[ Total Views: 1614 | Total Replies: 34 | Thread Id: 73088 ]
Author: Subject:  For those who are running adj. struts
Memberdubdude
Threads: 1
posted on November 26th, 2008 at 04:20 PM
Ive just been looking into getting some topline stuff sent over, do you have a contact number brad? And are you only bringing in maxx struts or any topline products?
Member76bug
Threads: 20
posted on November 27th, 2008 at 10:18 AM
hi Bizarre
i have a question about the 3 bolt vforce struts, is the strut housing shortened at the bottom near the 3 bolt flange? so in effect there is no taper at the bottom of the strut housing any like a standard 3 bolt strut housing? also what inserts do u run in your 3 bolt vforce struts?
posted on November 27th, 2008 at 11:44 AM
Sorry - i run 2 bolt
Best you call Richard and discuss the details
Pretty sure i have Boge for my inserts
posted on November 27th, 2008 at 12:35 PM
Ok - there is cutting - welding and boring involved. There is taper involved. Not a simple cut job
MemberBiX
Threads: 154
posted on November 28th, 2008 at 08:14 AM
I run lower stiffer king springs in my 2 bolt super. They are just captured at full drop. I think they are 35mm lower and 30% stiffer than std. They arn't in the normal catalogue, but if you ring and ask they have the specs on file and are made as a custom order. I think mine were about $200 a few years ago.
Go hard or go home!!!!
