[ Total Views: 176846 | Total Replies: 195 | Thread Id: 37252 ]
 Pages:  1  ..  3  4  5  6  7
Author: Subject: chasing sub 12.5's in a 2250lb Fastback
MemberBRUTUS
A.k.a.: et tu, Brute
Threads: 17
Mood: ACE 30 FOR SALE!
posted on August 23rd, 2006 at 01:58 PM
Anyone go to street drags at Calder still. I think they are still on but not sure if every week or ev 2nd week on Fridays... Closer than Heathcote. Would like to go if/when there are any VW peolple around!
ACE 30 & 40 oils: specifically engineered for your Air Cooled VW
delivered (free del.) throughout Yarra Valley / Ranges, & Gippsland areas. Also ACE 20, 50 & 90.
FOR SALE: ACE 30, 40 etc. Oil formulations & Trade-names.
MemberDoug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet :)
posted on August 23rd, 2006 at 03:48 PM
The more I see, the more I wish I had $10 or $15k to get Volkommen to build me a motor..... this is just Kool.....
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on August 23rd, 2006 at 07:59 PM
Come on Dougie... Get out there and do it yourself.... Im sure ppl like Nick, Hermann and Dave and even some of the old sckool guys will be there to help you get it happening.... And you don't need to spend HUGE bux..... I'll have around 5.5k in my 2276 once its on the road.... Sure its not as cheap as the Subi conversions we have done, but it is loads of fun and Im sure like James, its something I have wanted to do for years....
FUCH your early!
http://www.noh2o.org/
Membervwfastback
Threads: 12
Mood: Ready for Boost.
posted on August 24th, 2006 at 01:05 PM
Brutus,
Tend to avoid Calder unless the VW Club of Vic organise a meet.
I like to be able to inspect the car, the engine bay, under the car, etc when racing. As Calder is 90% in the dark, this makes it very difficult.
Heathcote is quieter, the atmosphere is friendlier and you can see what you are doing. It is further, but from a racer's perspective, it is a better environment.
Regards,
James C.
Membervwfastback
Threads: 12
posted on August 24th, 2006 at 04:48 PM
Found an interesting website to plug in the MPH and the weight of the car in to.
Using the calculator at http://www.speedworldmotorplex.com/calc.htm
It tells me that with a 220lb car going through the traps at 84mph that
I was making : 104 HP at the rear wheels and 123 HP at the flywheel*.
A little less than I had thought, but I will live with that.
It tells me currently with the same weight car going through the traps at 114.18mph
That I am making 261 HP at the rear wheels and 308 HP at the flywheel*.
I am not sure if that maths is right, but it does explain while I smile so much when driving the car. Same size engine but over twice the power.
It sure is going to get interesting over 20lb boost.....
*Note: Assuming a 18% drive train loss.
[ Edited on 24-8-2006 by vwfastback ]
MemberBRUTUS
Threads: 17
posted on August 24th, 2006 at 07:24 PM
Thanks for advice James. VW Club used to go a couple of times a couple of years ago - maybe they'll go again.
Let us know please when you go to Heathcote next. Where can you gert details on Heathcote drags? Was thinking of Calder due to closer distance if need to have car towed back (it is street driven to events). I suppose heathcote isn't ALL that much further. How much is it to run? can you just arrive & run as you used to at Calder street drags?
Brutus I (my stock-looking type 3) got about 17.3s at 79mph (from memory) in in the early-mid 1980's with a 88mm bore x 78mm motor. Have still got the little ticket somewhere.
The weights you keep quoting about 1010kg/2230lbs sounds 'stock' for a fastback. Can't it be lightened a bit?
Best Luck - John
Memberdangerous
Mood: 591
posted on August 25th, 2006 at 07:47 PM
Originally posted by vwfastback
( Dangerous - you are good at the maths here on what this should achieve)
Just broke out my slide rule and 11.5's are acheiveable with that speed, but 60 foot times in the mid 150s are needed.
I hate to spoil your guestimates, but at 114mph it has 285hp at the flywheel,
and that will equate to about 250 to 260 at the wheels on a modern chassis dyno.
BUT!!! you most likely have more power than this,
but will see much higher speeds with a cleaner take off.
Most turbo cars don't acheive their preset boost level in the lower gears
unless full throttle and/or 2-step are used for the launch.
Based on the spec and boost level or your engine,
I would guesstimate(that word again!) around 320 flywheel and low elevens @120 with correct tune for your current boost level.
Of course this assumes an efficient launch procedure and good tyres.
Originally posted by westi
That's mad Alan.
Memberdangerous
Mood: 591
posted on August 25th, 2006 at 07:58 PM
The other thing that will help with your launches is a taller first gear.
If it were mine( and it is not!) I would change to a 3.00 or taller first gear.
That's mad Alan.
Memberhumpty
Threads: 139
posted on August 26th, 2006 at 12:53 AM
Envy.... Thats what I have for you James..... Pure unadulterated ENVY!......
FUCH your early!
MemberBoostn
Threads: 28
posted on September 6th, 2006 at 01:42 AM
Turbo kit back from HPC
Pitty it won't look so nice after a race meet.
But at least it won't go rusty!
