| [ Total Views: 9334 | Total Replies: 112 | Thread Id: 91223 ] |
| Pages: 1 2 3 4 |
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on August 8th, 2011 at 05:14 PM |
Didn't go to portland sorry and that pic just looks like Macca mopping up some more oil hahahahaha
whathaveidone
Threads: 98
Mood: Heading for 10.99
| posted on August 8th, 2011 at 05:29 PM |
| Quote: | Originally
posted by LIFE IN THE LOW LANE
LOL, or is he trying to light it up with the battery pack???
| posted on August 8th, 2011 at 07:01 PM |
Recharging the energy polariser he got from Brocky waay back then....
LOWBUG
Threads: 33
Mood: OUT OF CONTROL
| posted on August 8th, 2011 at 08:48 PM |
Are you guys making changes or freshening up the bottom end as well. Oh and by the way thats some pretty big comp your boasting, is that what your
calcs are coming up with, or is that what you'd like, hate to damage those heads $$$$$$$$$. If the combo works its gonna be nasty.
westi
what the
Threads: 28
Mood: not blue, pink
| posted on August 9th, 2011 at 12:23 AM |
16 to 1 is the aim ,but proberly wont get it,gota have a dream though.
as for the bottom end it will proberly get a freshen up depends on time,and money.
my arse still hurts from buying the heads and rockers.no point doing things buy halfs.
as for the red face dave ,we'll see old man.
i have finished the heads for now so off to the flow bench they go to see if these yanky figures are as they say they are.
i will post up some pic's as i take em.
down sharon.
STOCK
Threads: 12
Mood: OK
| posted on August 9th, 2011 at 11:05 PM |
as brad said heads have been machined
i think he is flowing them tomorrow
will let you know the figures once brads done them
here are some pics anyway
STOCK
westi
what the
Threads: 28
| posted on August 9th, 2011 at 11:47 PM |
done
down sharon.
westi
what the
Threads: 28
| posted on August 10th, 2011 at 12:29 AM |
195@10''
15.5mm lift so far without manifold's.
they come to life when they get to about 9mm lift.
good for of the shelf .i have already cut the manifolds in half to see what the transfer from manifold to port is like.
it will definatly need some work but it is only minor.
i will try to get the manifolds back together over the next few day's so i can test the heads with the manifolds and throttles,hopefully find some
more cfm there.
i don't know what the heads do straight of the shelf as i did do a few little things in the chamber,but i don't think it would be far of what they
come as.
nice pic's fatman,u got the dt's or something.
don't forget your clothes tommorrow fatty.
down sharon.
dangerous
Mood: 591
| posted on August 12th, 2011 at 05:28 AM |
Good numbers, which flow bench?
Make sure the spark plug does not hit the piston.
16:1 will probably need .400 deep notches!
Hope your pistons are thick enough...and top ring is far enough away.
| Quote: | Originally
posted by westi
That's mad Alan.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on August 12th, 2011 at 06:16 AM |
Warwick is looking really good this year.
Nice work as always Westi
westi
what the
Threads: 28
| posted on August 12th, 2011 at 09:15 AM |
i started on the fma bench.but it was running out of puff for the last few reading's.
i wanted to start the new head on the same bench before getting them on the new one so i had some idea of the difference in cfm.
i should, if i can find the time. put it on the new bench on the weekend.fingers crossed.
i spent last night making a valve spring removing tool.
down sharon.
dangerous
Mood: 591
| posted on August 13th, 2011 at 05:28 AM |
Surecam on the mid north coast has the equipment,
but you wont get it back in time for Warwick.
I am guessing that Crow Cams has the simulation gear also.
Any good cam people should have it.
Be interesting to see the difference between the two benches,
dont get too excited till you run them on the other bench.
Mine flowed more with the manif and thrott.
Those figures closely match mine at 10".
(179 to 184@.550 to 600" @10" with manifold and throttles).
I use one of these and an angle plate to R&R the springs,
and check for travel and bind:
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
| posted on August 13th, 2011 at 09:09 AM |
nah i am not realy worried about the total cfm with that bench just wanted to compare the 2 heads to see if there was much of a change.
once i finish the jig to hold it,i quess i will see the difference.i can't really test the old head any more they have been put aside for a rainy
day.
but at least i can now see the difference betweeen the 2 benches.
my spring remover ain't that good.bit's of steel and shit welded together.it il do.
pull ed the motor apart last night so hopefully i will get some new bearings today and slap it back together tonight.
question for you dave.
head studs were and when.and what friggin invention did you com up with to do em up.
down sharon.
dangerous
Mood: 591
| posted on August 13th, 2011 at 11:30 AM |
Head studs were just 10mm Autocraft, and VW 8mm for the extras.
My other engine uses VW 10mm on all studs.
Ranging from the 36hp and up to 1600, there are just about any length you might need.
You can tension them to 35lbs no probs.
You will most likely need 12 point nuts though,
and make up a special ring spanner to use with your torque wrench
for tightening the hard to reach ones.
| Quote: | Originally
posted by westi
That's mad Alan.
