[ Total Views: 154378 | Total Replies: 56 | Thread Id: 51017 ]
Author: Subject:  My 1302S 'Racecar' Build-up.
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on May 21st, 2006 at 10:50 AM
Want some brakes?
A bit of reading for you!
http://forums.aussieveedubbers.com/viewtopic.php?tid=36884#pid440206
and
http://forums.aussieveedubbers.com/viewtopic.php?tid=42417&page=1
[ Edited on 21-5-2006 by VWCOOL ]
Pay your debts, CxxT
MemberVolkswagenboy
A.k.a.: Brenton Barry
Staggers Automotive.
Threads: 92
Mood: Indifferent
posted on May 21st, 2006 at 04:49 PM
Thanks, it's a good read man. I'll look into those.
-Staggers.
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on June 25th, 2006 at 09:43 PM
Just a question to you body pro's...
Should I opt for a full sandblast of the body and pan, or just work on the sections bit by bit
(Hoping not to find out further down the track that I missed some rust)?
I'd also be getting my '68 blasted too if I decide to.
Thanks.
-Staggers.
Membermalcolm
Threads: 102
Mood: where did he go!!!!!!
posted on June 25th, 2006 at 11:44 PM
don,t sand blast the body the last thing you want to do is pit the metal.clean off as you go and youwant get lost in the repairs .
chemicaldipping is better as long as its nutrialized properly.
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on June 28th, 2006 at 08:26 PM
Thanks for the tips/reccomendations, I might look into acid dipping.
-Staggers.
Memberjhp1
Banned
Threads: 33
posted on June 29th, 2006 at 09:31 AM
Memberkoolkarmakombi
enkarmarising
Threads: 158
Mood: do you see the bats?
posted on June 29th, 2006 at 09:48 AM
Hey Staggers,
Use one of those blue 3m discs on a grinder, cheap, easy and doesnt rip all the paint off the inside where you cannot reach.
Why not put the engine from the land rover in it ;-)
kkk
Memberbugbrained
Threads: 36
Mood: givin up cigs
posted on June 29th, 2006 at 08:12 PM
i gotta get over staggers get the whole run down on the set up your going to use . looking good so far catch up soon
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on June 29th, 2006 at 08:49 PM
Setting up the arse end will be the main thing, strenghtening it for the torque increase mainly.
Radiators are generally mounted in the spare wheel well, or above the gearbox somehow... I'm planning to do things different.
There's probably more people out there (On AVD) who could help you out better, as I'm only starting off really.
You'll need an adaptor plate obviously, but these are relatively cheap and generally come with a flywheel to suit.
They cost about $550 to $750, depending on who you buy them from.
Oh and for using my Land Rover V8, I love offroading too much!
-Staggers.
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 29th, 2006 at 09:41 PM
am so envious of ur dry, level, cement floored work station... :(
But its kool hearing her progressing
(ô_!_/ô) (ô_!_/ô)
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 26th, 2006 at 04:39 PM
Okay so the box is out, most of the body mount bolts removed, front end and brake lines disconnected...
I'm definately happy with the condition of the pan,
needs a fair bit of work still but it's nothing major. I'll try to get the pan ready to be removed by next weekend.
Good news for me is the fact that the box is a single side plate, but I'll need to replace a few seals and gaskets before I use it.
I'm also trying to decide whether I should use my rear side windows for air intake to the radiator, or install a couple of fibreglass scoops into the actual body.
-Staggers.
Memberbutidontunderstand
Threads: 113
Mood: :)
posted on August 27th, 2006 at 01:17 AM
does it look like a racecar yet? :P
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 27th, 2006 at 01:18 AM
Not quite yet, but it's getting there!
-Staggers.
Threads: 113
Mood: :)
posted on August 27th, 2006 at 01:20 AM
ahuh
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 27th, 2006 at 03:03 PM
I've discovered one way to f**k your back before the age of 20...
Lift a Beetle body off its pan, BY YOURSELF!
-Staggers.
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 27th, 2006 at 06:37 PM
Okay so the body is now hanging from the roof!
I'm extremely thrilled to see the condition of the heater channels and pan.
