[ Total Views: 1711 | Total Replies: 44 | Thread Id: 87712 ] |
Pages: 1 2 |
dangerous
Mood: 591
posted on December 22nd, 2010 at 12:19 PM |
Another important thing to look at,
no matter what type of front suspension you use,
is that the steering axis still coincides with the tyre contact patch.
This is more common on supers because wider wheels
with the correct offset would normally touch on the springs.
When the contact patch of the tyre is too far away
from the steering axis "projected point", it does as you describe.
Of course all the advice regarding the
correct geometry and
good condition of ALL parts is very important too.
All to often, people will say, "its all perfect",
when in actual fact there are still some worn parts,
or stuff that was "just replaced" that is actually many years/miles old.
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on December 22nd, 2010 at 12:20 PM |
...and a steering damper that is working properly
will often help cover/help thse issues.
Quote: | Originally
posted by westi
That's mad Alan.
Bizarre
Threads: 732
posted on December 22nd, 2010 at 12:28 PM |
Quote: | Originally
posted by dangerous
mmmmmmmmmm........... a R&P 1303 doesnt have a steering damper??
Bizarre
Threads: 732
posted on December 22nd, 2010 at 12:31 PM |
Quote: | Originally
posted by dangerous
Dont believe this would apply as I am running 6" rims with 40ET with thin spring struts
Tyre centre is same as before
Joel
posted on December 22nd, 2010 at 05:23 PM |
Supers only get a bad name because people just don't know how to fix shimmys and just put up with it.
It's not that hard to get rid of them, I've got topline urethane bushings in mine and havent had shimmy problems in years
The fact I can drive at 170km/h with one hand holding the camera reinforces they're safe and stable at high speeds.
With all the supers I've owned and worked on over the years I can safely say 9 times out of 10 its the rims that cause shimmys
Mine hasnt had any for years but I bet I could make it wobble worse than granny titties by bolting on the hotwires under the house.
14" rims are the worst for causing shimmys.
vw54
posted on December 22nd, 2010 at 05:46 PM |
didnt we fix this 2 days ago get more caster
waveman1500
Also rides a Honda
posted on December 22nd, 2010 at 05:52 PM |
Quote: | Originally
posted by Joel
But I love my 14" rims! Backyard built by some unknown person in the '70s as well. They definitely can't be the issue!
forry2000
Threads: 77
Mood: aircooled
posted on January 7th, 2011 at 12:43 PM |
as previously said put a beam in the front and you will never have any problems.
and Barls - the word 'tosser' is probably not appropriate to get your point across no matter how disillusioned you may be.
Joel
posted on January 7th, 2011 at 01:08 PM |
A fixable highspeed track issue or a tractor ride quality......hmmmmm
think I'll go buy a link pin bug
Damn Barry look what you started
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on January 7th, 2011 at 01:18 PM |
Quote: | Originally
posted by Joel
The ride in my Baja is fine!!
Especially when ploughing through fields
Smiley
Joel
posted on January 7th, 2011 at 01:33 PM |
Sweet, I've got an 18foot disc ripper here you can go drag round around the paddock for me
Im sure the VW crank pulley would spin the PTO shaft
vw54
posted on January 7th, 2011 at 04:10 PM |
especially as we know a strut front end will get BO gg ED
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 7th, 2011 at 04:27 PM |
Quote: | Originally
posted by vw54
What, like this ?!!!
Error |
Smiley
Threads: 110
Mood: Synchro'd
posted on January 7th, 2011 at 04:36 PM |
Quote: | Originally
posted by Joel
The little Baja with her 1300 would do it!
She can tow Kombis, and Daewoos and the odd Commodore!
Smiley
Bizarre
Threads: 732
posted on September 25th, 2011 at 05:47 PM |
OK - all good
I move slowly these days
A rear wheel alignment and new offset torsion bar bushing for caster
Pages: 1 2 |
