones
Threads: 69
posted on March 2nd, 2005 at 07:56 PM
Seagull,
Any progress on the HSV diff?
Memberseagull
Threads: 752
posted on March 3rd, 2005 at 12:47 AM
I have done some work on this subject but due to two of my projects needing finishing have placed it on the back burner .My next project will require this set up so I will post it here when I have some work in progress shots .
Keep your eyes out for a 215kw holden parked on the side of the road !
Memberseagull
Threads: 752
posted on March 3rd, 2005 at 01:12 AM
.The unit when made is two halfs ( wave plates ) with the slides placed in the center then the uint is welded together with a tig , it filled with a high temp grease then sealed with a small bearing .
The problem is when the ( bearing thrust washer ) wears .The fine fragments have no where to go .The slides then are pushed into the center and do not drive ( lock ) each wheel .This then calls for the car to drive only one wheel or two as it may slip and find lock for a second then back to one wheel .
I have made a cutter for the lathe as to open the center , when I did the fist one I thought the center was filled with a coppy type grease ! then found it was small particals of the thrust washer .
I am going to see if I can get some thust washes made so I can repair the center , then return it to service in a VW diff .
The unit is over $1000.00 new or you may find one in a bin at a diff place like I did the other day .
seagull
MemberFlintstones
Threads: 69
posted on March 6th, 2005 at 09:08 PM
if you manage to get some washers, ls there a way you can modify the LSD so this won't shorten the life of it again?
Memberseagull
Threads: 752
posted on March 9th, 2005 at 01:25 AM
I would say no , it needs to be cut open for repair each time .
After looking at this tonight I will not follow doing any mods to make it fit the vw diff .
Membermalcolm
Threads: 102
Mood: where did he go!!!!!!
posted on March 9th, 2005 at 02:26 AM
try these guys at Modena Engineering I find them very helpful 0397824420 or 0397825273 they custom make gears all types of diffs might help.
[ Queries: 40 ] [ PHP: 16.4% - SQL: 83.6% ]
