[ Total Views: 9335 | Total Replies: 112 | Thread Id: 91223 ]
 Pages:  1  2  3  4
Author: Subject:  junka getting ready for warwick
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on September 27th, 2011 at 10:12 AM
You can sleep during Warwick and I'll drive it for you lol.
Memberwesti
what the
Threads: 28
Mood: not blue, pink
posted on September 28th, 2011 at 01:26 AM
you couldn't drive a greasy stick up a dog's ahhhahaah.
your so funny.
all done, dyno tommorrow and if all goes well, pack and get ready to leave thursday.
cya all
down sharon.
Memberdangerous
Mood: 591
posted on September 28th, 2011 at 07:08 AM
Good work Brad, it should be a rocket.
Originally posted by westi
That's mad Alan.
posted on September 28th, 2011 at 07:36 AM
your so funny.
cya all
Have you changed the name of your car to dogs arse?? Hahahaha
Member20bkombi
Threads: 26
posted on September 28th, 2011 at 10:14 AM
Love your dedication!
Big effort
Can't wait to see it run with all the new mods, see you sat.
Aaron
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
posted on September 29th, 2011 at 07:59 AM
Did it survive the dyno??
MemberSTOCK
Threads: 12
Mood: OK
posted on September 29th, 2011 at 08:39 AM
Hi guys
car held together on dyno sounds pretty sweet
Our pushrods didn't show up in time so we had to use some shitty
35 thou wall peices of crap
So we couldn't rev it past 6000 it made 210 rwhp at that rpm
So not to bad considering were on our way well do some tuning up
There see you soon
:punk:
STOCK
posted on October 2nd, 2011 at 07:32 PM
Junka just didn't want to play this weekend!! Anything that could remotely go wrong did!! Pushed the car from our pit bay across the road to scrutineering and punctured a brand new rear slick. Raced all over Warwick to find someone to fix it and finally did!! Back to track and ready to go then storm hit and wiped out quick shades. Cut them up with the grinder and threw them in the bin. So Sunday rolled around and we were ready to go. Got the car started after it didn't really want to and it made it to the staging lanes. Started it again and pre stage burnout was ok then up to line and it stopped. Tried to start it and wouldn't even turn over. Westi will pull it apart when the boys return home to see what it is.
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on October 2nd, 2011 at 09:07 PM
must have something to do with all the ash in the case!!!!!
posted on October 3rd, 2011 at 02:26 PM
ahahahahahahahaha or the diesel oil hahahahahaha
posted on October 3rd, 2011 at 02:43 PM
:td:
No wonder the Westi boys slipped away so quietly
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on October 3rd, 2011 at 07:23 PM
centre main locked up or broken crankshaft, brad thinks centre main..
Memberwesti
what the
Threads: 28
posted on October 5th, 2011 at 05:39 PM
First thought's were of a bearing issue. Or even a clearance issue. Due to all the late nights the only thing that is constant is human error. So you Would think.
Doing some check's . On old bearings and lifters from the engine that has been in the car for over 3 years.
They tell me luck was on my side.
When the rollers are passing through there motions they have a spot were they bleed of alot of oil.
Since most of the oil pressure checks are always done at the front o the block and not at the rear . I am going to assume this is what has caused the problem.
You don't lose pressure all together but you don't supply enough were it counts.
Next problem is . If it was that simple ,then is it worth stepping up to bigger gear or staying with what I have.
Any info or suggestions would be appreciated .
down sharon.
Memberwesti
what the
Threads: 28
posted on October 5th, 2011 at 05:45 PM
Ohh. And I hope all that attended the weekend had as much fun as we did.
I can't wait to catch up again soon.
down sharon.
MemberJVLRacing
Threads: 30
posted on October 6th, 2011 at 09:00 PM
read alot of ur stuff westi...always a credit....but do u think the problems u had were caused rushing to a event in preparation?...
Memberwesti
what the
Threads: 28
posted on October 7th, 2011 at 10:58 AM
I wish it was that simple.
Human error I can live with.I admit I don't know everything.but if you can learn something new everyday.that's a bonus.
I think that luck has been on my side. The issue with oil is one that should have presented itself before. When I first changed to roller litters.
I will take it all as a good knock on the chin and a wake up call to leave nothing to chance.
So far it's an easy fix.
Just got to do some more home work and parts chasing.
I have set up an old block and will now do some flow testing with the oil.
I let you guy's know how it goes.
down sharon.
MemberJVLRacing
Threads: 30
posted on October 7th, 2011 at 02:39 PM
deff a learning game:cool:
posted on October 7th, 2011 at 03:24 PM
Originally posted by JVLRacingread alot of ur stuff westi...always a credit....but do u think the problems u had were caused rushing to a event in preparation?...
Hi JVL
Is that a stating the bleeding obvious comment?
Brad runs an extremely popular business and is in demand from some of the top modified car builders in the country.
I drove past his shop many times at ungodly hours leading up to Warwick and saw his daily driver out the front, I'm sure that his family would have preferred that he be at home with them and he would have as well.
If racers didn't push the envelope to get things done we would have had a very boring Warwick meeting.
Drink more Coke westi.
Membercoletrickle
Threads: 34
posted on October 7th, 2011 at 05:15 PM
I know your still smiling brad cause at least you didn't pay someone to screw up your stuff!C.L.A rule number one do it yourself cause you can eff it for free.Between dyno day and last weekend I built my motor had it in and out 3 or more times and an easy 50 hours screwing around with it.Brad I suspect you like me will be doing some "gearbox testing" when all the planners align.
Memberwhathaveidone
Threads: 98
posted on October 7th, 2011 at 05:21 PM
how did you go at the Jamboree Col????
posted on October 7th, 2011 at 06:32 PM
Did you break out the aero dynamic tape and put trust in the Carleton custom upholstered sun visors Col? Lol
Were they scared of you is prolly the question we all need answered.....
Membercoletrickle
Threads: 34
posted on October 7th, 2011 at 11:39 PM
All turned to shit! Spent ages chasing problems that turned out to be an electic fault at the front of the car!bloody white mans magic!still I had 1 qualifying run full street trim on 215 kendas and way off jetting ran 14.4@90. So there is promise.
MemberJVLRacing
Threads: 30
posted on October 8th, 2011 at 10:16 AM
Hi JVL
hi steve,
i do know how to push the envelope its not easy...my sayin never give up...keep pushing...
goodstuff westi:cool:
 Pages:  1  2  3  4
[ Queries: 40 ] [ PHP: 3.7% - SQL: 96.3% ]
