[ Total Views: 6162 | Total Replies: 52 | Thread Id: 84567 ]
Author: Subject:  Fastie Suby conversion
MemberKlaus
Threads: 100
Mood: Heavily modified
posted on August 15th, 2010 at 08:23 PM
I'm running the stock subi one just had to open up below the bumper for airflow thru it and the intercooler rad.
be quick in building it as the laws might be changing soon , better just buy mine :lol: gone up in price now to $20g's as it will be near impossible to rego one later on :lol:
MemberFastie
posted on August 15th, 2010 at 08:42 PM
Ha - nice - hold onto it, your car is gaining coin like the housing market ;)
Are they really changing the law? It's only a 2.0litre - I'm sure I'll be Ok.
Back to the shopping list. . what about the fuel pump.. I have a electric pump already, but I'm guessing I should be replacing it to something around 9psi?
MemberKlaus
Threads: 100
posted on August 16th, 2010 at 06:54 PM
just get a new vl turbo fuel pump usually about $180.00 camira are the same, ebay might have cheaper ones.
MemberFastie
posted on September 16th, 2010 at 09:56 AM
Received my WRX engine yesterday. Was told it was '97 but can't seem to find a match online for the ECU .. anyone come across a ECU info site before? Here are the numbers;
The code on the ECU is ;
B3 22611 AA600
below that is AA11-000 R69 (9427)
Have also just sorted out buying the 290mm brake package from Glenn. Looking forward to this coming together.
Memberian.mezz
Threads: 280
posted on September 16th, 2010 at 12:12 PM
check under the oil filler cap for the year,
:lol::crazy::lol::crazy::lol:
MemberKai4130
Threads: 2
posted on September 16th, 2010 at 08:21 PM
That engine looks to be the same as mine so it'll be from a pre face lifted model. I think they swapped over around 96-97 so sounds about right. Check underneath the oil filler cap or pull the cam belt covers off and look for the production markings which'll have the production year and month casted into the plastic.
Speaking from my experience (untested as of yet though) the Stock subaru radiator fitted nicely into the front of my late shape notch. A bar was welded across the width of the wheel well to provide a fixing point for the mountinf studs of the radiator. I then used Legacy/Liberty radiator top mounts to provide mountings for the top of the radiator. All looks factory.
The bar-
http://i16.photobucket.com/albums/b37/redevol/SANY2110.jpg
test fitting-
http://i16.photobucket.com/albums/b37/redevol/SANY2143.jpg
finished-
http://i16.photobucket.com/albums/b37/redevol/SANY2161.jpg
http://i16.photobucket.com/albums/b37/redevol/SANY2162.jpg
http://i16.photobucket.com/albums/b37/redevol/SANY2159.jpg
http://i16.photobucket.com/albums/b37/redevol/SANY2250.jpg
http://i16.photobucket.com/albums/b37/redevol/SANY2220.jpg
Your ECU code is B3,
Mine is Z4 a JDM WRX Impreza
http://i16.photobucket.com/albums/b37/redevol/SANY2203.jpg
MemberFastie
posted on September 18th, 2010 at 05:56 PM
Uncrated the engine today for a gander. Took rocker coves off and plugs out and all looks to be shiny with no oil sludge - happy about that, but I seem to be missing massive parts of my loom.
What's my options? I guess I have to track another loom and ECU down?
The fuse box even appears to be from a Nissan.. weird.
MemberKai4130
Threads: 2
posted on September 18th, 2010 at 06:07 PM
Well I got mine running yesterday for the first time in over a year. Wowwho
Looking at what you have pictured out of all of it you only need the ecu.
Have you got the engine harness? The wiring underneath the inlet manifold?
How about the boost control gubbins?
posted on September 18th, 2010 at 09:01 PM
thats the subi fusebox, someone has just used nissan relays in it, which would probably come out of the same Fuji factory as the subi ones
Most of the rest is your light loom
This is why i hate crate motors, wreckers just cut the wiring rather than remove it properly cos they dont give a shit
MemberFastie
posted on September 19th, 2010 at 12:36 PM
It isn't a crate motor - but the guy who pulled it bailed overseas and obviously forgot to include the engine loom - but did include kennedy adapter - bit gutted bout loom but think i've found another.
