| [ Total Views: 3898 | Total Replies: 87 | Thread Id: 78783 ] |
| Pages: 1 2 3 |
Dirtbag
What the hell does standard mean?
Threads: 22
Mood: boobtastic
| posted on September 1st, 2009 at 07:21 PM |
I figured out a simple way to get the beam back together, and I hope it's right. If not, please let me know.
I pushed some leaves through the beam tube into the adjuster block so I could turn the adjuster block (with the adjuster bolt removed) 90 degrees to
reveal the pointy grub screw. Simply unscrew it and set it aside.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 1st, 2009 at 07:35 PM |
With the grub screw out, re fit all the leaves into the beam. Make sure the divot in the centre of the leaves is facing where you took the grub screw
out, as the grub screw will be going into that divot. Also make sure you have the leaves the right way around, as the trailing arm divots are on
opposite sides of the torsion leaves. I had mine marked from when I took it apart, so it was Tim proof. I found it easiest to push them through
separately rather than try to get them all through at once. It didn't take long to do each set of leaves. Maybe a minute or two. I might have had
beginners luck too : )
In the pic, through all the grease, you can see the centre divot is lined up with the grub screw hole.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 1st, 2009 at 07:43 PM |
Just so I'm clear, as I didn't know any of this before, this is the grub screw I'm talking about that locates the leaves into the adjustable block
in the beam adjuster. It's at a 90 degree angle to the adjuster bolt that sticks out through the slot in the adjuster, so the bolt has to be removed
and the block rotated 90 degrees to get to this screw.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 1st, 2009 at 07:46 PM |
With the divot in the leaves lined up with this grub screw hole, the screw itself should go in a fair way. If it doesn't, then the leaves aren't
lined up and the screw will stick out past the edge of the adjuster block and you wont be able to turn the block back the 90 degrees it needs to go.
Sorry I'm not very good at explaining things, so I hope this makes sense.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 1st, 2009 at 07:50 PM |
I took this photo just to show the two holes in the adjuster block. The top hole is for the adjuster bolt that sticks out through the slot in the
adjuster, and the bottom hole is for the grub screw that locates the torsion leaves.
I didn't have any trailing arms lying around so I used multi grips on the leaves to turn the adjustable block inside the adjuster back and forth as
needed. It would have been easier to just stick a trailing arm on though, just so you know.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 1st, 2009 at 07:54 PM |
So with the grub screw in place, I turned the leaves back 90 degrees so I could see the other hole through the slot in the adjuster and refitted the
nuts, bolts and alloy block that go on the outside of the adjuster. Do all this to the other beam and the job's done.
The next bit will be fitting it to the car and shortening the steering arms to suit. I'll try to get pics and ad it to this thread if anyone is
interested.
That's it.
| Error |
matberry
| posted on September 1st, 2009 at 08:32 PM |
Great job mate.....those welds look great
One small point, you may notice the grub screw has a point where the original has a flat on the end, a grinder will fix it so it aligns the leaves
correctly and doesn't work loose.
Flintstones
Threads: 69
| posted on September 1st, 2009 at 08:37 PM |
great thread + build pics
gsa2at
Threads: 25
Mood: busy
| posted on September 1st, 2009 at 09:00 PM |
lookin great tim
made sense to me and i am well known as incompetent with these things
i will definitely get some photos of the beam going in - maybe you should be there to assist with this bit seeing as it is your baby
jack the beetle rides again !!!
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 1st, 2009 at 09:10 PM |
I'd like to be there when it goes in, just to make sure all is well and to shorten the steering arms.
donovan
Threads: 37
| posted on September 2nd, 2009 at 03:28 PM |
I once had surgery on my rocket
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 2nd, 2009 at 06:32 PM |
And I'm sure your rocket is all the better for it : )
Mad bastard. You're as crazy as I am.
lohoon
Threads: 67
| posted on September 2nd, 2009 at 06:33 PM |
Thanx Dude, way cool thread! Well done!
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 04:46 PM |
Hello again. Sorry for the delay in finishing this thread but too bad : )
Whatever amount you cut from each side of the beam has to also be removed from the steering arms.
Glen has already cut the 30mm off the end of the steering arms for me, so I just need to re thread the arm and get it ready for the clamp to go on.
Here's one of the arms cut.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 04:49 PM |
Next step is to put more thread inside the steering arm. There is still some in there seeing as there's only 30mm cut off, so starting the tap is
easy. The tap needed is a 14mm x 1.5mm thread.
