[ Total Views: 195731 | Total Replies: 511 | Thread Id: 55220 ]
 Pages:  1  2  3  4  5  6  ..  18
Author: Subject:  VOLLKOMMEN ART's junka build up(10.44 @ 131.39)
Membercrewcabconnection
Being Sid James
Threads: 293
posted on September 2nd, 2006 at 10:46 PM
you lot are all nutbags.
Loves a lolcat
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on September 2nd, 2006 at 11:25 PM
Yeah its great isn't it?????
FUCH your early!
http://www.noh2o.org/
MemberAdolph
Threads: 6
Mood: Fast
posted on September 4th, 2006 at 11:54 PM
Originally posted by fullnoise
Great work. I'm glad I stumbled upon your post.
I found it hilarious that after you displayed your impressive fabrication skills with the front end that some punter pointed out that the nitrous bottle may not fit under the bonnet. Like that will be a problem!
CYA CT
Hi fullnoise.
I am the punter that you are talking about. I am sorry if you did not understand my post, I am sure that boostn was not offended by what I wrote.
I wrote it because I could see that the bottle was put there for the picture. I am sure that he also knew that the bonnet would not close with the bottle in that position and I am sure that, with the fabrication skills that boostn has, it would not be a problem.
I have also remarked on the good ideas that boostn has shown and on his skills as a fabricator.
Great work boostn
Hermann
2000cc turbo type 4, dragster (325Kw)
2714cc no turbo, no gas, street bug (140Kw)
MemberBoostn
Threads: 28
posted on September 5th, 2006 at 12:40 PM
CYA CT
Hi fullnoise.
Great work boostn
Hermann
Hey guys,
It's all good no stress, lets not start anything. Sometimes it does not come out right when typed out.
I'm having fun slapping this thing together and it makes it better sharing it with you guys and hearing the suggestions and comments.
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
MemberTurbo54
Mood: Boost'n
posted on September 5th, 2006 at 01:46 PM
Hey Boostn,
I have a set of street eliminators w/ 44x37.5 valves and autocraft 1:25 rockers. i haven't had them flowed but they have had some work done on them by Melbourne Vw Performance? before I bought them. My ports look straight though like your just not as big as the valves aren't like yours.
I have a GT2871R and hoping to run up to 18-20psi but do you think my heads will be able to flow this? I understand its all about breathing and I know I can force the air in there but will I be able to get it out with 37.5's? Do these heads get really hot on the street?
Keep up the good work!
T54
C'mon kids gather round,
MemberTurbo54
Mood: Boost'n
posted on September 5th, 2006 at 01:50 PM
OH I forgot, When you step up to bigger port sizes it raises the rev range (Comp Eliminators) does this happen with bigger valve sizes? I would think so but never tested it. I dont really want to rev the crap out of my car was hoping to top off at around 6000 and try to keep it together. Ever used a Haletch E6X... what do you think?
Thanks again,
T54
MemberBoostn
Threads: 28
posted on September 6th, 2006 at 01:55 AM
OK Heath,
You are correct in saying an engine is just a pump. the more it flows the more power it makes. One of the most important thing is efficiency.An efficient engine will make power and survive. For starters you always build an engine to suit the head, not the other way around.You need to know what your heads flow, so you can know what cam to choose,rockers,rods,springs and even crank to use. There is no point in having heads that flow well @650'' and using a cam that has a .400'' and 230 @ 50 duration. All you are doing is creating a boggy pig for no reason because that port has the flow moved up the scale. It would drive nicer, have better economy and make better power with a smaller head. Bigger is not always better. Valve size also changes the head characteristics. Sometimes if you are not happy with the intake Vs exhaust ratio, you can correct it through cam grind or even rocker ratio.
Boost psi is only a way of measuring air at the manifold. Power is about volume not psi. You can get what ever boost you want that is not the problem, but what does that mean when the engine is not moving it? When your engine starts moving more volume at less boost you need to go for a bigger turbo to cope with the volume.
For example, a rotary needs a massive turbo because the engines move so much air. If you could put same amount of volume of air though a VW engine it would probably equate to something like 80 psi, the fact is that the rotary can move the air and only register 25 psi at the manifold.( just an example). Each turbo has it's own chart on efficiency and what it's designed for.
Basically Heath flow your heads with the manifolds, select a cam, rods, and springs and find out what size roller you have.
The comps don't run hot on the street my heads run much cooler than stock heads.
Dave would be a good person to talk to about heads.
Hellcraps are a good computer but you need to do a fair bit of tuning.
VOLLKOMMEN ART
Speed and Style
Member58bbugger
Mood: busted
posted on September 7th, 2006 at 12:33 PM
I thourght you just add boost and go.
MemberBoostn
Threads: 28
posted on September 9th, 2006 at 02:38 PM
2233 engine is in
Finally I got the engine in.
Although the engine and turbo kit were ready, I still had to mess around making brackets and things. Now for the wiring.
VOLLKOMMEN ART
Speed and Style
Memberhumpty
Threads: 139
posted on September 9th, 2006 at 03:02 PM
Hey Nick.... Noticed you put a bit of effort into keeping the exhaust lengths close.... There are conflicting veiws on this in regards to turbo engines.... Have you created or witnessed any data to support this?.... I know most of your engine also run the turbo in the engine bay, how as this arrangement effected engine temps?.... The reason I ask this is because I use my cars in classic rally's and track days as well as daily and long distance driving, not to mention the odd trip down the quarter. So the idea of getting the turbo out of the engine bay has been playing on my mind.... Been thinking of fitting it up the 'Woolongong Way' and intercooling which is very similar to the WRX arrangement.... Have you guys ever attempted this arrangement?
