[ Total Views: 6303 | Total Replies: 134 | Thread Id: 91614 ]
 Pages:  1  2  3  4  5
Author: Subject:  what engine did you purchase / build
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on July 18th, 2011 at 06:55 PM
So I assume a stroker engine is really more for racing or drag racing rather than for a daily?
NO, truck loads are used as daily drivers.
MemberSebastienPeek
Threads: 89
posted on July 18th, 2011 at 07:11 PM
Yes, but the major downfall of stroked engines are the fact that tinware and other bits have to be chopped away, right?
The sold one, '73 VW 1303 - Zelda
The project, '74 VW 1303 - Gretl
MemberPaulc1964au
posted on July 18th, 2011 at 07:39 PM
thanks guys i am learning a great deal so looks like a stroker is the way to go?
So are CBb, Pobjoy motors strokers?
MemberCraig Torrens
Threads: 347
posted on July 18th, 2011 at 07:53 PM
Both can build longer stroke or "stroker" motors.:tu:
MemberPaulc1964au
posted on July 18th, 2011 at 08:14 PM
ok cool so what would be the spec of a typical stroker motor and can what size would i be able to run without heating issues etc
posted on July 18th, 2011 at 09:38 PM
Any size can be built, just the bigger they get the more effort goes into building them. There are many different combinations that give improved performance, the final size can depend on many variables and there as many differing opinions out there as there are engine builders.
Memberzayus
A.k.a.: Bryce
Threads: 26
posted on July 19th, 2011 at 12:33 AM
Hi Paul,
Here is a very simple description, that I can understand! :)
Pistons are attached to the crank.
The crank turns and the pistons move from side to side.
The stroke, is the distance the piston travels.
A stroker crank, increases the distance that the piston travels.
The increased stoke allows the engine to breathe in a greater amount of air and fuel.
More air & fuel means more power.
The advantage of the stroker crank, is that engine can consume a greater amount of air & fuel turn @ a slower RPM, EG: good for a daily driver.
A simple comparison is, an adult running alongside a child.
The adult is the stroker crank, the child is the standard crank.
Both run 50 metres.
The adult covers the distance in less steps, than the child, because their stride (stoke) is longer than the childs stride.
Paul, I can't build an engine, but I try to have a simple understanding of how hot-rodding an engine works :)
Oh yeah, simple diagrams help too... they will be in tomorrow's lesson!
Memberdonn
Threads: 428
Mood: LAID BACK AND CONFUSED
posted on July 19th, 2011 at 08:54 AM
Both run 50 metres.
Cool, but this adult runs outa puff quicker than the kid. :lol::rolleyes:
MemberPaulc1964au
posted on July 19th, 2011 at 09:05 AM
thanks guys this is a very helpful thread for all us novices
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 09:13 AM
I'm with you Paul,
This thread is definitely full of information for everyone, not just novices :)
MemberPaulc1964au
posted on July 19th, 2011 at 11:47 AM
So would a 1916 stroker be the way to go? and then what cam, carbs , exhaust would you all recommend
MemberPaulc1964au
posted on July 19th, 2011 at 12:11 PM
oh with a budget of $6K without labour could I get a decent motor for that price?
MemberPumba
Threads: 255
posted on July 19th, 2011 at 01:22 PM
My new project will be running a stock 36hp,so who wants a race:lol:
69 Beetle
66 Beetle
56 Beetle
Membervassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on July 19th, 2011 at 02:12 PM
A 1916cc is the standard 69mm stroke with 94mm pistons.
A stroker motor (longer stroke crank) is larger than 69mm, usually from 72mm upwards.
For everyday practicality the key is to get the performance without running the compression up high or using a bigger cam.
It is all in the combo. Find someone that has a good combo and find out what has gone into it. You can spend a lot of money in parts that don't really gel into a good package for an engine.
That would suck.
As I am sure I have said plenty of times the combo in my 2165cc is absolutely excellent. In a beetle you could go up in the cam to an engle 120 and still be happy I feel.
The 6K will be okay for parts but the assembly and machining would need to be an additional.
