[ Total Views: 4160 | Total Replies: 61 | Thread Id: 81124 ]
 Pages:  1  2  3
Author: Subject:  WSID , THIS FRIDAY 8th Jan
Memberdangerous
Mood: 591
posted on January 18th, 2010 at 04:04 PM
http://badgerphoto1.badgerphotography.com.au/2010/FTF%20100109/index.htm
Originally posted by westi
That's mad Alan.
Memberfish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on January 18th, 2010 at 06:23 PM
The Autocraft pattern head stud location that Rod uses, and as do my engines,
is almost identical to the VW Wasser Boxer stud pattern,
and the distance between adjacent cylinders is the same as stock type 1 and Wasser.
People have used the Deutz cylinders on type one aftermarket engines,(pauter,scat, autocraft, arpm and autolinea and converted wasser),
but pobably the largest size you would ever want to go would be 103mm or so.(case bored to about 107mm, head 110 to 111)
If you wanted to use a very long rod, and just sit the barrel on a very shallow step at the case you could fit as large as 105mm,
but that is just greedy on a type 1, he he.
yeah Dave, that would be very greedy on a type 1, I'm thinking of messing around with a type 4 eg. 86 x 101.6 - 107, the Deutz are so long they would need a bit of machining.
a lot depends on the combo regarding forced or n/a, I have two sets of heads opened up to 105mm which brings me to the question of using the hemi heads for turbo, has anyone done this with good results?
 Pages:  1  2  3
[ Queries: 40 ] [ PHP: 11.8% - SQL: 88.2% ]
