| [ Total Views: 112843 | Total Replies: 107 | Thread Id: 91646 ] |
| Pages: 1 2 3 4 |
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
| posted on August 25th, 2011 at 08:45 PM |
ROCKERS
Here are the Pauter billet 1.5 ratio rockers . These are mounted as a pair with 3 mounting points per cylinder for added strength . The total lift
will be around 650-660 thou at the valve
| Error |
| Error |
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
RodPenrose
Threads: 330
| posted on August 25th, 2011 at 08:50 PM |
VALVE COVERS
This is a look at the inside of the valve covers and the base of the inlet manifold . Both of these have a groove similar to the sump and top cover
for an o'ring . This is a far better way to seal two machined surfaces as compared to a paper gasket .
| Error |
| Error |
| Error |
RodPenrose
Threads: 330
| posted on August 25th, 2011 at 08:53 PM |
INLET MAINFOLDS
Here you can see the match ported IDA intake manifolds with the nitrous nozzles installed . These are a custom made stainless steel anular nozzle that
will spray the gas directly at the intake valve .
| Error |
| Error |
| Error |
RodPenrose
Threads: 330
| posted on August 25th, 2011 at 08:57 PM |
ROCKER GEOMETRY
Here you can see the rockers assembled on the heads . The rocker assemblies are mounted using 3 x 3/8 bolts per cylinder . The rockers are a roller
tip deal and will connect with the hardened valve tips and therefore will not require the use of lash caps . Upon my request , I have had every 2nd
valve adjuster drilled hollow to allow more oil to splash around inside the valve cover . This may change on the # 3 and # 4 cylinder valve cover as
the vacuum pump will be mounted to this cover and may pull too much oil from the engine .
| Error |
| Error |
RodPenrose
Threads: 330
| posted on August 26th, 2011 at 09:07 PM |
ALMOST SEALED UP
Here are a few pics of the engine on the stand . Here you can get an idea of of what the finished engine will look like . I have also included a few
pics of some of the sensors , cylinder head temp and boost pressure . The flywheel is set up for either a dual or triple disc system .
| Error |
| Error |
| Error |
RodPenrose
Threads: 330
| posted on August 26th, 2011 at 09:09 PM |
| Error |
| Error |
| Error |
motha
Threads: 16
| posted on August 26th, 2011 at 09:37 PM |
Jeez!!!
This is one serious bit of gear Rod.
Can't wait to hear how it goes!!!
How far off is this from making its first pass?
Thanks again for the chat today too.
Unfortunately, the other bug I mentioned about also fell through. So will keep my eye out for a mid-late 50's bug.
My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
RodPenrose
Threads: 330
| posted on November 13th, 2011 at 10:55 AM |
FINISHED
The engine assembly is finished and I am now installing and fitting all of the external accessories . The 2nd pic shows the racing alternator mounted
above the # 2 cyl and the Vacuum pump above the # 4 cyl is in the 3rd pic . The crank pulleys will be sent away to be anodised and the tirgger wheel
for the crank sensor is yet to be mounted , ROD.
| Error |
| Error |
| Error |
BugsyMalone
Threads: 8
Theme: UltimaBB Powder
Mood: Beer time yet????
| posted on November 13th, 2011 at 12:09 PM |
Speechless
Love to hear the thing purrr, I reckon if you drove past some girls with that they would magically lose their clothes and end up in the beetle
RodPenrose
Threads: 330
| posted on November 13th, 2011 at 05:41 PM |
The first pic is the completed nitrous oxide set-up . I have 1 x nitrous and 1 x fuel solinoid per side with the jets being mounted at the nozzle .
In the 2nd pic is how I have mounted the mercury coils to the inside of the intake runners . I have 4 coils with really short leads .
In the last pic you can see how I have mounted the fuel lines from the fuel rail . These lines go to the injectors and keep the top of the engine
clear for conrod bearing inspection without removing the engine from the car , ROD.
| Error |
| Error |
| Error |
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on November 13th, 2011 at 05:52 PM |
nice how it's all so well planned Rod.......loadsa thought and experience
NOS bottle warmer/blanket i hope
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on November 13th, 2011 at 06:07 PM |
Wow!!
That looks amazing.
Neat work on taming the snakes (hoses)
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
| posted on December 24th, 2011 at 01:51 PM |
Hey Rod, How is this going. Have you startedd it yet?
bevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
| posted on December 25th, 2011 at 10:14 PM |
Wish I could see the pictures.
DylanTheDubber
Threads: 173
| posted on December 26th, 2011 at 05:20 PM |
WooooooW Rod! How much are these Things worth?
If i gave you $15k would you build me one?
From Dylan
matberry
| posted on December 26th, 2011 at 05:32 PM |
| Quote: | Originally
posted by DylanTheDubber
From Dylan
Plus parts
RodPenrose
Threads: 330
| posted on December 27th, 2011 at 08:01 AM |
Dylan , here is a break down on the costs ;
new unassembled engine $ 26000
Motec E-888 , M-800 , dash $ 9800
Gt 51r custom turbo by garrett $ 4400
Assorted motec/racepac sensors $ 4700
XRP hose and assorted fittings $ 3800
modified bosch injectors $ 2400
Turbosmart dual wastegates $ 910
Turbosmart blow off valve $ 440
Turbosmart E-Boost 2 $ 700
Turbosmart FPR 1200 $ 550
HPC tc1 exhaust coating $ free
Edelbrock throttle body $ 480
Enderlie DSR fuel pump $ 600
Assorted sizes of tube for intake , exhaust , brackets and machine engine plates , approx $ 1500
Cost of labour to fabricate all necessary brackets , assemble oil and fuel lines , weld intake and exhaust and assemble the engine ? , ROD.
