| [ Total Views: 195733 | Total Replies: 511 | Thread Id: 55220 ] |
| Pages: 1 2 3 4 .. 18 |
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
| posted on August 16th, 2006 at 10:38 AM |
Dude your idea of junka and mine must be slightly different....... wish I had your junk pile !!!!
Love it, fantastic - and great idea about the surge tank inside the original volksy tank. Did you have to do much prep to the tank to safely cut and
weld it ? (ie to get rid of old petrol fumes that might be flammable ?)
Boostn
Threads: 28
| posted on August 16th, 2006 at 12:08 PM |
Adolph
| Quote: | Originally
posted by Adolph
Very nice job. Will the bonnet close with the NOS bottle in that position?
I think I have just stolen some ideas
Hermann
I will find out if I have to shorten the front bracket to lower the bottle down a bit.
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
decked dubby
Threads: 91
| posted on August 16th, 2006 at 12:11 PM |
Cool work dude.
Boostn
Threads: 28
| posted on August 16th, 2006 at 12:22 PM |
1967 1300 Deluxe
| Quote: | Originally
posted by 1964_Notch
And this is a budget build up ! Any issues welding the tank ? I remember hearing that even after a thorough clean there can still be traces of fuel.
Can you post better pics of where the surge tank sides meet the bottom of the tank please ?
The tank mods is just time wasting and the POR 15 kit is $70.
It is true that even after a thorough clean you can still loose all your knuckle hair. The most important thing is to burn the vapours out properly
before you start but make sure your not building a bomb because it is still a small container. A mate of mine does gas conversions a cuts the tanks up
in vans and things like that so he showed me the way. If your not sure don't try it because you can damage your tank or even yourself.
I don't have any better pics of the bottom but it does have small holes at the bottom of the side plates so the fuel level is even, but slows in
sloshing away from the pick up.
VOLLKOMMEN ART
Speed and Style
dangerous
Mood: 591
| posted on August 16th, 2006 at 12:29 PM |
Hi Nick,
Now I know where the "art" comes from in Vollkommen Art.
I am so jealous of your fab skills.
What are you using to weld with?...as far as wire I mean, it is tig no?
Regards DB.
| Quote: | Originally
posted by westi
That's mad Alan.
Boostn
Threads: 28
Doug,
I have done the internal surge tank many times and many different ways because almost every car I do is either e.f.i or a tuff carbied car that needs
good pick fuel up.
I found that it is much neater than an external tank,lines,pumps and all that crap. Plus in a bug space is an issue, so many times we need to either
loose the spare or run the spare on the tank.
VOLLKOMMEN ART
Speed and Style
Boostn
Threads: 28
| posted on August 16th, 2006 at 12:37 PM |
Dave
| Quote: | Originally
posted by dangerous
Hi Nick,
Regards DB.
I have an Esab tig and an Esab mig.
.6 wire in the mig and just mild steel rod for the tig.
I love the finish of the tig but it takes soooooo long and with a project tike this I am mainly using the mig.
Dave I can't believe your saying that shit, I would much rather know how to machine things and mill things to the thou, RESPECT!!!!
VOLLKOMMEN ART
Speed and Style
Boostn
Threads: 28
| posted on August 16th, 2006 at 01:03 PM |
I still need help guys,
What engine combo?
Asp??
turbo??
Nos??
Ideas?
VOLLKOMMEN ART
Speed and Style
reub
VWRX is gone...
| posted on August 16th, 2006 at 01:40 PM |
Large capacity n/a old skool (with a little tickle gas)
Reub
Doug Sweetman
Threads: 58
Mood: sweeeeet
| posted on August 16th, 2006 at 01:48 PM |
I agree with Reub, large type 1 based, big big big IDA's (or equiv)......
Would help if we knew what was in your junk pile.....
I mean carbed sounds easier to most, but can still take just as long to tune as EFI, but EFI takes longer to install......
Personally I'd love to see a little roots style blower and big f&*k off 4 bbl on it..... but thats probably not really your style from what I
understand !!
pete wood
| posted on August 16th, 2006 at 03:01 PM |
seems to me that if you go tall them turboes hangin round, the least you can do is wack one on. be silly not to EFI it then if you have a computer
too. carbies are ok, but if the newer stuff is free and available to you, why not use it?
engine size below 2l and let the turbo do the work for you. just use the nitrous to get it up on boost and intercool it.
Craig Paton
Threads: 68
Mood: Absolutely Gratefull..!
| posted on August 16th, 2006 at 03:23 PM |
| Quote: | Originally
posted by Boostn
What engine combo?
Asp??
turbo??
Nos??
Ideas?
I'd like to see one of your "bad Ass" turbo's with the stock wheels and just a little lower!
Then you can just smoke those things down the Black top! :thumb
malcolm
Threads: 102
Mood: where did he go!!!!!!
| posted on August 16th, 2006 at 10:34 PM |
ratted
| Error |
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on August 16th, 2006 at 10:50 PM |
how 'bout a destroked crank, but still with 90.5mm......... some mega heads, efi turbo blah blah.......somethin still 1300cc, but revs to oblivion
with the aid of nitrous.
Boostn
Threads: 28
| posted on August 16th, 2006 at 11:42 PM |
I would love to do that, give a 1300 a 200hp hit of gas!!!!!!!!!!!
The only problem is those pistons are junk. But would be funny!
