| [ Total Views: 164372 | Total Replies: 155 | Thread Id: 41005 ] |
| Pages: 1 2 3 4 5 6 |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on December 21st, 2005 at 10:06 PM |
Whoo-hoo!! Awesome stuff!
nbturbo
Threads: 89
Theme: UltimaBB Powder
| posted on December 26th, 2005 at 09:47 PM |
Got the front ones as well.Need to make a spreader bar now so I can lift it all onto the pan.
| Error |
mscabrio
Cabriolet Queen
Threads: 142
| posted on January 2nd, 2006 at 07:14 PM |
| Quote: | Originally
posted by nbturbo
.I might see if I can get a set of clear lights for the back of the NB as well.
I have got clear tail lights and changed the rear fog light to a clear reverse light on my Cabrio and it looks a lot cleaner
nbturbo
Threads: 89
| posted on January 3rd, 2006 at 10:20 AM |
No-I didn't need it to be auto,but thought that almost everything else had been tried on a Beetle except this-so why not.My NB is auto and it's a
dream to drive,so the Oval should be the same.It should have plenty of power,so stop light sprints should be fun.
nbturbo
Threads: 89
| posted on January 3rd, 2006 at 10:24 AM |
mscabrio-did you ever post any pics of the back of yours?I don't think I have seen any on an NB.Have seen plenty on the XR Ford utes and they look
good-will have to get a set for that as well-bloody cars-they try their best to keep you poor.
[ Edited on 3-1-2006 by nbturbo ]
blutopless2
DAMSLO
Threads: 187
| posted on January 3rd, 2006 at 01:56 PM |
here is a pic of the rear.
| Error |
see.... air and water do mix
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
nbturbo
Threads: 89
| posted on January 3rd, 2006 at 05:00 PM |
Nice.In that pic,it looks like you have changed your exhaust.
nbturbo
Threads: 89
| posted on January 11th, 2006 at 09:15 PM |
Had a day off today and put the body back on the pan.Had a few minor things to tidy up first,then lifted it with one felt sling thru the door
openings.Made a small block of wood for each side and covered them with carpet to keep the sling off the headlining and stop it crushing the metal
strip that holds the lining.With all the mods to the pan for the auto,I managed to have the motor sitting about 15mm too low at the back-easy enough
to fix-just have to modify the bell housing mounts to compensate.It all fits that well,it looks like it came from the factory.
| Error |
| Error |
| Error |
nbturbo
Threads: 89
| posted on January 11th, 2006 at 09:16 PM |
1 more
| Error |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on January 11th, 2006 at 09:55 PM |
Very tasty indeed - I love it!!
vw54
| posted on January 12th, 2006 at 06:56 AM |
Gary
The cars looking great is it nearly ready for regristration
Have you thought about widening the bumpers by about 3 or 4 inches or so to match the guards. You have to do this from the center and moove the
mount holes as well.
It would look trick but a bit of stuffing around but after all its only money
pete wood
| posted on January 12th, 2006 at 09:12 AM |
Excellent stuff. Can't wait to see it all finished. I'm particularly looking forward to hearing about how the auto goes. You might start a trend of
some sort.
nbturbo
Threads: 89
| posted on January 12th, 2006 at 10:26 AM |
Thanks Fellas- I'm keen to give it a hiding.I cut and shut a couple of front bumpers to see what it looked like, B4 I had these rechromed.Looked odd
to me-too wide and too thin.
vw54
| posted on January 12th, 2006 at 11:14 AM |
We did some a few years ago.... makes the car look F A T T E R
maybe just the blades on ther own would look better when wider
But its yr choice.
nbturbo
Threads: 89
| posted on January 12th, 2006 at 03:20 PM |
Took some of the auto in position and thru the hole in the back seat area-and my guide pegs still in position for locating the body in the right place
when I lowered it onto the pan.Can also see the rear bars I made up to stiffen up the frame horns.When I am happy with it all,will send all the bars
and brackets away to be cad plated.
| Error |
| Error |
| Error |
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on January 12th, 2006 at 03:31 PM |
looks better every-time i look keep up the good work mate
Flintstones
Threads: 69
| posted on January 12th, 2006 at 07:53 PM |
Looking Superb NB!!
