| [ Total Views: 5358 | Total Replies: 127 | Thread Id: 56010 ] |
| Pages: 1 2 3 4 5 |
ren
A.k.a.: PARKER LEWIS!
Threads: 58
Mood: Milky Fresh!
| posted on October 3rd, 2006 at 05:54 PM |
Just ordered some Lotus White acrylic paint for the panels, and an extra pressure pack too (just in case). Should be ready tomorrow.....
paulr
Threads: 103
| posted on October 3rd, 2006 at 09:50 PM |
Ren
Sorry about the door mate. Thats a bugger of a job changing the hinges. I did not know about the different hinges either - Lindon filled me in the
other day when i was chasing a door for my type 3. The notch is looking great, not sure about your foot though
Paul
Dazed and Confused
and riding a pushi
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 3rd, 2006 at 11:11 PM |
Don't be sorry Paul! You were a saviour, since the door doesn't need to be painted. Just have to wait to get to beerdoc's house to get the pin out,
then hopefully all will end well!
beerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
| posted on October 4th, 2006 at 07:10 AM |
| Quote: | Originally
posted by ren
mmmmmmmmm Did I here my name mentioned
Anytime guys as I have been to the expert about my knee he does not have to operate BUT another 6 weeks on the crutchs
So COME ON DOWN TO G/TOWN
I am in the process of riggy up a bungy in the garage similar to the mechanic in Mad Max movie Thunderdome I thinkit was :P
[ Edited on 3-10-2006 by beerdoc ]
Cheers Doc
reVOLKS at Fyansford Geelong
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 4th, 2006 at 08:59 AM |
Ok that's crap news, Doc. So when I come down are you going to be wearing a patch w/tatts all over, and a dodgy black leather vest?
empi
A.k.a.: Empstar
Mood: thunderous
| posted on October 4th, 2006 at 10:27 AM |
Fastys ans squares have the same 2 bolt hinge notch have 3 bolt , make sure u have the same door handle and lock mechinism too.
empi
"If at first you don't succeed, skydiving is not for you." - Anonymous
ruckus
Threads: 165
| posted on October 4th, 2006 at 12:14 PM |
Thanks Adam I think he's got that down...
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 4th, 2006 at 06:40 PM |
yeah got a new door today, since I got some advice that changing the pins would be an absolute ass of a job, since the door skin curves over the top
of the upper hinge, meaning you probably can't get it out that way, or smack it the other way from that side.
Brian (bagged notch) suggested that cutting and welding the hinges would be easier, so I just got another door. I think it's an OG Gulf Blue colour,
which will be nice once the respray is cut back.
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 4th, 2006 at 11:51 PM |
here is the new door with the right number of bolt holes. 3 is the magic number. door is gulf blue with a dodgy colour match over coat. Will strip it
back to gulf and have it mismatching for a little while, then paint it lotus.
Got the door seal off in one neat piece! don't need that because I'm using the pinch/seals from DDB. Beat a few large dents out of the door, which
was easy enough.
The 2nd photo shows the inside which is OG colour. Did I mention that I like gulf blue?
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 4th, 2006 at 11:56 PM |
Got this bug ignition on the advice (from a local VW dealer!) that it would fit a type 3 with an extra hole needing to be drilled. Wrong. Scored a
used fasty barrel which bolts up, but it has no key. At least the key from the new bug barrel I bought works! he he..
Installed and ready to fire up the 1600 twin carb now! well not yet, since the engine isn't hooked up....
Also got this super high tech shorter shifter, obviously far more desirable, rare and expensive than a Berg shifter. Also scored a matching lotus
white ash tray, and some sunvisors/clips which scrubbed up nicely. Mirror was installed too, as well as shifter.
Headliner was masked off and sprayed with off-white satin vinyl dye, which worked great. It all sagged at first, but then tightened as the dye
dried.
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 5th, 2006 at 12:02 AM |
these seat rail bushes came in from the states yesterday, and were easier to find than expected (heard they were very hard to come by), but they were
a bit pricey, at US$65 the set. Smacked them in place w/rubber mallet, and trial fitted the passenger seat which sits nice and tight, with no play
whatsoever. Usually they rattle about because of broken/missing bushes. Got the enertia reel seat belts trial fitted, but I'm not sure if it's RWC
to mount the retractors on the rear seat panel. Don't know why it would be an issue, but they have to be perfectly vertical, so it's either that, or
mount them on the rear floor with an L bracket.
Another pic of the headliner....
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 5th, 2006 at 07:30 PM |
Steering wheel fitted, which should be white with a semi circle horn ring, but that was in pieces and missing some springs/washers, so just chucked
this '70 wheel in for now, and will put the nice one in after Rwc. Also got the enertia reels sorted, mounting them on the rear seat panel, nice and
neat, not in the way and the work very smoothly.
