[ Total Views: 1434 | Total Replies: 46 | Thread Id: 89589 ]
Author: Subject:  More Carby Questions 31PICt-3 - No idle
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on April 10th, 2011 at 12:33 PM
Does the hole in the butterfly plate have to be blocked the same as a 34PICT-3???
It never needed to be on my 1300, but at this point I'm willing to try anything.
Smiley :cool:
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on April 10th, 2011 at 01:01 PM
Ok. Here's all the info.
Engine is a 1600 Twinport AD case.
Valves have been checked and are set to .006"
Plugs are new gapped to 0.028"
Leads are new.
Coil is a red GT40
Distributor is a stock 009.
Running electronic ignition.
Timing is set to 10° at idle and 32° at full advance.
Carby is a 31PICT-3 with
Main - 135
Idle - 55
Power Correction - 60
Air Correction - 110Z
Choke is not operational so I've set it to stay open.
Fuel cutoff solenoid is connected and working correctly, have checked with the engine off and while running.
Have triple checked the manifold and carby for vacuum leaks, there are none.
Engine starts and runs, but only if you hold the throttle. Otherwise it just stalls. Acts like the cutoff solenoid is not functioning, just stalls out.
Can ANYONE suggest anything else that it could be before I burn it to the ground??
Smiley :grind:
posted on April 10th, 2011 at 01:09 PM
Silly question but are you dead sure it's fuel?
could be weak spark, especially with a GT40 door stop.
I've had one do the same thing, I swore it was a carb problem, rough/no idle but swapped the GT40 for aother coil bam problem gone.
got another coil to try?
posted on April 10th, 2011 at 01:24 PM
[size=4]Hi
sounds like the idle jet is blocked...
or can be the coil as Joel suggested..
are You sure the idle electromagnetic cutoff valve is actually NOT stuck closed..???
PS: check the High tension lead to the coil.... silicone ones can break VERY easily.....
try a VW wire HT lead in to check if You are getting all the spark... wire leads don't break..
[/size]
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on April 10th, 2011 at 03:06 PM
Tried a different coil. No difference to problem.
[size=4]Hi
[/size]
Cutoff solenoid is operating as it should, I'm sure.
All the leads are brand new, I bought them this morning.
Any more brain busters?
The only other thing that I can think of is the electronic ignition. About to throw the points back in it and try.
Smiley :cool:
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on April 10th, 2011 at 03:09 PM
Why are these no good?
It's not one of the crappy round ones.
It's one of these
http://i933.photobucket.com/albums/ad172/smileyman1968/Alyce%20the%20Baja/P1040111.jpg
Smiley :cool:
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on April 10th, 2011 at 03:35 PM
Points made no difference. :grind::grind:
Smiley :grind:
posted on April 10th, 2011 at 03:45 PM
Smiley :cool:
[size=4]No...
I don't think that would fix this problem..
You haven't put any OLD fuel into Your tank???
Fuel doesn't last long these days before going off...
and causing problems..
have You tried adjusting the timing??
LEE written at 2pm..[/size]
question.gif posted on April 10th, 2011 at 04:03 PM
It's one of these
the points should be GB534 ?
The round coils are oil filled for cooling....
GT40 s have a lower resistance than the other Bosch coils..
round ones.. nothing wrong with the round ones either,,,
IMHO..
I Hope You find the problem...
did you clean the points before using them with petrol or alcohol etc.. they do have a protective coating on them.
Condensor OK... they should be replaced every year or so...
You have the coil connected the correct way... many people
who have owned VWs for many years still get them mixed up at times.. I always check 3 times.... lol
I bought a beetle a few years ago that stopped at every intersection.. [foot off pedal]
I took it home and tuned it up..
and no problems after that...
its probably something easy?? once You find it...
PS: sometimes New parts aren't as good as the old parts..
the old parts have been tested and DO work... lol
Smiley :cool:
posted on April 10th, 2011 at 06:00 PM
GT40 coils just seem to have high fail rate, I;ve had 2 die on me, a couple of freinds the same and just the cases I;ve read on forums.
Overall consensus seems to be the solid state ones you bought at the worst but give it try, I always had a spare coil under the back seat in my bugs.
I would be checking the resistance of it though, most electronic ignitions are very fussy on what the resistance is, 99% of VW kits are designed for 3ohm coils.
Also as Lee mentioned 529 points are designed for the late twin port dissys with the shorty cap (73-76).
the early ones and all 009s use 534 points.
