[ Total Views: 2731 | Total Replies: 41 | Thread Id: 98582 ]
Author: Subject:  Exhaust pipe problem
MemberBlue65
A.k.a.: Yau
Threads: 93
Mood: Retrospective
posted on February 11th, 2013 at 03:35 PM
Would it still scrap though if you went in on an angle?
I saw these two examples.
But it looks like they might scrap badly if I drove in at an angle.
______________________
Owner of a 1964 VW Beetle, 1641cc engine, etc..
Membersander288
"Bolt-on Master"
Threads: 183
posted on February 11th, 2013 at 07:30 PM
That top pic isn't typical of the hideaway headers; they normally end under the rear apron. I think I may of read that thread of the blue car and it is a thing header and modified muffler.
http://i1183.photobucket.com/albums/x463/sander19671988/photo-1-1.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/photo-2.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/163793.jpg
and heres one on my car
http://i1183.photobucket.com/albums/x463/sander19671988/GOPR0026800x600.jpg
and here is the GT one
http://i1183.photobucket.com/albums/x463/sander19671988/407067_2636185432558_281159640_n.jpg
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
MemberBlue65
A.k.a.: Yau
Threads: 93
Mood: Retrospective
posted on February 12th, 2013 at 01:32 AM
That last one looks good. Not sure about the others - because they seem quite likely to come to serious grief on my driveway.
any more photos of the GT one? And more info on where to get it?
Membersander288
"Bolt-on Master"
Threads: 183
posted on February 12th, 2013 at 08:20 AM
these are from bizarre
http://i35.photobucket.com/albums/d170/blue74l/Marty/101_1206.jpg
http://i35.photobucket.com/albums/d170/blue74l/exhaust/100_2220.jpg
from memory he had it on a mild 1916cc
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersander288
"Bolt-on Master"
Threads: 183
posted on February 12th, 2013 at 08:23 AM
You can get these systems from classic veedub
https://www.classicveedub.com.au/cvd_new/part_detail.aspx?parts_id=16612
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Memberbevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
posted on February 12th, 2013 at 11:25 AM
Air Shocks ???? With a compressor on board, pump it up when you need to, let it down after? Just a thought.
Country Buggy King & Link Pin Overhauls, Type 1 & 2 King Pins, General Machining.
http://forums.aussieveedubbers.com/viewtopic.php?tid=74138
My car is KO813
posted on February 12th, 2013 at 04:19 PM
Originally posted by Blue65
I thought I should post some photos of my muffler and driveway to give you a better idea of whats the problem.
YIKES
maybe really BIG wheels or bigger tyres like 225s etc..
NOT low profile..
or a normal beetle towbar which goes from the torsion bar tubes to the back to the bumper brackets...
made from round pipe..
although they may stop the fitment of any extractor exhaust system...??
standard muffler with straight thru pipes..
I ran one with straight thru pipes about 1 5/8" ID
about 30-35mm id.. it was VERY loud though...
I remember back in the 60s and 70s where many beetle standard muffler pipes were worn thru at the bottom from steep driveways...
Your driveway is very nasty... going Up or Down...??
PS: I don't think driving in backwards would make any difference either.. lol LEE
probably a one off exhaust with the muffler up in the wheel arch may be the answer.. $$$ LEE
these are very low and will protect anything... lol
Memberempi
A.k.a.: Empstar
Mood: thunderous
posted on February 13th, 2013 at 08:26 AM
Get a vintage speed lowrider exhaust
posted on February 13th, 2013 at 08:39 AM
What is the cars front and rear stance? Often the rear is sagged and the front high which makes the overhanging engine/exhaust drag worse than if the front is lower than the rear.
Vintage Speed are great for clearance and longevety.
Membermodnrod
Threads: 50
Mood: Old School Volksies!
posted on February 13th, 2013 at 08:53 PM
Those pipes in the pic above apparently are restrictive (me? I dunno, but the Euro's on Cal Look think so).
These ones look the same outside, but apparently flow about as good as a 4-1.......
http://vwparts.aircooled.net/Tri-Mil-Hotdog-Muffler-VW-Beetle-and-Ghia-p/tri-...
.....but that might scrape too.
When I was a teen, so sometime when Adam was eating peaches on his front porch, my aunt's beetle did the same thing in Darlington WA (bloody steep hills and driveways). My uncle and I had the simple remedy of cutting away the valance between the rear guards and putting the muffler sideways up under the engine hatch.
You might find that a bit extreme, so have you considered the "old-school" 4-1, something like this..........
http://vwparts.aircooled.net/VW-Sedan-Bus-Street-Header-1966-73-1300-1600cc-p...
.....and then use 2 hotdogs (one is bloody loud, two isn't too bad!), a bit like this........
http://vwparts.aircooled.net/Dual-Quiet-Pack-Mufflers-for-2008-2008-11-2011-p...
.....but get your own made up.
These systems tuck right up under the rear guards and valance, with the outlets each side not in the middle, and should give you plenty of room.
Membersander288
"Bolt-on Master"
Threads: 183
posted on February 14th, 2013 at 10:12 AM
Some more ideas; whatever you get though basically if the stock muffler scrapes then most other exhausts out there will too.
IMHO I would go with either the 2-tip GT or the vintage speed. The EMPI mild steel version of the GT system is restrictive but this stainless version has about 30-31mm ID pipes so it flows alot better; where as the EMPI version has the stock tailpipe ID of about 20mm.
http://i1183.photobucket.com/albums/x463/sander19671988/s01.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/oldtimer-53442306004961709.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/oldtimer-53442306004961702.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/oldtimer-53442306004961701.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/mqdefault.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/kaefer-motor-059-9152748570342579106.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/003.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/1wei03.jpg
http://i1183.photobucket.com/albums/x463/sander19671988/JBExhaust.jpg
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
MemberBlue65
A.k.a.: Yau
Threads: 93
Mood: Retrospective
posted on February 18th, 2016 at 04:54 PM
My mechanic installed a camber compensator to fix the rear wheels being wrecked.
It also fixed my ramp scrapping problem.
But now I got issues going around corners.
I wished they had a hydraulic system for this.
Originally posted by tar76
I think any type exhaust will scrape there, man that's steep.
Sometimes if I angle it right, my exhaust don't touch the ground. Right now, its slightly brushing against the ground. What I don't want is for it to gorge holes. Once I used a quiet muffler flanged where the exhaust came out in the middle - and that proved impossible to drive up the garage without some damage.
I thought maybe the GT Exhaust system might be a good option.
http://www.vollks.com.au/store/GT-STYLE-2-Tip-Exhaust-System.html
[ Queries: 40 ] [ PHP: 3.0% - SQL: 97.0% ]