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 5th, 2006 at 07:37 PM |
Got the decklid on, in red ox for now, and the licence plate light, including 12v bulb change over. chucked the 996 mats in the front, because I
won't be able to put the front carpet in until front fenders are done and fitted.
All seats now fitted, ahh feels good, and yes I did sit in the drivers seat for 5 minutes picturing the car being finished and on the road....:duh
plastic interior heater box things are half in place, but one doesn't seem to fit, and has a superfluous tube coming out of it (?!). What are these
things called, by the way?
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 5th, 2006 at 07:38 PM |
Some new bling! Well paint and seals anyway, and a new dual circuit master cyl, and brake lines. WCM bonnet/boot seals, and rear tail light seals. Got
2 cans of lotus white pressure pack too, for this and that.
ren
Threads: 58
Mood: Milky Fresh!
seats/belts etc finally in....
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 5th, 2006 at 07:39 PM |
make shift front floor.....
Grey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
| posted on October 5th, 2006 at 09:42 PM |
Looking good ren. That carpet looks excellent.
Is the extra outlet on your heater ducts for the centre windscreen outlet?? Or does a notch have the rear window heater like a Type 34 KG??
empi
A.k.a.: Empstar
Mood: thunderous
| posted on October 5th, 2006 at 10:09 PM |
| Quote: | Originally
posted by ren
Thats the correct steering wheel for a type 3 , also looks like it has the correct horn pushy thing too , white wheels and D horn rings were only
fitted to beetles. 71 on type 3s have big fat ugly plastic steering wheels .
Ad
empi
A.k.a.: Empstar
Mood: thunderous
| posted on October 5th, 2006 at 10:14 PM |
Chrome wolfsberg horn button fitted to pre 67 cars , frosted wolfsberg horn button 68 on.
Bit o useless info.
Ad
CAFFINEPUSHERMAN
A.k.a.: chris taranto
bandito di culo
Threads: 169
Mood: got the horn
| posted on October 6th, 2006 at 10:32 AM |
where ren really got his new rack from
you sure that roof rack wasn't a barina option ?
A candy coloured clown they called the sandman tip toes through my room every night just to sprinkle stardust on my pillow go to sleep everything will
be allright
1967 Type 3 square
1956 double door panel
1968 single cab kombi
CAFFINEPUSHERMAN
bandito di culo
Threads: 169
Mood: got the horn
straight outta low cash
be allright
1967 Type 3 square
ruckus
Threads: 165
| posted on October 6th, 2006 at 03:12 PM |
heeheheheehehe
busted
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 6th, 2006 at 03:45 PM |
Pusherman. Ok so I stole it from a Barina in the hood (st kilda!).....so what?! Like you don't go around stealing rusty vintage roof racks every
other weekend.
good point grey57, maybe it's for an optional rear window heater, or could be off a later model that had that option, or t34 or something else, since
I don't know if it's og. It is a 311 part though....
......thanks for the info empi, but I'm not sure it's completely accurate, because nearly all of the archived type 3 lit. on samba shows d ring
wheels, but yes black seems to be the standard. I just like white!
ruckus
Threads: 165
| posted on October 6th, 2006 at 07:33 PM |
Adam's going to tell you that's a 34 and you're not playing fair
Like the 70s chick though, beats having me sitting on your passenger seat. Speaking of which how sweet do those seats look?!
[ Edited on 6-10-06 by ruckus ]
empi
A.k.a.: Empstar
Mood: thunderous
| posted on October 7th, 2006 at 12:44 AM |
Look harder
| Error |
| Error |
bails
Threads: 9
| posted on October 7th, 2006 at 11:38 AM |
white
mmmmmm, 34. paint it white ren.
| Error |
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 8th, 2006 at 01:50 AM |
and look harder again....!
Grey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
| posted on October 8th, 2006 at 09:04 PM |
You missed one style of Type 3 horn ring out boys. Its a Petri Full Circle Horn Ring. Noice. There was one for sale at the swap meet last weekend. Was
tempted buy my T34 doesnt have the standard wheel anymore.
You can get these as repros too. Look good in your 3 ren
| Error |
ren
Threads: 58
Mood: Milky Fresh!
| posted on October 8th, 2006 at 09:41 PM |
Dean - Yes I saw that at the swap meet under the canopy! Very nice, but I was too scared to ask how much it was....
PS - If anyone has a thermador/swamp cooler for sale let me know!
CAFFINEPUSHERMAN
bandito di culo
Threads: 169
Mood: got the horn
| posted on October 9th, 2006 at 10:09 AM |
ren 6 empi 2 game ren
be allright
1967 Type 3 square
| Pages: 1 2 3 4 5 |