MemberJak Rizzo
Threads: 67
Mood: Pastizzi eating
posted on September 20th, 2010 at 09:29 PM
Fastie
Why did u put your hot & cold water pipes next to each other? I don't understand why u would do that?
There is masses of room under the vw floor pan to have them on either side of the car away from each other.
Jak
posted on September 20th, 2010 at 10:55 PM
by crate motor i just mean a package you get from a wreckers, engine, loom, ecu etc as opposed to buying a donor car or complete front cut
MemberFastie
posted on September 21st, 2010 at 02:23 PM
Originally posted by Jak Rizzo
Fastie
Jak
Jak - you will be looking at Kai4130 post. He was posting pics for me to reference.
I'm pretty sure he put them through the transmission tunnel to hide them.
S
MemberKai4130
Threads: 2
posted on September 21st, 2010 at 05:53 PM
I wanted a clean looking install and for ME running the pipes below the car wasn't an option. in the future if I ever remove the engine and box my charge cooler pipes will find their way into the tunnel too as I'm not happy with them running below the car neither.
Also I'm now running a cable shifter for the porsche transaxle so I didn't need to worry about the shifter rod getting in the way of the coolant pipes.
MemberJak Rizzo
Threads: 67
posted on September 22nd, 2010 at 06:39 AM
So how do u insulate the heat form the pipes inside the tunnel, from heating up the cabin? I have my fuel lines running through the tunnel & when I didn't have the front plate on the tunnel on, the hot air from the radiator would go into the tunnel & heat up the car quite drasticly. Besides that, my Engineer here in NSW said a big no to the pipes internally.
If u wanted a clean looking install, why didn't u use the Subaru factory Water to air intercooler? It took me a while to work out what that alloy box was sitting in your engine bay LOL
Jak
MemberFastie
posted on September 22nd, 2010 at 12:31 PM
I have tracked down a wiring harness for the EJ20T. Question is though - it is a Jap harness - not Aus/NZ new. I emailed RJES and Richard said the JAP harnesses are a nightmare.
Is this true - or has anyone here picked apart and wired a Jap harness successfully here?
Membermactaylor
Mood: even my dog is german
posted on September 23rd, 2010 at 05:19 AM
talk to al from am autos.
EVERLAST CONCRETE TANKS
1800 552 123
MemberKlaus
Threads: 100
posted on October 5th, 2010 at 07:55 AM
yep
Memberchris7
Threads: 15
posted on November 6th, 2010 at 07:52 PM
iam thinking of putting the same engine in my fasty..any advice would be welcome i live in victoria too.
Memberchris7
Threads: 15
posted on November 7th, 2010 at 06:19 PM
Would i be best off getting a Subaru front cut???? i would prefer to see the engine run before purchase....does anyone in Victoria Wreck Subaru's?
Memberchris7
Threads: 15
posted on November 8th, 2010 at 08:45 PM
where can i get the the suby engine to vw gearbox from and how much.......i know this has been asked before but iam new to this type of conversion..
MemberFastie
posted on April 11th, 2011 at 09:19 PM
Got the brakes sorted - now I can concentrate on power.
Also fitted the new/but old cookie cutter shoes.. happy with the way she's sitting
http://www.kitset.net/Fastback/frnt01a.jpg
http://www.kitset.net/Fastback/frnt02a.jpg
http://www.kitset.net/Fastback/disc04.jpg
http://www.kitset.net/Fastback/Ufront_qrtr.jpg
http://www.kitset.net/Fastback/Uside.jpg
http://www.kitset.net/Fastback/Urear01.jpg
http://www.kitset.net/Fastback/Urear02.jpg
MemberJak Rizzo
Threads: 67
posted on April 12th, 2011 at 08:09 AM
Very very very nice! I love Type 3's
Jak
[ Queries: 40 ] [ PHP: 13.6% - SQL: 86.4% ]