So far the right front end of the heater channel is the worst, and the only section of heater channel with rust!
It's quite noticeable that the rear section of the left channel and pan half have been replaced, due to the lumpy welds!
A few hours grinding and rewelding should have them looking like new.
On the pan the main part with rust is under the cross member where the brake master cylinder mounts.
I picked up a few handy tips from Alan (Dasdubber) the last time I was over which will help to repair those parts.
There's alot of surface rust all over, but thankfully nothing detrimental!
Early days I know, but everything takes time!
-Staggers.
http://i83.photobucket.com/albums/j286/Volkswagenboy1/IMG_0020.jpg
http://i83.photobucket.com/albums/j286/Volkswagenboy1/IMG_0014.jpg
http://i83.photobucket.com/albums/j286/Volkswagenboy1/IMG_0016.jpg
http://i83.photobucket.com/albums/j286/Volkswagenboy1/IMG_0019.jpg
http://i83.photobucket.com/albums/j286/Volkswagenboy1/IMG_0015.jpg
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 27th, 2006 at 06:39 PM
Damn Photobucket image resizing!
-Staggers.
Member66deluxe
Threads: 139
posted on August 27th, 2006 at 07:51 PM
Yep, i lifted a body of the pan by myself once, stood inside and pressed my shoulders against the roof and lifted it was lighter than i first thought, then a mate came over and we lifted it of. But i hope your back is alright now Staggers.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 27th, 2006 at 07:58 PM
The back's fine but it made me realise how much I need to get a gym membership!!
-Staggers.
Memberbugbrained
Threads: 36
Mood: givin up cigs
posted on August 27th, 2006 at 08:05 PM
staggers what are YOU doing mate just give me a call next time you need a lift:yes:
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 27th, 2006 at 08:22 PM
Hehe Okay Jeff!
Man I need to get my arse round and do some work on that '68 too!
I have another pair of doors and some bits and bobs for it now.
-Staggers.
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 30th, 2006 at 08:08 PM
Yesterday I cleaned up the gearbox and today I started polishing it.
Why polish the gearbox you ask?
Because I need something to do in my lunchtimes!
http://i83.photobucket.com/albums/j286/Volkswagenboy1/Box.jpg
http://i83.photobucket.com/albums/j286/Volkswagenboy1/Box2.jpg
-Staggers.
Memberbugbrained
Threads: 36
Mood: givin up cigs
posted on August 31st, 2006 at 05:57 PM
no worries brenton im allways around somewhere, been checking on the tarp for you its hanging in well . you going to warrick drags your welcome to come for a run in the kombi with me :thumb
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 31st, 2006 at 06:45 PM
I might be, not too sure yet though.
Thanks for checking on the tarp! I was thinking about that the other night with all the dang rain about.
But anyway... to the box.
I bought myself a die grinder and 90 degree surface prep tool (Small 2 inch sander/grinder), both pnumatic. Been working on getting a nice old shine.
I hate the look of all the dang cast marks so they've been filed off, and the ribs are now smooth.
-Staggers.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on August 31st, 2006 at 09:15 PM
I know how fiddly it is to get into all those ribs - have fun!
Just a word of warning, I polished the ribs on my box and they tarnished/corroded/whatever you call it....I then repolished and clearcoated but still happenned to a degree. Maybe look into what you can do to keep it shiny apart from getting under the car and polishing by hand every weekend!
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on August 31st, 2006 at 10:32 PM
Okay thanks for the tip!
I'll look into it some more.
-Staggers.
MemberVolkswagenboy
Threads: 92
Mood: Indifferent
posted on September 2nd, 2006 at 08:46 PM
Okay so thisarvo (After I recovered from the rum 'n' rona's last night) I stripped the rest of my pan, bought a 17mm inhex socket to remove IRS arms.
All's rosey, just have to send the pan off now to be blasted and primered ready for repairs and rustbullet (Which I will need to buy soon).
After that I'll start scrounging 'round for some decent type three squareback arse end parts (Bigger brakes, heavier springrate to make the engineer happy).
-Staggers.
[ Queries: 40 ] [ PHP: 11.6% - SQL: 88.4% ]
