[ Total Views: 2613 | Total Replies: 31 | Thread Id: 84168 ]
Author: Subject:  Notch suby project need info
Memberseagull
Threads: 752
posted on June 12th, 2010 at 06:29 PM
I can help you with a My96/97 wrx low K import motor has under manifold turbo intake
c/w full electrical harness & ecu , yellow top injectors
Note: does not have a turbo fitted , This is best fitted with a VF34 turbo
MemberKlaus
Threads: 100
Mood: Heavily modified
posted on June 14th, 2010 at 01:24 PM
I did the irs conversion when i did the subi conversion as i made a cradle setup to hold the motor /box so very strong and stable rear end , and it was orig swing axle.
and yep my 68 wagon is still forsale $6500 no rego but has nsw eng cert and very little rust , just changed out d/side sill, needs some fixing on pass side.
Actually started it for the first time in 6 months yesterday , first kick and idled smooth except for noisy lifter which cleared up after being warm.
$$ a conversion this is cheap. Most shops want 10g's for conversion alone . And i used it daily and fkn quick mmm might take it for a spin around block.
[ Queries: 40 ] [ PHP: 11.3% - SQL: 88.7% ]
