| [ Total Views: 1553 | Total Replies: 36 | Thread Id: 4114 ] |
| Pages: 1 2 |
waltermitty
Mood: Hungry for mor
| posted on April 23rd, 2003 at 07:24 PM |
I have found a 1970 Kombi It has wide 5 ( i think) and factory drum drums will this have the correct front end and swing plates axles for
conversions?
Also how much does a standars bay beam lower a splitty? and does it widen the track?
Mitchell .
23 windows ...8 too many!
kombi_kid
Good Kid too many projects
Threads: 341
| posted on April 23rd, 2003 at 07:38 PM |
only 68/69 kombi beams will fit and they make ur kombi sit higher by about 2 inches and i think they keep the same track
rhys
fish
Threads: 32
Mood: just cruisin
posted on April 24th, 2003 at 05:11 AM |
think i'll stick with Kimm. seems like the best alternative to all my lowering worries. fish.:bounce:bounce:thumb
Drink and drive your a bloody idiot!!! make it home you'r a legend !!!!
kombi_kid
Threads: 341
| posted on April 24th, 2003 at 08:56 AM |
so what u gonna go fish??
rhys
59 BUS
Threads: 27
Mood: Too Low?
| posted on April 24th, 2003 at 09:31 AM |
Hey Fish, I might be up the coast this weekend, we should meet up then you can see what my bus rides like!
:bounce:bounce:bounce:bounce:bounce
humpty
Threads: 139
Mood: Totally boosted!
| posted on April 24th, 2003 at 10:52 PM |
Walter...
The LP front with drop spindles will narrow your track by about 30mm per side, a BJ front with discs will widen your track by about 40mm per side. A
BJ with Drums I can not tell you as I have only ever converted them to discs. I like to stop as my cars all have modded engines & I like to
drive'm hard! And yes that 1970 front end will fit. Later BJ beam can be made to fit. You just need to just need to drill new holes through the
chassis and add some spacers inside the rail for strength (just as the factory has). But you must get it straight otherwise you alignment will be
out!!!
Not good grass hopper!
I have only ever used Kimms (Chief) adjusters on BJ front ends. On the LP front Antony used modified AVIS adjusters with home brew drop
spindles....Worked a treat and was loads cheaper!
fish
Threads: 32
Mood: just cruisin
posted on April 25th, 2003 at 02:54 PM |
Rhys. going to stick with Kimm (Chief) on the front and rear. Just got to find myself a 1968-69 suspension. fish
kombi_kid
Threads: 341
| posted on April 25th, 2003 at 03:02 PM |
koolio!!!
rhys
fish
Threads: 32
Mood: just cruisin
posted on April 26th, 2003 at 10:34 AM |
didn't get a chance to look at the 68 kombi this weekend, maybe next week. :alien
AndyL
Threads: 25
Mood: always looking
| posted on May 7th, 2003 at 08:22 AM |
Lowering
thanks for the replies on lowering, just wondering why my back wheels are leaning out at the top, is this so when there is weight in the van they sit
more vertical or is something amiss here? any help always appreciated. is 3 - 3 and a half inches the minimum you can lower a bus front end or is
1-2" possible? cheers Andy
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on May 8th, 2003 at 03:32 PM |
If you only want to lower it 1-2" then have some adjusters put in and forget the dropped spindle argument. The rear can be lowered to suit just
by adjusting the rear splines, which is outlined in the workshop manual.
Kruizin Kol
| Pages: 1 2 |
