| [ Total Views: 6471 | Total Replies: 46 | Thread Id: 66708 ] |
| Pages: 1 2 |
66deluxe
Threads: 139
| posted on May 21st, 2008 at 03:39 PM |
| Quote: | Originally
posted by Andy
Howdy Damo, looking good mate!
Question for you, you have kept the stock kombi bar at the rear (modified of course).
Do you still have the rubbers between the bar and the case?
And will you use the stock type 3 mounts betwee nthe body and the bar??
Richard
Richard, i have modified a rear bus bar to fit, i will be making some solid mounts between the case and the bar because it just rocks to easily, and i
am using the stock type 3 mounts. Question for you do you still have some auto gearboxes?
Damo.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
Andy
Andy's Adventures
Threads: 181
Mood: Happy Man
| posted on May 21st, 2008 at 07:59 PM |
That's great Damo, that's the trouble with my car, they left the stock rubber mounts on the case, so the motor is not properly supported to take the
torque of the motor. I think I showed you when I was around. I will need to do what you have done one day.
Hmm, do I have auto GB's, yes. What are you after?
Richard
X-I-TED
Mood: good
| posted on May 27th, 2008 at 11:31 AM |
| Quote: | Originally
posted by jake raby
Looks good Damo!!
(always in stealth mode, seldom revealing my presence :-)
wow a raby post that wasnt and ad
now thats MA$$IVE
nice work damo
are the thousands n thousands of splits really rare???
Tazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
| posted on May 27th, 2008 at 12:58 PM |
Looking good damo.... watching this with great interest.....
Tazz
1962 Type3 Squareback
1967 Type3 Fastback "Kermit"
66deluxe
Threads: 139
| posted on June 7th, 2008 at 06:28 PM |
I got my rods back yesterday and have dropped them of to be balanced, they would of been done earlier but my machinist has been flat out building V8
drag engines. I am still waiting for heads, cam and P&C's to arrive. Then i can get cracking on the engine. Here's pics of the big block chev
3/8 wavelock bolts installed into the rods.
66deluxe
Threads: 139
| posted on June 21st, 2008 at 04:53 PM |
Well i've decided to remove the auto trans for a rebuild, after reading many posts about increasing the power of the engine and not at least
replacing the seals in the auto, i have decided to do it right. as soon as this notch is complete and rego'd i will be selling it, to complete my bug
build so i want the buyer to be happy. A fellow aviation engineer mate of mine actually did his first apprenticeship in an auto trans overhaul shop
and he says he'll build it for me, i just need to source the rebuild kit, ie seals, gaskets, o-rings, brake bands. So i just have to find a
repuitable auto shop for the kit any one got ideas?
Damo.
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on June 21st, 2008 at 05:32 PM |
US http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&a...
US http://www.tricomponent.com/catalogs.htm
US http://www.transmissionkits.com/# http://www.transmissionkits.com/catalogs/PartFKNP.pdf
UK http://www.jpat.co.uk/productsandservicespartscatalogue.htm http://www.jpat.co.uk/jpat_pdfs/Audi_VW%203_04_2001.pdf
AU http://www.atraonline.com.au/
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on June 21st, 2008 at 05:53 PM |
One I missed
US http://www.drivetrain.com/volkswagen_dt.htm#VW003
Quote of the week
66deluxe
Threads: 139
| posted on June 22nd, 2008 at 07:09 AM |
Holy shit, thanks mackaymanx.
matberry
| posted on June 22nd, 2008 at 09:27 AM |
German Auto's may be able to help, they are local for you, II cab may confirm.
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on June 22nd, 2008 at 10:25 AM |
Bulkparts are the ones I see mentioned most on The Samba. Yeah I've been doing my research, been collecting autos for a few years. I have a
buggy(MaxFX) planned with MickH useing a type2 003 auto/EJ22. Let me know how you go kit wise as I maybe looking for one too.
Quote of the week
66deluxe
Threads: 139
| posted on July 31st, 2008 at 05:39 PM |
Well, my friend is rebuilding the auto trans for me he says he got the rebuild kit through his old boss in Canberra. I have finally gotten all the
parts for the rebuild, the rods and crank have been assembled so far more to come next week after Valla. Some foto's for you.
All parts layed out on bench.
Head comparison between LE 200 914 replica's top and rebuilt bus heads with 914 plug angle bottom
Keith Black 96mm pistons
AA 96mm cylinders
ready to measure crank borrowed mic from work
damo99
| posted on January 4th, 2009 at 02:58 PM |
I have some plans for the type 4 into type 3 conversion for thr bellows .it uses the stock type 3 boot and modified type 3 shroud to bolt straight on
to the type 4 motor. there are some photo's to show how it works
(hope they turn out(photo's).i will have to post again to add the rest of the finished photo's.
if any one is intrested just post on here and i'll send them the plans
| Error |
| Error |
| Error |
damo99
| posted on January 4th, 2009 at 03:03 PM |
this system works excellently ,keeps the type4 cool in all weather and uses a stock type 3 bellows .
it's also very easy to fabricate .the first photo is of the finished product ,the other 2 photos are of another persons efort using stock type 3
shroud (modified).but it doesn't seem to direct the air well enough
| Error |
| Error |
| Error |
damo99
| posted on January 4th, 2009 at 03:07 PM |
sorry the bottom 2 photos on the last post are of impi's(south africa's)fiberglass conversion shroud that can be bought from him(if you can contact
him )for about $25aus
MY68VW
Threads: 25
Mood: fresh metal
| posted on October 8th, 2009 at 09:35 PM |
I came searching for this thread as I've had my square back for a month now. It went in to have the type4 installed back in Feb. Rear discs
front/rear sways, efi, injected. Wayne Penrose did it and I'm impressed with the power and handling. Most impressive is the sound and constant looks
and comments.
Tuned Type IV power - shaking out the rust.
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on October 8th, 2009 at 11:49 PM |
If ya need any help or queries from a successful type 4 swap... ask midlifecrisis.
Sounds like ur going swarve though. He put one in a wagon some time ago for his daughter. nice bloke too.
(ô_!_/ô) (ô_!_/ô)
69' baja: kombi box, thing spindles, irs, disc front, type 3 rear drums, 2 inch lift kit, 31x10 rears.
| Pages: 1 2 |
