[ Total Views: 164368 | Total Replies: 155 | Thread Id: 41005 ]
 Pages:  1  2  3  4  5  6
Author: Subject: Ovals progress
MemberFlintstones
Threads: 69
posted on September 10th, 2005 at 07:17 AM
I'd say that they will be fairly important as this is what will keep the rail in place whilst your driving around, as well as vibration.
The last thing you want is for the rail to move and dislodge your roof panel and for it to rattle and leak.
With the speaker in the top corner, you will find that it will drive you crazy (as well as giving you a headache) as you won't be able to have a decent staging of your stereo.
The higher frequency will overpower all your other speakers almost making them useless.
Hope I haven't ruined your thoughts.....
Membernbturbo
Threads: 89
Theme: UltimaBB Powder
posted on September 10th, 2005 at 10:39 AM
No-always on the lookout for info from someone who has tried it B4.I will still fit the brackets B4 the headlining goes in-but will do a dummy test with them up there B4 I cut the headlining.Thanks for that.
Membernbturbo
Threads: 89
posted on September 25th, 2005 at 05:42 PM
Got it back with another headlining fitted-got a good job done this time-- and have fitted all the sunroof seals and it's in and working.After I adjusted everything,it was sliding pretty easy with just a small feeling of drag in the guides,so I put some cardboard between the guides and the headlining and sprayed a small amount of silicone spray into the guides,wow,does it glide home easy now.If anybody is playing with one of these and is having any issues with adjustments,contact me and I can help out,have got on top of it now.nn[ Edited on 25-9-2005 by nbturbo ]nn[ Edited on 25-9-2005by nbturbo ]
MemberFlintstones
Threads: 69
posted on September 25th, 2005 at 10:48 PM
Looks Sweet NB
Membernbturbo
Threads: 89
posted on October 12th, 2005 at 06:20 PM
At last-just picked up my pan after it went in on 8th August for a blast and paint.It was ready last Friday,but it looked like it had been painted by a blind bastard,so had it done again.Can get into action again.Picked up some front buckets last week from a Mitsubishi Starion, so won't have to wreck mine now.Will strip them down and get them covered in black leather as well as the back seat.Have ordered the leather with the perforations for the centres and normal stuff on the edges-same as my NB.Looks like this weekend will be for swapping over the front and rear suspensions from the original pan.
Membernbturbo
Threads: 89
posted on October 14th, 2005 at 03:43 PM
Swapped the front beam over. Got a new Master Cylinder and made up new steel pipes and reservoir lines-need to keep the brake stuff on the other pan.Pulled out all the bolts I screwed into holes B4 blasting and run a tap thru them all with some some thread compound.Stripped down my Country Buggy front beam and took it in yesterday for blast and paint.Will put it back onto the other pan when done.
[ Edited on 14-10-2005 by nbturbo ]
MemberTurbo54
Mood: Boost'n
posted on October 14th, 2005 at 04:25 PM
Pan looks sweet! Are you coming down on the 30th?
T54
C'mon kids gather round,
posted on October 14th, 2005 at 04:29 PM
great work on the frame horns. with a lick of paint they almost look factory. :thumb
Membernbturbo
Threads: 89
posted on October 14th, 2005 at 08:21 PM
Yes,I will be down.The only day each year where I know exactly where I will be.
Membernbturbo
Threads: 89
posted on October 17th, 2005 at 09:09 PM
Just finished my 2 rear trims-made new cards and spacers to get the speakers away from the body.Will fit some dynamat B4 they go in.Used some chrome outside trims from a late Bug-cut them to length and made up some metal threads to attach them.Used some VDO speakers,but paimted the covers grey to match.
[ Edited on 17-10-2005 by nbturbo ]
Membermscabrio
Cabriolet Queen
Threads: 142
posted on October 18th, 2005 at 07:21 AM
Can't wait to see this finished, it is looking great! Shame you couldn't have used the instruments and steering wheel from a NB, that would have looked wicked! When you finish, are you going to buy the oval window inserts for your NB ??????
:punk:
Membernbturbo
Threads: 89
posted on October 18th, 2005 at 09:51 AM
Yes- thought about the steering wheel.Spotted one at Autopro the other day-looked a like the NB one.And no-like the NB just the way it is.
Membervwtyp2
Mood: over it
posted on October 18th, 2005 at 07:25 PM
hey Gary, where did you get the passenger side sun visor from?
I'm after just the arm without the visor to mount a Tacho on.
Membernbturbo
Threads: 89
posted on October 18th, 2005 at 10:08 PM
Vintage Parts California.It's their passenger mounting bracket.I drilled out the rivets and turned the rod over and fitted some new rivets,so it can then go on our passenger side.Made up a small aluminium plate the same shape with the 3 screw holes which goes on first.I got it with a whole heap of stuff-someone here may sell them.I think it was about $8 US.You could probably make something similar out of some 3mm aluminium.
