[ Total Views: 11011 | Total Replies: 179 | Thread Id: 50017 ]
 Pages:  1  ..  3  4  5  6
Author: Subject:  67 panel (Rhino) spot the chisel resto
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on April 30th, 2007 at 11:51 AM
great work Doc - it's come a long way since last time I saw it when i was over...
I just had a closer read of the thread... holy shit man, i can't believe your skills.. much respect.......
[ Edited on 30-4-07 by oval TOFU ]
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on May 13th, 2007 at 06:02 PM
Thanks Chris it has been a lot more work on the upper than I had thought but OH well
Finally finsihed the tailgate/rear door bracket This was completley cut out and used some spare floor created when installed type 3 lid
Just have to weld it up and round we go to drivers side
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Reardoor001.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Reardoor004.jpg
Cheers Doc
reVOLKS at Fyansford Geelong
Super AdministratorBenettonVW
AVD Forum Founder
Threads: 185
posted on May 15th, 2007 at 09:34 PM
Okay Doc, nice idea with the boot lid, but.. why?
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on May 19th, 2007 at 08:22 AM
Jim my whole rear floor above engine was rooted all the way along for about 120mm and some of the middle was gone so to get donor floor to match I saw this a while back and thought great idea
I can leave it open while driving and listen to the webers:beer
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Driversside001.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Driversside004.jpg
Cheers Doc
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on May 19th, 2007 at 08:26 AM
Thanks Chris will be cruising with the gang soon maybe:beer
Cheers Doc
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on May 20th, 2007 at 06:05 PM
Have finished outside panels to allow preping inside for a textured paint to cover up all the rust spots caused by the foam fill holding moister
pics of rust prevention and then some epoxy
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Insiderear001.jpg
Disco
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Insiderear003.jpg
Cheers Doc
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on June 11th, 2007 at 05:46 PM
Put some product on called Raptor
Has a textured and very hard finish
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Inside003.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Inside002.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Inside001.jpg
Cheers Doc
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on June 11th, 2007 at 05:48 PM
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/oilcooler001.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/oilcooler002.jpg
Cheers Doc
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on June 11th, 2007 at 05:51 PM
Have had the steering box rec,od by Robk and in these before and after shots will by putting it up out of harms way of speed bumps
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/steeringbox.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/steeringbox003.jpg
Cheers Doc
Member65notch
Threads: 21
posted on June 13th, 2007 at 10:12 AM
looking good doc:thumb
hope to see it in person sometime
Memberruckus
Threads: 165
posted on June 15th, 2007 at 10:52 PM
Awesome Doc. Got enough clearance on the steering box? Think it might still scrape mate.
Memberdak002
A.k.a.: rossko
Threads: 15
Mood: fine, I said FINE ! !
posted on June 15th, 2007 at 11:14 PM
yes bloke you better get back here soon and check it out
when is that anyway
and you need to help Doc he's bugging me now to help him
There's nothing like the wind on your head, where your hair used to be.....................
http://img443.imageshack.us/img443/7473/roskopg2.jpg
Member76camper
Threads: 89
Mood: happy :-)
posted on June 17th, 2007 at 12:47 PM
love the rotisery!
wats that external oil cooler off? are you running it from the engines main oil pump or an electirc pump?
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on June 19th, 2007 at 08:15 PM
Originally posted by 76camper
love the rotisery!
Cooler is spanker Serko I think and running of oil pump tapped for full flow I think they call it
Still have to mount external filter and stat
Yes Dak002 forget about Rensun and Ruckussun YOUR IT
Cheers Doc
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on June 24th, 2007 at 06:37 PM
This is for you Ruckus and Ren
The main reason Rossko wants you back!!
This Stripper no where near as good looking as my last one (and wrong gender)
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Dickheads002.jpg
Still doing some work around that steering box region
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Dickheads004.jpg
IRS tack up and trial fit
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/IRS003.jpg
Cheers Doc
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on July 15th, 2007 at 05:43 PM
Fitted up shocker mounts and modified old mounts for bump stops
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/IRS004.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/IRS007.jpg
Cheers Doc
AVD Forum Founder
Threads: 185
posted on July 16th, 2007 at 09:18 PM
Things are moving nicely Doc.. IRS.. nice.
MemberPHAT BUG
Dave says Bini's a fool
Threads: 192
Mood: Drippin
posted on July 21st, 2007 at 08:58 AM
Lookin good Doc, Is the textured paint coloured or did you spray it red over the top? And what IRS set up are you using?
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on July 21st, 2007 at 09:22 PM
It comes 2pac and we put colour in when the hardner was added
Very happy with the result and easy to apply
IRS is creative
Cheers Doc
posted on July 21st, 2007 at 09:54 PM
hmmm comin along noice...
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on July 24th, 2007 at 06:15 PM
Hit a lul in work today
Have the rear to do and thats it for panel work :thumb
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Rear001.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Rear003.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Rear004.jpg
Cheers Doc
MemberCAFFINEPUSHERMAN
A.k.a.: chris taranto
bandito di culo
Threads: 169
Mood: got the horn
posted on July 24th, 2007 at 06:40 PM
shit doc lucky this was the dry/good one:thumb
1967 Type 3 square
1956 double door panel
1968 single cab kombi
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on July 25th, 2007 at 06:14 PM
Out with the old and in with the new
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/Rear006.jpg
Daryl is in shot ( trust me)
Cheers Doc
Memberruckus
Threads: 165
posted on July 29th, 2007 at 01:49 AM
That chisel's a cheeky little bastard
bandito di culo
Threads: 169
Mood: got the horn
posted on August 3rd, 2007 at 11:16 AM
doc you coming down sat for the cruise?
1967 Type 3 square
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on August 3rd, 2007 at 10:07 PM
Yes matey I am in:thumb:kiss
Bringing Muz (65notch) in Courtys L to give it a run
Cheers Doc
Member65notch
Threads: 21
posted on August 4th, 2007 at 08:56 PM
thanks again for the ride up this morning doc... look forward to catching up again
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on August 4th, 2007 at 09:02 PM
Nice progress pics Doc - keep em coming!
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on August 18th, 2007 at 04:11 PM
Just got a little bit of welding tomorrow and we are done
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/rearend001.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/rearend002.jpg
http://i21.photobucket.com/albums/b280/beerdoc/Rhino/rearend003.jpg
Cheers Doc
Memberruckus
Threads: 165
posted on August 21st, 2007 at 09:27 PM
wow!
 Pages:  1  ..  3  4  5  6
[ Queries: 40 ] [ PHP: 13.5% - SQL: 86.5% ]