STOCK
Threads: 12
Mood: OK
| posted on August 14th, 2011 at 11:03 PM |
hey guys a few more updates:
*heads are machined (still to be ported though)
*so friday night we thought we better pull out the motor so we can
rebuild the bottom end so its finished , then we can mock up
to flycut the pistons , then concentrate on porting making
manifolds etc etc
case pulled apart all cleaned (ready for assembly)
welcome to westside's engine building room(we believe in a controlled sterile environment  )
after we paid for the new heads budgets tight (cant afford feeler gauges) so we check cam end float the westside way
duh were did that peice go again
crank rods etc all back together in our purpose built facility
ready to go back into case
case halves about to go back together, we'll cut the pistons tomorrow
we should have barrells tuesday, we'll machine them (bottom end done ) then back to the heads and manifolds
more updates soon guys see ya
STOCK
whathaveidone
Threads: 98
| posted on August 15th, 2011 at 07:17 PM |
so what cost more???? The engine build or the Maccas coke?????
ian.mezz
Threads: 280
| posted on August 15th, 2011 at 09:00 PM |
I think the cokes used for cleaning parts
venFun10
Threads: 0
| posted on August 16th, 2011 at 11:11 AM |
coming along nicely mate
you sure love to leave a lot of work last minute
how light is your car? looks light
nbturbo
Threads: 89
Theme: UltimaBB Powder
| posted on August 17th, 2011 at 08:37 PM |
| Quote: | what friggin
Brad-this is what I came up with to do mine head stud nuts up.Welded an old 3/8" drive socket to a 7/16 ringy, exactly 6 inches from the centre of
the ring.I use an inch pound tension wrench set at 170 which gave me 35 foot pounds.I tested it on a bolt and nut in the vice,using my 1/2" drive
tension wrench,and they both did the nut to the same tension.
| Error |
westi
what the
Threads: 28
| posted on August 17th, 2011 at 10:28 PM |
the car was 1410 last time it was weighed ,but it will be heavier now,new wheelie bars heads and od's and sod's.
i will take the weight back out when i stick some front cage legs in it.
yeh thats what i am talking about,nbturbo good idea.
haven't touch the car this week.
i pulled the bottm end back apart to get the cam and crank re-balanced.flywheel machined and get the cam checked stability wise.
hopefully get all my shit back early next week so i can put it all together again.
down sharon.
venFun10
Threads: 0
| posted on August 18th, 2011 at 08:55 AM |
nice
good luck
Stanley
Threads: 270
| posted on September 4th, 2011 at 07:46 PM |
hey westi....unlike you to be so quite a month out from warwick....wtf is going on
1303Steve
| posted on September 5th, 2011 at 11:09 AM |
I been working a late shift, I saw Westise car and a few other cars at the shop very late on Saturday & Sunday night, must be really burning the
candle.
westi
what the
Threads: 28
| posted on September 8th, 2011 at 01:37 AM |
as per usuall leave everything to the last minute .
i have been getting everyone esles cars together for jambo and test and tunes and all that shit,so poor old junka gets rushed once again.
i have ,when i get a chance to work on it been playing around with cam timing and deck hieghts and all that jazz in order to keep the comp up around
16 ish to 1.
finally think i got it ,but i am runnig out of time.
ordered the bigger fuel pump and injector's tonight.
did my last check's for piston to valve,i had heaps of old shit layin around to machine up and test in the engine,so i am pretty happy with the
finished product.now i just need to get some new pistions,hopefully get them tommoorrow and do a machine fest over the weekend an get it all back
together buy monday ,then all i have to do is make extractors inlet manifolds fuel rails a few fuel lines,brakes master upgrade as i haven't had
brakes for awhile now.and i might need them if all goes to plan.
if i don't have the car up to puting engine in on monday i think i will have to pull afew more allnighters to get it done,but what else is new.
down sharon.
vassy66T1
A.k.a.: Marcus Vass
| posted on September 8th, 2011 at 10:59 PM |
I like your commitment Westi!
Looking forward to seeing you at Warwick.
westi
what the
Threads: 28
| posted on September 10th, 2011 at 01:49 AM |
question for dave,
i have 4mm piston thickness at the radius of the piston of the recess,it is 4mm thick for about 10mm of the radius.the rest around 5mm +.
what do you recon?
yeh marcuss i look forward to catching up and havin abit of fun .
down sharon.
dangerous
Mood: 591
| posted on September 10th, 2011 at 05:08 AM |
I have gone as thin as 3.5mm no probs...no N2O though.
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
| posted on September 10th, 2011 at 08:21 AM |
cheers dave
yeh that was what i was thinking ,no nos bummer
i will get the fat man to take some pic's before we start putting the engine back together for hopefully the last and final time.
down sharon.
westi
what the
Threads: 28
| posted on September 10th, 2011 at 07:41 PM |
dave got any 283mm long pushrods layin around.
down sharon.
dangerous
Mood: 591
| posted on September 10th, 2011 at 08:15 PM |
nothing thick in that length, only 277 or 293,
or new berg that can make up to 305....what spring load at full lift?
| Quote: | Originally
posted by westi
That's mad Alan.
| Pages: 1 2 3 4 |