FUCH your early!
MemberCraig Paton
Threads: 68
Mood: Absolutely Gratefull..!
posted on September 9th, 2006 at 05:05 PM
Luv your work!
Being Sid James
Threads: 293
posted on September 10th, 2006 at 07:37 AM
nutbags rule
Loves a lolcat
MemberEuro_67
Threads: 75
posted on September 10th, 2006 at 09:26 AM
Keep the updates coming, its looking great.
Membernewoldmanx
A.k.a.: Billy
Threads: 52
Mood: stylin
posted on September 10th, 2006 at 02:20 PM
man if you ever get bored you can "junk up my manx" anytime truly inspirational :thumb now i just need to learn to design measure cut weld etc
its just a car for f*%k sake
Membernewoldmanx
A.k.a.: Billy
Threads: 52
Mood: stylin
posted on September 10th, 2006 at 02:28 PM
The other option is a new 2387cc with ported 044s,Fk 10, 5.7'' h beam rods, pauter 1.4.1 rollers, cb thinline sump, mallory dissy and a comp of 9.8.1.The engine is complete less exhaust and throttle bodies, so I still need to spend money on it.
ok no one likes to spend money and i only wanna help out a fellow dubber so just to save you dollars ill come down and take that nasty donk save money and create space all in one hit and hey you dont even have to thank me im just happy to help:thumb
MemberBoostn
Threads: 28
posted on September 11th, 2006 at 01:04 PM
painted up the tank
Came in to work on Sunday and painted up the tank in silver matal flake. It looks crazy in the sun and against the unpainted crappy looking car! LoL!
VOLLKOMMEN ART
Speed and Style
MemberBoostn
Threads: 28
posted on September 11th, 2006 at 01:11 PM
tank
Another angle
VOLLKOMMEN ART
Speed and Style
Memberhumpty
Threads: 139
posted on September 11th, 2006 at 01:29 PM
Brillian job on the Tank.... It looks so factory!... Except for the paint bit of course! :rolleyes:
FUCH your early!
Super ModeratorBUGBOY
Chief Toy Dude / Head Cruiser
Threads: 403
Mood: A wise German once said
posted on September 12th, 2006 at 08:44 PM
build me a fuel tank
Hey can you build me a fuel tank, the way petrol is going i'd like to still be able to say "filler up thanks mate" :thumb
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Member58bbugger
Mood: busted
posted on September 16th, 2006 at 03:42 AM
any more updates?
I'm hanging to see this thing finished!
MemberBoostn
Threads: 28
posted on September 18th, 2006 at 02:01 PM
1300 junka nearly done
Some pic updates for the junka, I will post more up later.
VOLLKOMMEN ART
Speed and Style
MemberBoostn
Threads: 28
posted on September 18th, 2006 at 02:07 PM
Does anyone know how I can put up some video footage of this thing when I get it running?
VOLLKOMMEN ART
Speed and Style
MemberTurbo54
Mood: Boost'n
posted on September 18th, 2006 at 03:26 PM
place it into somewhere like photobucket.com and link it from there. I could proberly sort it out for you if you cant work it out.
T54
Did you get my PM?
Memberruckus
Threads: 165
posted on September 18th, 2006 at 03:44 PM
upload it to youtube and then link it here
Memberhumpty
Threads: 139
posted on September 18th, 2006 at 07:11 PM
Not a big fan of Youtube, because I like to download moofies and save them....
Just a pet thing of mine..... I'd go photobucket and share the love!
Lovin' the look you have going there Nick.... Very nice.... So you have an idea of when you will be running this puppy?
FUCH your early!
posted on September 18th, 2006 at 07:49 PM
Man, that is awesome. If only every junker in the world was that good.
Memberreub
VWRX is gone...
posted on September 18th, 2006 at 08:03 PM
Please don't so one of those upload things...make it available for us to download onto our computers...please..I'll even host it for you dude....
Looks sweet as...makes me want to do a turbo setup on the 1916 that's going into the 58 later on...hmmm
You in Sydney dude? Heading down there after Chrissie and over new years for 5 days....
Reub
Memberhumpty
Threads: 139
posted on September 18th, 2006 at 08:48 PM
Nicks in Melbourne Reub.... Make a little side trip and get the low down for us.... I've been thinking of going 'old school' turbo with my little donk just because (the one thats in the Ragtop right now).... I did built it to turbo years ago and i have most of the bits to do it too.... Hmmm
Keep it up Nick.... Im diggin this build up....
FUCH your early!
MemberBoostn
Threads: 28
posted on September 19th, 2006 at 01:28 PM
I don't like youtube either because you can not save it.
If I do it on photobucket, can people save it?
I got it driving and have been tuning on the street with the laptop. It dives very nicely with plenty down low and spools up quickly because of the small turbo. EFI draw through feel very different to a carbie.
I will keep you guys posted.
VOLLKOMMEN ART
Speed and Style
MemberVWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on September 19th, 2006 at 02:17 PM
One word " crazy " Love it.
[ Queries: 40 ] [ PHP: 14.1% - SQL: 85.9% ]
