[ Total Views: 299653 | Total Replies: 1782 | Thread Id: 21201 ]
 Pages:  1  ..  48  49  50  51  52  ..  60
Author: Subject:  1963 ragtop beetle project - gone to a new home
Memberpyr0
flame-on
Threads: 123
posted on November 2nd, 2005 at 06:37 AM
truely awesome. right to the end the attention to detail is mind blowing.
MemberPrettyBlueBug
A.k.a.: P.B.B....
Almost over it...
Threads: 70
Mood: ;)
posted on November 2nd, 2005 at 07:42 AM
Wow.... looks truly amazing.... all 50 pages of this thread! ;)
MemberBiX
Threads: 154
posted on November 2nd, 2005 at 04:20 PM
Awesome, thats all i can say!!
Go hard or go home!!!!
Super AdministratorBenettonVW
AVD Forum Founder
Threads: 185
posted on November 2nd, 2005 at 06:16 PM
Alan, you my friend are a legend.
Looking forward to chatting with you again.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on November 2nd, 2005 at 09:17 PM
Thanks guys....I guess your right oval tofu - our projects are never really "finished".
Well with some great satisfaction and a big grin I finally got the audio system working - no problems, no blown fuses, no dramas surprisingly considering this was my first ever audio installation. Only issue was the sub didn't work initially - found out I forgot to reconnect the sub box...once sorted I was enjoying some 'doof' and 'uunce uunce' sounds in the garage tonight! The Dynaudio 240 GT splits are expensive but well worth it, along with the alpine head unit. From Hilltop Hoods to Jack Johnson, the sound was awesome - still have to play around with the amp filters, time alignment (to regulate the pathlength of the left and right speaker outputs so it reaches the drivers head at exactly the same time), and other settings to fine tune. I must say I'm loving it.
Now just to find time to tune the engine again and get rid of the slight flat spot off idle (jetting changes probably required and accel pump adjustment)....the fix a slight lag in the steering. Then to enjoy driving it.....then to start/finish the resto on the 70 bug (originally thought it was 68)...that will be for sale once done.
:beer
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on November 28th, 2005 at 09:15 PM
Sorry to resurrect this thread from the archives - just a few pics from a car audio show on the weekend (got second in the novice class) and some from the show at coomera on sunday.
I promise to only update this thread with any changes or shows - thanks for you interest to date.
[ Edited on 28-11-2005 by Dasdubber ]
MemberE
Threads: 32
Mood: Bodaciously Rad
posted on November 29th, 2005 at 12:54 AM
Dont apologise Das, we all of love this car to bits.
Reality leaves alot to the Imagination
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 30th, 2006 at 10:11 PM
Back from the depths of the members ride section, this thread is revived.
After many runs and a bit more fine tuning, the engine is still running hot. So an external cooler with fan was required. Pulled the engine today (I knew that removable rear apron would come in handy!) and cleaned everything up, then fixed the cooler into place. Hopefully over the next few days I'll plumb up the AN fittings and s/s braided line.
The beetle certainly stands out as I tend to get lots of comments and looks which is really great. I certainly love driving it, but must admit the most pleasure for me is in the resto itself - once I sort out a carport, I'll get stuck into the 1970 beetle resto so I can sell it. Then the splitty panel project will begin some time after that!
Alan
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on January 30th, 2006 at 10:52 PM
sorry? pffffft. You're crazy. We love this $h!t.
Have you got the fan hooked to a thermo? Is it full flow?
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 31st, 2006 at 10:25 AM
For now the fan will be manually switched so I control when it comes on/off. Being a type IV case, full flow was easy to achieve because I will be using an adaptor which screws onto the filter mount - this has an inlet/outlet.....this will then flow through a filter mounted off the bumper bracket, then into the cooler, then back into the adaptor (and into the case).
Depending on how it goes I may add a thermostat later but won't bother if not necessary (the cost of all these AN fittings add up pretty quickly!).
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on January 31st, 2006 at 10:29 AM
You have a temp gauge in you dash yeh? ..so you'll just flick it on when the temp gets into the 'red' zone huh?
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on January 31st, 2006 at 08:19 PM
Correcto-mundoh. Temp gauge will dictate when the fan will be switched on - obviously there is some lag time so I will be conservative.
Super ModeratorPeter Leonard
Volatile
Threads: 52
Mood: shiny
posted on February 6th, 2006 at 02:49 PM
How hot are we talking here? Is it just when you're idling along in heavy traffic, or more when you're pushing it a tad?
let sleeping dubs lie
Membersurfncam
Threads: 12
Mood: Uninspired
posted on February 6th, 2006 at 03:04 PM
Carport??
