[ Total Views: 6336 | Total Replies: 78 | Thread Id: 71235 ]
 Pages:  1  2  3
Author: Subject:  FK87 Experiences ?
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on November 8th, 2009 at 09:42 AM
Awesome result :tu:
Membercoletrickle
Threads: 34
posted on November 16th, 2009 at 07:02 PM
Nice!So are you happy with the fk87?I'm real happy with my 2332 done over 7000miles now.Raced at the nostalgias,j19,and warrick and a couple of street meets and some after hours testing.I've been fiddling with the tune ever since and prior to last friday i was totally happy with how it drove slow or fast it would pull from 33ish mph in top(700mm trucktyres).After running 98 octane since 0 miles i've now swapped over to 91 octane and CANNOT BELIVE THE DIFFRENCE!!I thought it was smooth before now it will pull from 27ish mph in top it has a lot more power on partial throttle and with full throttle it revs out so much harder and faster and doesn't seem to nose over near 6600.Can't wait to get to the track it feels so much faster than before when it ran 13.17@101.2mph,60ft of 1.77.Maybe a 12 second street car christmas thats what i'm wishing for!
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on November 16th, 2009 at 07:55 PM
interesting findings there Col.......you mean better with 91 octane?
what brand fuel you been using.....same or irregular companies?
Membercoletrickle
Threads: 34
posted on November 16th, 2009 at 08:54 PM
Either caltex premium or shell v power.tried 95 ethanol blend ran a tiny bit better but shit milage and ran a bit hotter according to the hand-o-mometer.Have tried 7-11 91 octane and now bp both unreal compared to the 98 premium.On partial throttle its like its a 5 cyl engine and the progression is so smooth i havn't changed a thing except the fuel still running 30 degrees timing no pinking no running on even today after driving in peak hour traffic and it was hot had to be at least 34degrees gave it a real good seeing to and it just screamed thru the gears no problems.So yes 91 octane fuel in my 9.8-1 2332 =:crazy:power who wooda thunk it.Got me thinking in a diffrent direction now,gonna get the a/f meter tomorrow and see what its doing.
posted on November 16th, 2009 at 10:32 PM
Col, here is the dyno pull of your engine with air fuel being around 12.4 and peak lean at 13.5. Typically the dyno operator only really gets it happening 4000 rpm upwards.
This was with 98 and 32* total. You know the jetting.
Member55slug
Threads: 22
Theme: UltimaBB Psyche Red
posted on November 17th, 2009 at 04:57 AM
FK87 is really nice, now I have a better tune in it, I think the 88 crank helps a lot down low in smoothing the powerband a bit. In the last week I have changed a couple of things, found loose inlet manifold nut on cylinder #3 (it was leaning out) and changed the wiring to fuel pump after noticing an audible drop in tone when the lights were on ... my dodgy wiring... and added a bypass oil filter holder (jaycee). At least now I can get repeatable results on the wideband.
Engine will be out next week, and onto the dyno next weekend. Have a lot of stuff to try out to get the max out of it ! Its good to have a mate who works for an engine builder !!
Member55slug
Threads: 22
posted on November 21st, 2009 at 05:35 PM
Quick update...Ran 1.75 sixty foots last night, best time was 12.78@168 ks. More seat time required to get used to the launch side of things and get some consistency in it,
MemberCraig Torrens
Threads: 347
posted on November 22nd, 2009 at 10:20 AM
Good time and 60ft.....I thought 140hp would have given a higher terminal speed though.
posted on November 22nd, 2009 at 10:49 AM
Craig, you have to allow for the overall weight, that includes the driver.:lol::lol::lol:
Memberdangerous
Mood: 591
posted on November 22nd, 2009 at 12:13 PM
I think it ran 104mph in matt's car,
and Cole was using his "witches Brew" that week end too,
so I doubt it was making 140 on that day.
Originally posted by westi
That's mad Alan.
Membercoletrickle
Threads: 34
posted on November 25th, 2009 at 09:42 PM
Yes it should go a bit faster than 101 mph,like dave said i was running some special fuel that day that didn't help and my car is so not lowered so i'm calling very bad aerodynamics for some of the "loss" westie has promised a set of dropped spindles so we'll see if that helps.
posted on November 25th, 2009 at 09:55 PM
Ooooh dropped spindles Col, about time, you wont regret it. Soon you might be all one colour:lol:.
Are you adding kero to your 91 yet??
Member55slug
Threads: 22
posted on November 30th, 2009 at 07:17 AM
Spent time on an Engine Dyno on the weekend (drgouk's place of work). Made 196 Hp and 178 ft/lb, with belt and muffler on. Started at 187 Hp so we made some good gains.
Have been chasing a valve lash problem with the #1 exhaust, found that the pushrod was eating the lifter cup... so Im stripping it down now... Im confident it will make over 200 hp with the valve train set up properly.
Interestingly we found more horspower with 42mm vents than the 44s that I had in originally...
I am running a steel billet cam - any suggestions as to lifters ? I was looking at the CB lightweight jobbies ?
posted on November 30th, 2009 at 08:24 AM
Recently been using the light Scat with no problems (and removed two engines worth for inspection too)
Memberdangerous
Mood: 591
posted on November 30th, 2009 at 11:32 AM
I used the old black mahle lifters with my steel billet cam, but they are heavy.
The advantage though,
is that Autocraft make a hardened steel lifter cup that slides into the mahle lifter.
That's mad Alan.
Member55slug
Threads: 22
posted on January 14th, 2010 at 12:44 PM
Dave, I have lost about .080" in one lifter in the cup area. I have some of the Autocraft cups on the way. Just wondering wether these may be a fix for my existing lifters ? Only one has this issue...
Memberdangerous
Mood: 591
posted on January 14th, 2010 at 02:46 PM
These should do the trick if they fit inside your particular lifter brand.
That's mad Alan.
Member55slug
Threads: 22
posted on January 30th, 2010 at 07:04 AM
Thanks for the tip on these they worked out perfectly. Cheapest fix ever at only $60 Us !
http://www.nzveedubnuts.com/files/dscf0061_114.jpg
http://www.nzveedubnuts.com/files/dscf0062_950.jpg
Member55slug
Threads: 22
posted on March 26th, 2010 at 09:12 PM
Got back to the strip tonight, ran a 12.501 off the trailer, only made three runs but got to a 12.437 @ 170 ks. Shifting at about 6500. 60 foots in 1.654, 1.658. Im really happy with it. It was cooling down so probably a 12.3 in it yet. I have an oiling issue to sort out, idiot light coming on when backing off over the line... I was running the level at the bottom of the dipstick, and have changed a few things, so need to work that out...
 Pages:  1  2  3
[ Queries: 40 ] [ PHP: 16.3% - SQL: 83.7% ]