VOLLKOMMEN ART
Speed and Style
Boostn
Threads: 28
| posted on August 17th, 2006 at 12:14 AM |
2632cc
| Quote: | Originally
posted by Doug Sweetman
understand !!
I do not have any IDA's and you are correct about tuning carbies. I much prefer to tune e.f.i. The wiring is easy I have done heaps of Microtechs and
found the easiest way is to make my own loom seeing as is for a VW and not a usual car. I am trying to stay away from turbo charging this one because
it always get out of control and I find myself doing way too much work on bracing and gearboxes to handle the grunt. Remembering I want to keep it
simple.
I could use my brothers 2632cc T4 with twin 45mm perfection injection throttle bodies, 244@50 and 50x40 ported heads but I need to make an exhaust
system for it because he has it in a T3. It has been sitting around for about 7 years so he won't mind. The only problem is that I hate those exhaust
ports and need to spend money on fresh valve springs and bends for the exhaust.
VOLLKOMMEN ART
Speed and Style
Boostn
Threads: 28
| posted on August 17th, 2006 at 12:15 AM |
2387cc
The other option is a new 2387cc with ported 044s,Fk 10, 5.7'' h beam rods, pauter 1.4.1 rollers, cb thinline sump, mallory dissy and a comp of
9.8.1.The engine is complete less exhaust and throttle bodies, so I still need to spend money on it.
VOLLKOMMEN ART
Speed and Style
Boostn
Threads: 28
| posted on August 17th, 2006 at 12:16 AM |
2233cc
The final engine I have sitting around is a complete 2233cc t4 60mm wheel , pauter 1.5.1 rollers, 5.6 h beam rods, street comp heads 46x42
valves(ported) draw through with a single throttle body and two staged 1700cc injectors.This engine drove very well and made 220 kw @ the wheels on
15psi on pump gas. The beauty of this engine is that you don't need an intercooler because it's draw through. Simple!
VOLLKOMMEN ART
Speed and Style
Boostn
Threads: 28
| posted on August 17th, 2006 at 12:32 AM |
1967 1300 Deluxe
down on the ground with CB drop spinles, late discs and posche 4.5 blades.(just for the look)
I love the roof racks!
VOLLKOMMEN ART
Speed and Style
ruckus
Threads: 165
| posted on August 17th, 2006 at 08:23 AM |
Jesus I'd love to see you work. You get stuff done so bloody fast!
Is it true you guys never sleep?
hehehe
Doug Sweetman
Threads: 58
Mood: sweeeeet
| posted on August 17th, 2006 at 10:53 AM |
I vote for either the 2632 - just for pure cubic capcity, or my #1 vote would be the 2233 turbo - with the 1.5 rollers and the heads you have on it,
I'm not surprised it makes such big big numbers......
dangerous
Mood: 591
| posted on August 17th, 2006 at 01:28 PM |
What bore and stroke on the 2233?..and the 2632 type 4 too please.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on August 17th, 2006 at 01:30 PM |
92 x 84 and 105 x 76??
| Quote: | Originally
posted by westi
That's mad Alan.
GoLfMan
Threads: 14
Mood: supercharged
| posted on August 17th, 2006 at 04:30 PM |
nice work giving me some inspiration for my bug
i say a screaming NA engine that will scare rice from here to japan :P
[ Edited on 17/8/2006 by GoLfMan ]
firebreathing 4 potter...
vwfastback
Threads: 12
Mood: Ready for Boost.
| posted on August 17th, 2006 at 09:46 PM |
I feel sorry for you guys with all this junk and leftovers clogging up your shed.
Tell you what, how about I give you a case of beer and take some of this stuff out to the tip for you. Then you can make space for other toys.
I won't even charge you for the tip fees......
Boostn
Threads: 28
| posted on August 18th, 2006 at 01:36 AM |
1967 1300 deluxe
I'm thinking 2233 turbo for now.
I will think more about it later but now I will get stuck into the rear end and brace it all up without putting a cage into it.
VOLLKOMMEN ART
Speed and Style
Boostn
Threads: 28
| posted on August 18th, 2006 at 01:46 AM |
tip
| Quote: | Originally
posted by vwfastback
:cry
VOLLKOMMEN ART
Speed and Style
pete wood
| posted on August 18th, 2006 at 02:37 PM |
| Quote: | Originally
posted by Boostn
geez! I almost feel sorry for this little car....almost
ren
A.k.a.: PARKER LEWIS!
Threads: 58
Mood: Milky Fresh!
| posted on August 18th, 2006 at 08:07 PM |
the car is giving it's life for a greater good. respect. |
Boostn
Threads: 28
| posted on August 19th, 2006 at 11:59 PM |
Brace work
Some pics of the rear end taking shape
I used square tubing because round is always associated with race cars. So no round pipe or dzus fasteners, just square tube, bolts and nutserts. Plus
I'm lazy and square is easier to work with.
The engine and gearbox mounts have been raised up 1.5''
This because I run swing axle gearboxes and the axles must be straight on launch.So if you want to lower the car, this is how you do it. If you raise
the engine up any more, you must raise the torsion housing up too so you retain the rear end geometry.
This is my other 1967 1300 Deluxe that has been raised 3'' and tubbed 3''. This also requires to buy narrowed axles.
[ Edited on 19/8/2006 by Boostn ]
VOLLKOMMEN ART
Speed and Style