Craig S
A.k.a.: Craig
Threads: 83
Mood: In the mood for change
| posted on December 27th, 2011 at 08:06 AM |
WOW!! That's a lotta monies!!!
Probably about what I expected though given what has gone into this.
Looking forward to the day when I can see this fly down the quarter in anger.
1969 Beetle - June
1974 L Bug - Gwendolyn
2002 Bora V6 4Motion - Anita
STIDUB
Over it.
Threads: 57
| posted on December 27th, 2011 at 09:35 AM |
is it passion or insanity when you keep track of the $$$ suddenly my
build isnt so bad
Volkswagen Drivers Club of Queensland - member
matberry
| posted on December 27th, 2011 at 09:48 AM |
Prices like that you don't forget.
Not to mention the 'incedentals'.
Thanks for sharing Rod, think of paying ALL labour too.
Sides
A.k.a.: Dave Sidery
| posted on December 27th, 2011 at 12:29 PM |
Yeah, keeping track of the individual prices is passion... EVER adding them up into a single number... THAT would be insanity I reckon !!!
My toys
vassy66T1
A.k.a.: Marcus Vass
| posted on December 27th, 2011 at 03:57 PM |
Honesty appreciated Rod. Can't wait to hear and see it.
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
| posted on December 27th, 2011 at 06:03 PM |
Just. Freaking. Awesome.
Thanks Rod, I appreciate the sharing as I will never own anything like this !!!!! As much as I would like to .
Love the o ring seals everywhere I don't think you will have too much trouble keeping the boost inside the engine where it is meant to be !!!!
RodPenrose
Threads: 330
| posted on December 29th, 2011 at 07:08 PM |
CLUTCH
I am now ready to set the clutch up and install the engine into my new drag car . The flywheel is a custom aluminium deal with an L&T pressure
plate and either a dual or tripple disc set-up . To start with I will be using the 8" dual disc set-up and I have attached some comparison pic's
against the std VW units , ROD.
| Error |
| Error |
| Error |
RodPenrose
Threads: 330
| posted on December 29th, 2011 at 07:13 PM |
Before I start with the clutch I have to install the rear main seal and rear engine plate . The seal is much larger that the original VW seal and to
keep this seal in place and to stop it from either blowing out or getting sucked in , I have machined up a seal holder that will house the seal that
will be mounted to the inside of the engine plate , ROD.
| Error |
| Error |
| Error |
RodPenrose
Threads: 330
| posted on December 29th, 2011 at 07:15 PM |
More pic's of seal .
| Error |
| Error |
| Error |
RodPenrose
Threads: 330
| posted on December 29th, 2011 at 07:25 PM |
In the first pic you can see the flywheel mounted , in the 2nd pic is the installation of the 6 x clutch stands the 2 clutch plates and the floater
plate . In the last pis is the complete clutch assembly . The clutch has 6 x adjustable stands to set the ring height , as well as 6 x individual
springs to set up the static pressure . You will also notice that there is a small bolt and nut mounted at the base of each of the 6 fingers that are
used to attach extra weight to in order to make the clutch hit harder at the higher rpm's . The more weight added to the fingers the harder the
clutch will clamp the plates . I do not fully understand how it all works at the moment , but this is the most complex part of the entire car and is
the secret to actually finding the fine line between clutch slip and wheel spin , ROD.
| Error |
| Error |
| Error |
Flintstones
Threads: 69
| posted on December 29th, 2011 at 08:31 PM |
The build is looking great Rod.
When I used to have my worked V8 Commodore, I used to run a centreforce clutch arrangement and it had weights in between the fingers which moved with
centrifugal force.
So as the RPM's increase the weights would move outwards and thus adding further clamping force onto the clutch.
This clutch gave me a very light pedal and I was able to use my car as a daily.
Might be a similar situation here...
How many sensor's are monitoring the motor, cause there are a few in the last pic.
D
RodPenrose
Threads: 330
| posted on December 30th, 2011 at 07:10 AM |
SENSORS
D , I have the following Motec and racepac sensors mounted on the engine for data aquisition only , these will not tune or change the engine tune in
any way ;
GT 101 on the crank for RPM's
Motec Cam sync sensor
4 x Exhaust temps
1 inlet air temp before the intercooler
1 inlet air temp after the intercooler
fuel temp
oil temp
oil pressure
fuel pressure
cylinder head temp on each head
barrel temp on each barrel
throttle position
Nitrous fuel pressure
Nitrous bottle pressure
vacuum/pressure for the block { case }
turbo speed
exhaust pressure
Lambda from turbo exhaust
boost pressure
water temp { intercooler water }
I will also have a fuel flow sensor mounted , however I cant seem to find any thing that is suitable yet . Then there are a shit load more on the new
car that will monitor the drive line , suspension and chassis , ROD.
RodPenrose
Threads: 330
| posted on January 1st, 2012 at 09:42 AM |
Done , and installed , ROD.
| Error |
| Error |
| Error |
| Pages: 1 2 3 4 |