I ran the tap into the arm further than the tie rod end could reach, so I know there is maximum adjustment available for wheel alignments.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 04:52 PM |
This photo shows how long the tie rod is compared to the tap I used. This now makes the previous picture make a bit more sense as you can see how far
in I tapped the thread. Does that make sense?
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 04:56 PM |
Once you've run the tap through the steering arm, there are a couple of simple things that need to be done for the clamp to go back on. Firstly you
need to cut the slot back into the steering arm, so the arm can grab the tie rod as the clamp is tightened.
The second thing to do is grind the small recess into the arm as the bolt that goes through the clamp wont fit through without the clearance this
recess gives. Simple.
You can cut the other end of the steering tube if you want, but double check for left/right handed thread before you cut.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 04:58 PM |
When it's all done it should look something like this.
The tie rod end shouldn't have to go in this far, I just wound it in that far to check that it could.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 05:00 PM |
When tapping things like this I always like to use a decent cutting compound. I have a liking for moly cut paste and/or tap magic liquid. Makes the
job a lot easier and when tapping holes with a really small diameter tap makes for a lot less broken taps.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 06:59 PM |
Glen has fitted the beam to Jack the beetle with the help of Lindsay. He had to do a little bit of tapping with the hammer on the inner guard to clear
the shock towers, but as you can see it's nothing too major. Narrowing the beam any further would result in having to recess the body to make room
for the shock towers to sit inside. Again, not a huge deal, but it's definitely easier to not have to do that.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 07:05 PM |
Well here's the beam fitted again. Seeing as this is the first beam I'd modified, I was happy to know it all fitted up properly and that my jig was
accurate in getting the mounting tabs back in the right spot.
Thanks have to go to Glen for letting me try this out on his car.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 07:09 PM |
Here's a pic of Jack before I did anything to the front end.
At this stage he has a stock beam and 2 1/2 inch drop spindles. The growth in track from fitting the spindles meant the tyres rubbed on the guards
even in a straight line.
The first thing we tried was cutting the centres out of the front wheels and altering the offset, so the rim sat further inboard. This helped a bit,
but wasn't the proper fix, hence the narrowed beam.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 07:11 PM |
Now here's Jack again with the altered front wheels and narrowed beam. A fair bit more clearance now. I love the look of a VW with a narrowed front
end, even when it's only subtle like this one. I can't wait to see Jack on the road soon, he has a lot of character.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 23rd, 2009 at 07:14 PM |
Well here's Jack again and that's about it for this thread. If there is anything I can help you with in regards to this stuff feel free to ask.
Cheers.
Tim the Dirtbag : )
Father of Sid Vicious the Volksrod.
| Error |
gsa2at
Threads: 25
Mood: busy
| posted on September 23rd, 2009 at 11:15 PM |
Thanks Tim - not only for the beam narrowing but for the excellent photo documentary of the process
Jack is happy - tomorrow we will work on getting him closer to roadworthy so he can come visit Sid
cheers mr bodgy - great job again!
psimitar
Threads: 148
| posted on September 24th, 2009 at 10:17 PM |
Excellent thread dude.
Hope you don't mind if it's a few months before I have the funds to do my beam? Really should get the pan done first
madness is in the eye of the beholder
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 29th, 2009 at 09:54 AM |
Hey psimitar, no worries. Whenever you're ready. What sort of beam was yours again? I might be able to do an exchange one with you if that's any
easier?
psimitar
Threads: 148
| posted on September 30th, 2009 at 10:00 AM |
| Quote: | Originally
posted by Dirtbag
easier?
Hiya dude, mine's a link pin beam so has the straight shox towers. Exchange works for me, just let me know what you need from me? Thanks, Mike
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 30th, 2009 at 11:01 AM |
Hi again Mike. I only have a ball joint front end here for kombi. Yours is a kombi right? Sorry, but my memory is shocking. Can you let me know
exactly what year/model yours is so I can place a wanted ad to try and get a beam to do an exchange for you? I also have a ball joint beetle beam if
you know anyone wanting one of those modified.
Cheers.
Tim.
psimitar
Threads: 148
| posted on September 30th, 2009 at 07:13 PM |
Hiya Tim, no worries. Mine's a Link pin Beetle. There's actually two link pin bug in a scrappies near me if that's any use to you.
I'll see if anyone wants a BJ beam when at Warwick this weekend
Let me know about those beams. Also how far up the coast are you from Brissy? If not that far I can always drop mine off with ya or come up and give
you a hand
Laters,
Mike
| Pages: 1 2 3 |