MemberPaulc1964au
posted on July 19th, 2011 at 02:26 PM
thanks Marcus that is great information. I want an engine that will idle fine and not too loud but when you put your foot down will have enough low down power to have some fun (within the speed limit of course) I will also be driving the wife around on weekends so cant have something too loud lol
MemberPaulc1964au
posted on July 19th, 2011 at 04:48 PM
What spec should i be building????
Membervvwbeetle
Threads: 63
Mood: Upsetting bikes on the Old Road
posted on July 19th, 2011 at 05:16 PM
Hi Paul
More than happy to take you for a run in my car!
Now I have it. I need places to go and people to drive around with.
I am putting the car in storage for a few weeks while I get a new kitchen built.(I need the room in my garage to store items and I don't want dust getting on it or anything banging into it.)
So when I get it back more than happy to take you for a spin. Just let me know. Simon.
MemberPaulc1964au
posted on July 19th, 2011 at 05:32 PM
thanks for the offer and I can take some photos for you if you like
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on July 19th, 2011 at 05:41 PM
I've just purchased a 2054 from Rod Penrose.
It's 94 bore and 74 stroke.
I was told that 74 is the largest stroke you can go to before the case starts to need clearancing.
Has a very mild Scat C20 cam (basically stock)
Will be going into my daily driver Baja, with a pair of Kadrons. I do at least 600km a week.
It's not going to be a super fast engine but it has around 108hp at the flywheel which is twice what I have at the moment. Will be very torquey and a nice daily driver engine.
With any luck I'll have it installed in a few weeks and I can let you know what it's like.
Smiley :)
MemberPaulc1964au
posted on July 19th, 2011 at 07:21 PM
Cool smiley am interested to see how you go i saw that engine down at Rods last week.
Oh rod is currently building me an engine check the thread to see updates :)
Ultimate VW Engine
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 07:42 PM
I wish Rod was just down the road from my place.
Let's just say that is definitely where all my money would be going!
Memberbeetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on July 19th, 2011 at 09:48 PM
Hey Seb, you are closer to Rod than Smiley is - he is in Yeppoon in Queensland. Have a look on a map. :-)
From your ole' mate Jeff
MemberSmiley
Threads: 110
Mood: Synchro'd
posted on July 19th, 2011 at 11:03 PM
It looks real pretty. I can't wait to drive it :love:
It's not that far! Barely 2 days drive!
Smiley :)
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 11:08 PM
Ah, I am going to contact Stan about getting myself a mean 1916cc twin port, we'll see what happens!
I'd be up for a two day drive in Zelda any time though, something I would do in a heartbeat :)
Memberbeetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
posted on July 19th, 2011 at 11:30 PM
If you do, try and time it so you can go to the Sawtell winter break or Valla - they are both just down the road from Stan's.
Also, if you do, let us know - I would love to catch up with you - Stan is only about 2 hrs from my place.
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 11:47 PM
Will do Jeff!
It's definitely a long drive, will put the current engine to her death bed I reckon.
But, it'll be worth it!
MemberPaulc1964au
posted on July 20th, 2011 at 07:21 AM
Let us know what he says and approx costs
MemberSebastienPeek
Threads: 89
posted on July 20th, 2011 at 07:56 AM
Will do Paul,
I've got to figure out exactly what I want first though.
Seems the best way to achieve what I want is probably to have the same budget as yours.
It won't be a stroker, as there is no point. 69mm crank and that is the largest it'll go.
Basically, to make it a stable daily driver, but with enough up and go to scare the pants off of people at the lights.
MemberPaulc1964au
posted on July 20th, 2011 at 08:59 AM
Will do Paul,
I think we are after the same specs be interesting what Stan suggests
MemberSebastienPeek
Threads: 89
posted on July 20th, 2011 at 09:01 AM
Will definitely be interesting what Stan says,
would love to see the comparison between Stan and Rod.
Doubt it'll be very much, but even still...
I'm surprised I haven't seen any Gene Berg engines on here, anyone got one?
 Pages:  1  2  3  4  5
[ Queries: 40 ] [ PHP: 19.9% - SQL: 80.1% ]