Got room for you if you need something quick or until you get your carport, bus gets moved outside for any work. Just 'round the corner too.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 6th, 2006 at 09:59 PM
Cruising around the suburbs it will push 210 (gets there a lot faster when pushing it hard)....when doing a highway trip (say 1 hour) it can get to 240 pretty easily. It is a new autometer sender in the sump plate, new autometer gauge so I am pretty confident it is accurate. I pulled the plugs the other day and no real signs of running lean (or rich). Timing is set at 12 degrees initial and 28 total with the mallory unilite.
I would like 180-190 but would be happy to keep it under 210 max.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 6th, 2006 at 10:01 PM
Thanks heaps Cam - may need to take you up on the offer when I pull the body off the pan on the new project! You'll have to drop around for a beer some time soon. Hope you got some waves on the weekend - was cranking out the front sat and sun mornings! :thumb
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on February 6th, 2006 at 10:07 PM
We talking degrees celcius or kph here? anything over 130 sounds too hot to me..
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 6th, 2006 at 10:14 PM
Degrees Fahrenheit.....I'd like to think I could get it to 210kph but don't think it would quite get there!
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on February 6th, 2006 at 10:16 PM
God forbid: drop it out of a cargo plane!
nooooooooooooooo!
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on February 6th, 2006 at 10:17 PM
did the previous owners get a look at the finished product yet?
[ Edited on 6-2-06 by dumone ]
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 6th, 2006 at 10:24 PM
I dropped around to the old couple's place twice when still living in brissy but they were out both times. Providing I get the oil system done this week, I am going to possibly drive it up again on the weekend and see if I can catch them!
Membersurfncam
Threads: 12
Mood: Uninspired
posted on February 7th, 2006 at 03:06 PM
Yeah, real nice on Sat morn' at 25th, and took half day off today and had a cracker at the Alley, tried out a new 6' fish, now want one so may have to postpone sandblasting the bus. Sheds yours whenever ya want it.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 7th, 2006 at 09:14 PM
Cheers mate - let me know if you want any help with the splitty whenever you get stuck into it.
Back to the bug - did a little more work this evening - managed to finish the plumbing with AN fittings and braided lines from case to filter to cooler back to case. Just waiting on seals then the rest of the engine can go back together hopefully for a test run this weekend.
MemberAlex Holzl
A.k.a.: Big Al
2332cc of pure BALLZ!!
Threads: 85
posted on February 7th, 2006 at 09:34 PM
HMMMMMMM braided line$! they used up my drinking money!
Looks awsome as usual! :thumb
alexxx
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 8th, 2006 at 07:09 AM
Cheers Alex - yep the $ add up with the AN fittings - the braided line is not too exy, but the angle fittings don't come cheap! At least they are reusable and they look the goods (thats how I justify it to myself). ;)
Volatile
Threads: 52
Mood: shiny
posted on February 9th, 2006 at 08:36 PM
The trick is to use good oil, Das. Which I'm sure you are. 240F should be a walk in the park for anything half decent. Do you have a head temp sensor?
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 9th, 2006 at 10:53 PM
No head temp sensor yet - I know that it is certainly recommended...I figured I would see how this oil cooler goes with the oil temps, then will go the head sensor if necessary. Whilst we are on it, what oil do you use Peter? What do people recommend? For the initial break in I used a straight 30 weight Pennzoil (spelling?).
Volatile
Threads: 52
Mood: shiny
posted on February 11th, 2006 at 02:04 PM
Castrol Formula 'ARRRRRRHH'
Big-bore performance, non-synthetic. ~28 bucks for five litres, but I've seen how well it looks after my innards after seriously abusing them. :rolleyes: very happy. From what I understand, the better oils have stabilisers and additives that makes them both last longer, and increase the resistance to shearing under load. Steer clear of Woolworths or No Frills unless you're setting up an engine blow at a fete :cussing
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 13th, 2006 at 09:31 PM
I decided that it was way too much work (and would have taken a long time) to get the wiring for the cooler switch up behind the dash (would have to pull out amp rack etc) - so I hid the wiring and mounted it below the seat.
Finally managed to stop spending money on AN fittings and braided S/S line (hopefully) with the final two lines from case to cooler in shroud.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 13th, 2006 at 09:35 PM
And here is where it sits this afternoon - haven't had a chance to work on much so hopefully in the next couple of days it will be back together and running nicely for the dubs to the pub run on sunday!
[ Queries: 40 ] [ PHP: 8.9% - SQL: 91.1% ]