MemberBRUTUS
A.k.a.: et tu, Brute
Threads: 17
Mood: ACE 30 FOR SALE!
posted on April 10th, 2011 at 09:03 PM
Smiley,
I had a 1600 bug with a 34PICT-4 that had similar symptoms. It all worked/checked out well, except it would NOT idle. I cleaned it out, dismantled everything, etc., but still the same. The idle mix screw and the bypass screw were not doing anything. Then I got Really Annoyed and with the engine running fast (well above idle), removed the idle MIXTURE SCREW, then revved it hard while squirting carb cleaner (using spray can with small plastic tube) in the hole. Then put back MIX SCREW; then removed the (large) bypass screw, with the engine running, then squirted in cleaner as before. It fixed it. (Didn't remove the idle JET, but that might have been next.) There was obviously a blockage that couldn't be got at or seen... Take care...
ACE 30 & 40 oils: specifically engineered for your Air Cooled VW
delivered (free del.) throughout Yarra Valley / Ranges, & Gippsland areas. Also ACE 20, 50 & 90.
FOR SALE: ACE 30, 40 etc. Oil formulations & Trade-names.
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on April 12th, 2011 at 07:07 PM
Smiley :cool:
[size=4]No...
I drive the car everyday, if the fuel has gone of in 3 days I'd be worried!!
Smiley :cool:
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on April 12th, 2011 at 07:11 PM
That's just an old picture, the only one I have of the coil, back when I had a vac dizzy, that's what the points are for.
I did try a different coil, and it made no difference at all.
If the GT40 coils are no good what SHOULD I be running? Cause I will just go and buy one.
Was thinking of getting a Pentronix set of electronic points and matching coil. Is this a worthwhile investment?
Smiley :cool:
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on April 12th, 2011 at 07:15 PM
Originally posted by BRUTUS
Smiley,
I had a 1600 bug with a 34PICT-4 that had similar symptoms. It all worked/checked out well, except it would NOT idle. I cleaned it out, dismantled everything, etc., but still the same. The idle mix screw and the bypass screw were not doing anything. Then I got Really Annoyed and with the engine running fast (above idle), removed the idle jet, then revved it hard while squirting carb cleaner (using spray can with small plastic tube) in the hole. Then put back jet; then removed the (large) bypass screw, with the engine running, then squirted in cleaner as before. It fixed it. (Didn't remove the idle mix screw, but that might have been next.) There was obviously a blockage that couldn't be got or seen... Take care...
I will try this next chance I get.
Will it run if I pull the jets out?
Smiley :cool:
info.gif posted on April 12th, 2011 at 07:53 PM
Smiley :cool:
i BELIEVE THE PERTRONIX IS Great and well worth the money..
You will need a HIGH Resistance coil...
which is really just a standard coil..
[to fit what????} I just got people [on ebay] to measure the resistance in Ohms of the coils they had for sale...
The answer will be approximate unless they have a really good multimeter...
so a 3 ohm coil May measure 2 ohms or 4 ohms ???
but many measure BELOW 1 ohm.... which isn't good for Pertronix.. or some other ignition systems..
PS: Good to know what You were doing with those points etc...
posted on April 12th, 2011 at 08:34 PM
Smiley :cool:
It seems to be luck of the draw with GT40 coils, with all the failures I mentioned there are the exceptions, dads has been on for 10 years now, bought the same time as mine in 2001.
his is still going, mine died in 2005
Although died isnt the right word as it still operated but was doing what you are experiencing.
Would make it run ok at revs but would barely idle roughly or not at all.
Had me puzzled why it ran fine at revs especially under load though which is why I didnt suspect a dud coil it at first.
The other I had die on me was in my Celica, it would cut out when it got hot then would restart after 15 mins of cooling down, run for a bit......rinse and repeat.
As to what to run, piece of string type question.
people rave about Bosch blue for VWs, never used one myself
If pertronix make their coils as good as their electronic ignitions I'd be going for it.
I've had a couple of Hanshin coils which came on bugs I've owned which I suspect were probably OEM coils off jap cars which worked well.
MemberBRUTUS
Threads: 17
posted on April 12th, 2011 at 11:41 PM
Sorry Smiley, mixed up the Mixture Screw and the Idle Jet. Have corrected text (in capitals) in original post. The problem was apparently behind one of the 2 screws. I don't think I removed the jet, but it was a long time ago, so not sure. I kept the revs up (may have propped open the throttle lever; and removed screws quickly, spray can at the ready... revved it hard when spraying in. It made plenty of fumes.
[ Queries: 40 ] [ PHP: 3.0% - SQL: 97.0% ]