nbturbo
Threads: 89
| posted on January 13th, 2006 at 09:10 AM |
Dino-whats the go with yours-any progress??
nbturbo
Threads: 89
| posted on January 23rd, 2006 at 10:08 AM |
Got a couple of hours in last night-been too hot to even go into the shed for the last week.Back on it's wheels now,but think I need to lift it a
spline at the back-just a little too low.I have all the VW tools to align the back wheels,so will give it a go after I get it sitting at the correct
height.Finally finished the auto dipstick tube.Took ages to decide where to actually put it.I bought it into the engine on the LH side.Had to lengthen
it 100mm so it could just come into the engine bay.Had to shorten a dip stick from an auto Kombi and scribe the level marks-all turned out OK.The
hardest bit was making sure the tube didn't hit against the body under hard acceleration-made this bracket with a rubber panel to allow for some
flex.To prevent any trans fluid being blown into the engine bay under pressure,I have made the dip stick an air tight seal inside the tube,and will
weld an 8mm breather pipe high up on the outer tube,and fit a filter and drain tube to vent behind the LH back wheel.Got the hand brake working as
well-had to make some extension tubes to go over the original tubes coming from the pan.I had to reposition these during the mods,so didn't know how
long to leave them-I was 85mm too short.
| Error |
| Error |
Alex Holzl
A.k.a.: Big Al
2332cc of pure BALLZ!!
Threads: 85
| posted on January 23rd, 2006 at 10:30 AM |
VERY VERY VERY NICE! makes me wanna pull my car apart and start again!
Great work!
alex
nbturbo
Threads: 89
| posted on January 27th, 2006 at 12:48 PM |
Adjusted and aligned all the steering system.Screwed all the fuel fittings into the tank and fitted it.Found a grinding feeling in the steering at the
straight ahead postion-searched for ages and couldn't find the cause.Had the tank out again and saw a very small scratch mark in the new paint-just
where the column would be.I had fitted a centre shaft from a later Beetle and it was just catching.Moved everything further into the car by about 20mm
and it's all OK now.
| Error |
| Error |
| Error |
nbturbo
Threads: 89
| posted on February 26th, 2006 at 05:25 AM |
Got it registered last week so I could enter it in a car show here as a daily driver.Have got it and my "64 on Seasonal registration,they can be done
for 3 months at a time without having to pay for a reinstatement fee.Still haven't got the doors back together yet.Had 3 of my VW's and my ute in
the 'Family group" catagory.Don't know how I went-they were so late doing trophies-had to get all the cars home,so didn't hang around.
[img]
[/img]
Flintstones
Threads: 69
| posted on February 27th, 2006 at 09:33 PM |
Great stuff NB.
So how she drive with the T4 and the auto?
Craig Paton
Threads: 68
Mood: Absolutely Gratefull..!
| posted on February 28th, 2006 at 06:57 PM |
That looks great!
Jus love that exhaust...!!!!!!!!!!!!!!!!:thumb
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on February 28th, 2006 at 07:35 PM |
Absolutely shuperb! Great work! :bounce
nbturbo
Threads: 89
| posted on June 18th, 2006 at 10:36 PM |
Thought I would give an update-It's almost there.Got the auto and motor back in,finished all the wiring,made a switch for the auto's
kickdown,drilled and tapped the 4 intake manifolds for a vacuum source for the auto etc.Just finished swapping the CV joints onto the auto axles and
have fitted one side(had enough for today) Lifted the rear suspension up about 30mm,was a bit too low and couldn't get rid of the excessive negative
camber at the lower setting-all looks good now.Auto gear changer is in and all adjusted and hooked the small selector indicator lights into the dash
light system.Only need to bleed the brakes and fill the auto and I can start it and make it move.Still waiting for my doors to come back from the
painter-will phone tomorrow to hurry them up.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on June 18th, 2006 at 10:59 PM |
C'mon Gary - we need some more pics mate!
vw54
| posted on June 19th, 2006 at 07:07 AM |
Looking great so its up to the Test drive stages ??
pete wood
| posted on June 19th, 2006 at 09:59 AM |
WOW! :thumb
063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
| posted on June 19th, 2006 at 02:59 PM |
nice job... keep the pictures coming. Love the idea of the drains running directly into the wheel well.... very clever  |