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
MemberBoostn
Threads: 28
posted on September 6th, 2006 at 01:49 AM
Intake
The intake side
VOLLKOMMEN ART
Speed and Style
MemberDoug Sweetman
Threads: 58
Mood: sweeeeet :)
posted on September 6th, 2006 at 10:33 AM
engine porn..... lovely.... very nice indeed :)
Memberhumpty
Threads: 139
posted on September 6th, 2006 at 11:03 AM
Now thats sexy stuff......
FUCH your early!
Membermalcolm
Threads: 102
Mood: where did he go!!!!!!
posted on September 6th, 2006 at 10:14 PM
what thickness is the pipe wall and have you looking at the black high temp coating on the exhaust housing to keep up gas velocity.
Member58bbugger
Mood: busted
posted on September 7th, 2006 at 12:29 PM
I don't think that you should use the turbo kit so you don't wreck the look of it.
Nar just race it!
MemberLOWBUG
Threads: 33
Mood: OUT OF CONTROL
posted on October 31st, 2006 at 07:56 PM
NICE, MONEY WELL SPENT, THATS ALOT OF EFFORT TO GO TO. I HOPE IT DOSN'T LEAK.
MemberLOWBUG
Threads: 33
posted on June 12th, 2007 at 12:27 PM
Whats happened to this project?
MemberBoostn
Threads: 28
posted on June 12th, 2007 at 01:17 PM
It was my fault the car didn't make it on the day. Sorry again James!
We are doing a better set of heads for it and have been messed around getting valves but I also have had too much work on to get it finished in time for the drag day.
James has been busy re-wiring the car and has also rebuilt the porsche alternator. It will not be long now but James is also VERY busy with his own work.
VOLLKOMMEN ART
Speed and Style
Memberfullnoise
Threads: 103
Mood: Middle of the road.
posted on June 12th, 2007 at 01:56 PM
WOW
I just came across this post. What great reading!
Thanks for sharing the development and the trials and tribulations.
I bet it won't be long before you get your 12.5 second time slip. Nice looking fasty too.
esratrams
Memberhumpty
Threads: 139
posted on June 12th, 2007 at 10:04 PM
I've missed this thread.... Nice to see it has not been lost.....
FUCH your early!
MemberLOWBUG
Threads: 33
posted on June 13th, 2007 at 09:15 AM
What was the logger worth to buy and what did it come with?
MemberStanley
Threads: 270
posted on June 13th, 2007 at 07:12 PM
It'll be great to see a fast type 3...great read....:starhit:
Memberwesti
what the
Threads: 28
Mood: not blue, pink
posted on June 13th, 2007 at 09:06 PM
great story ,some more pic's would be nice
,what cfm carby are you running.
down sharon.
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on June 14th, 2007 at 11:21 AM
Well your not the only one building a quick Type 3 Fasback.Good to see!! My brother and I are attempting(along with help and info from Dangerous,Pete Page and co) to do a similiar thing but we are going EFI(Autronic) with garrett T3/4 hi flow on 2330cc. We are also looking to run into the low 12's and possibly high 11's once everything is sorted and driver gets his head around the way the car responds and the amount of power.
In aspirated form it ran mid 14's with a loose manifold and broke a clutch tube!! So me thinks it'll be a lil bit quicker than that now...
MemberBoostn
Threads: 28
posted on June 14th, 2007 at 03:12 PM
750 vac
VOLLKOMMEN ART
Speed and Style
Memberwesti
what the
Threads: 28
posted on June 14th, 2007 at 08:40 PM
cheer's.
down sharon.
posted on November 19th, 2008 at 11:12 PM
http://i169.photobucket.com/albums/u217/Silvabullit/TYPE%20THREE%20FASTBACK/TroysType3029.jpg
This is a pic of how Troy has run his fuel system. He is running EFI hence the Bosch motorsport pump as the main pump and a carter keeps the swirl pot full.
Car has so far made 250 odd HP atw on 15psi and is going back for another 5 psi and to finish off the tune. Aiming for 300 atw when completed.
Membervwfastback
Threads: 12
posted on November 20th, 2008 at 12:32 AM
The spare wheel well is allways the first thing to be sacrificed in a type 3.
No one carries a spare there anymore.
Memberoldskl60
Threads: 28
posted on November 20th, 2008 at 03:11 PM
Great to see James!! And after Portland.... Warwick!!??
Keep us posted with the progress.
http://4.bp.blogspot.com/_0YtLR7Gj2Tw/SlsMWR7pLcI/AAAAAAAAAAM/CDqzMEYH70E/S1600-R/oldskl60-footer1a.jpg
MemberGTMac
A.k.a.: Andrew
Threads: 246
Mood: Always asleep
posted on November 20th, 2008 at 06:07 PM
James, low 12's will be a sinch for you. Im currently running 240-250hp atw and can manage a 12.7 with only a 2.6 60'.........................so wait for the big grin on your face after you receive the time slip.
Had to look twice at your wheel well, wondering where the radiator was as Im so used to seeing it now. Im aiming for about the same HP after head work and change of cams but hoping can keep the boost at 15psi.
Looking forward to seeing the end results and yes doesnt it take time for these things to come together. :crazy:
1971 Type 3 Fasty - EJ20T
[ Queries: 40 ] [ PHP: 17.9% - SQL: 82.1% ]