Membernbturbo
Threads: 89
posted on November 15th, 2005 at 09:14 PM
Not much progress of late-still waiting for the doors,front and rear lids and the 4 guards to be finished.They are all painted,but have some minor blemishes,so he is redoing them-but starting to wonder which century.Drew this logo up and had a signwriter do a heap for me in yellow and blue.Think it represents what an early one looks like using the NB style logo.
MemberFossil
A.k.a.: Bert Wright
posted on November 22nd, 2005 at 05:32 PM
Sweet :smirk:
IGOR is ALIVE !!!! :cool:
Membernbturbo
Threads: 89
posted on December 5th, 2005 at 08:57 PM
Well at last the rest of my bits are finally finished.Got a call this morning to come and pick up the doors and front and rear lids.The guards only need to be polished and should be done by the weekend.Got both lids on tonight and adjusted and all gaps are good.Fitted some of the badges as well.
[ Edited on 5-12-2005 by nbturbo ]
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on December 5th, 2005 at 09:13 PM
nice mate im going up to play with mine and ill get some pics how the whole heater set up is done cause i remember you asked a while ago
the chaos project - click me
Membernbturbo
Threads: 89
posted on December 5th, 2005 at 09:46 PM
Thanks-keen to check it out.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on December 5th, 2005 at 10:10 PM
Great stuff Gary - looking absolutely fantastic! Its such a nice feeling reinstalling all the new/renewed components onto a freshly painted body!
Membernbturbo
Threads: 89
posted on December 6th, 2005 at 10:36 AM
That's for sure-had forgotten what it felt like.I know one thing for sure-next one I do-I will be doing the body work as well.With this one I thought to save heaps of time,I would have someone else do the body while I did all the mechanical stuff.Well I have done the motor,the pan,all the suspension and stuff,and then did another pan and modified it for the auto,and still finished long B4 the body was done and still run a business to pay for it all.Any way will get into it now and enjoy the refit of everything.
Member063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
posted on December 6th, 2005 at 02:03 PM
Looks really good..... keep up the hard work
MemberAnirok
Threads: 7
Mood: I don't wanna play no more
posted on December 6th, 2005 at 02:12 PM
WOW!!!
looking great!!!
:smilegrin:
http://forums.aussieveedubbers.com/banner/avdbanner27.gif
Membernbturbo
Threads: 89
posted on December 6th, 2005 at 04:47 PM
Nearly ready to drop the body onto the pan-but had to cut a trap door under the back seat to clear the front of the auto and give access to the front band adjuster.If I turn this panel thru 180 degrees it fits back perfectly-need to weld some sides to it with a flange all around,then can make it removeable.
MemberWABaja
A.k.a.: Daniel
Call ME when you need a TOW
Threads: 40
Mood: Grumpy in the morning and moody at night
posted on December 6th, 2005 at 05:49 PM
You're doing a Beautiful job on this car... I've got a lot of respect for someone that puts that much work in...
Whilst I'm not a huge fan of late model panels on an early bug, but I can appreciate the look you're going for and the effort you're putting in...
First time I've seen this thread, but I'll be watching with a smile from now on...
Keep up the good work, really lovely looking car... Well done..
:thumb:thumb:thumb
MemberY2K
A.k.a.: Maya
Threads: 14
Mood: APRed
posted on December 6th, 2005 at 08:08 PM
lookin fab Gary...cant wait to see it turn out
2000 New Beetle White (SOLD)
2004 NB Turbo Black, APR (SOLD)
2007 Passat Black shaggin wagon
1955 Beetle white VWOVAL
1956 Kombi, rusty n lichen
Memberfoxy_fuchsia
Threads: 110
posted on December 9th, 2005 at 12:56 AM
love it, very schmick!!
Membernbturbo
Threads: 89
posted on December 20th, 2005 at 11:10 AM
Got another instalment of bits last night-both back guards and 1 front-get other guard and mirror heads tonight.Couldn't resist-had to bolt them on.
Membermscabrio
Cabriolet Queen
Threads: 142
posted on December 21st, 2005 at 05:13 PM
One things for sure noone can say that you have no imagination ........ it's coming together really well now, looking forward to seeing the final project.
You have combined my two favorite bug details ...... oval window and elephant foot taillights !
:punk:
Membernbturbo
Threads: 89
posted on December 21st, 2005 at 10:00 PM
Thanks-I'm a bit like that as well,and I have used the clear ones with the small coloured covers over the globes.I'm also a bit partial to the 4 slot engine cover too(but like the W lids the most).I have a W lid with vents in it that came on the Oval.I might see if I can get a set of clear lights for the back of the NB as well.
 Pages:  1  2  3  4  5  6
[ Queries: 40 ] [ PHP: 17.7% - SQL: 82.3% ]
