| [ Total Views: 299641 | Total Replies: 1782 | Thread Id: 21201 ] |
| Pages: 1 .. 51 52 53 54 55 .. 60 |
koolkarmakombi
enkarmarising
Threads: 158
Mood: do you see the bats?
| posted on July 11th, 2006 at 06:15 PM |
Does it run cooler now Das?
kkk
ps, that looks so sweet, I bet you couldnt stop grinning on the drive!
This disclaimer does not reflect the thoughts or opinions of either myself, my company, my friends, or my dog: don't quote me on that; don't
quote me on anything; this disclaimer is subject to change without notice; text is slightly enlarged to show detail; resemblance to actual persons,
living or dead, is unintentional and coincidental; dry clean only; do not bend, fold, or mutilate; anchovies or jalapenos added to this disclaimer
upon request; your mileage may vary; no substitutions are allowed; for a limited time only while supplies last; offer void where prohibited; this
disclaimer is provided "as is" without any warranties expressed or implied
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on July 11th, 2006 at 06:57 PM |
So far so good - went for about a 45min drive and it didn't hit 200F whereas before it was up to 220F at times and on hot days up to 230F+ which is
when I pulled over to give it a rest. I still think the tuning and timing is not spot on which may be contributing to the higher temps - I know it is
not running lean but may try and get it on a dyno to do some more accurate tuning. Just need to find someone who knows what they are doing with
dellorto jetting and vw engines around here or in brissy (with a dyno).
Bizarre
| posted on July 11th, 2006 at 07:57 PM |
| Quote: | Originally
posted by Dasdubber
Just need to find someone who knows what they are doing with dellorto jetting and vw engines around here or in brissy (with a dyno).
Buy a load of jets and play yourself.
No one is going to get it right - even with an hour on a dyno
Do it yourself and then you will understand and get it right
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on July 11th, 2006 at 08:52 PM |
Cheers Barry - were do you source such jets? I haven't found a supplier yet apart from CB performance but I'm sure someone in Oz would stock them?
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on July 11th, 2006 at 09:24 PM |
Carburettor Services.... although they're in Sydney shipping teeny bits of brass is quite cheap. you can spend a lot of money on jets if you're
experimenting, but certainly no more than you'll spend frikking around with Dynos and EFI ;O)
Never played with Dells, so it would probably be of some help to Das if people had a ballpark figure for jets suited to a car his weight, capacity and
altitude etc etc.
Anyone? BTW 'grats on your efforts, which are, as per, quite spiffy.
let sleeping dubs lie
Bizarre
| posted on July 12th, 2006 at 01:34 PM |
CARBURETTOR SERVICE CO PTY LTD
240 Parramatta Rd Burwood 2134 (02) 9747 4066
You can also start with 2 small sets of jets and a set of reamers.
NOT drills. Reamers will give a smooth edge. Drills give a rough edge.
Start small and "sssllloowwwlllyyy" work your way up - do a change and drive for a while.
Ream out when you are wanting to try up a jet size.
Go back to your other set when you want to compare.
When you are finished - buy that set of jets.
With idles - it is easier.
You carb will tell you when you have "best lean mixture" as the revs pick up when you are 2-ish turns out on the mixture screws.
You can buy just one jet and see what difference that makes to that cylinder. Move that jet to other cylinders to see that difference.
[ Edited on 12-7-2006 by Bizarre ]
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on July 13th, 2006 at 01:50 AM |
Iffin your gunna order from Sydney yer might aswell order from here http://www.racecar.co.uk/dellorto cheap
postage and in your letterbox in a few days,email with paypal or phone and c/card,ask for a quote on idles and mains,they have the lot,luck dude.Mick.
Dont listen to what they say,just watch what they do.Oh yeah ive NEVER finished anything ive started.:o
FPG-779_IN_FLAMES
Threads: 0
| posted on July 16th, 2006 at 05:44 AM |
OMG! Amazing!!! I want it
[ Edited on 15-7-2006 by FPG-779_IN_FLAMES ] |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on July 16th, 2006 at 09:21 PM |
Cheers for the info guys - I have the superformance book re. dells already which has helped thus far - I appreciate the links though!
Alan
kroozzn63
Threads: 317
Mood: mmm coffee
| posted on July 16th, 2006 at 09:31 PM |
that must hammer
show us your gates
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on July 16th, 2006 at 09:42 PM |
Runs out of puff a bit with the stock cam and very mild heads but it is a lot of fun. Future plans for the engine may include new cam, bigger p&c's
(nikasils would be sweet, but $$$$), maybe fuel injection, but only time and money will tell. The less of either I have, the more likely it will stay
as is for a while! :P
koolkarmakombi
enkarmarising
Threads: 158
| posted on July 17th, 2006 at 08:12 AM |
Unless you work it as a business vehicle and it needs
' maintenance and repairs '
or will that be the mobile accoustics split?
(kkk sees retro paintjob on splitty with audiology lab inside)
| Quote: | Originally
posted by Dasdubber
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on July 17th, 2006 at 11:23 PM |
Hehehe....I wish I could claim more of my "vehicle expenses" as a deduction kkk! Even though I am related to my accountant, I can't quite seem to
be able to justify such restorations (just yet)!
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on August 11th, 2006 at 06:29 PM |
Well, I didn't really expect to part with the ragtop after so much blood, sweat and tears (ie. frustration/ satisfaction, hard work and
money!).....but the time has come to hand it over to a new owner.
The rag is staying in Australia, even in Queensland....but I do not wish to divulge who the new owner is NOR how much he paid - if he wishes to let
you know so be it, but I will keep the details confidential and will leave it up to the new owner (so please don't ask).
Firstly a huge thanks to my wife Katie for all her understanding and support....also to all the helpers along the way (Brad, Alan and co.)...finally
thanks to the new owner for his understanding and flexibility with negotiations. I will be keeping my type IV, and the 1916 I had to sell will now go
into the ragtop.
So there you have it....the engine transplant is underway - hopefully will have it done soon. Here is my engine slowly being disassembled to be
removed...
| Error |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on August 11th, 2006 at 06:33 PM |
The type IV has donated its mallory unilite and promaster coil, as well as all braided lines and AN fittings for fuel and oil.
The new owner passed on his serpentine pulley system which is in the process of installation (just have to change the two front alternator stand studs
with bolts)....hopefully more progress over the weekend.
Thanks for following the resto along - the rag will have its final feature in VWMA next issue which I am looking forward to - it will be a great
momento.
Alan
more pics to come (at least until I hand over the keys!)
| Error |
| Error |
| Error |
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on August 11th, 2006 at 06:34 PM |
bugger i didnt expect that das
66deluxe
Threads: 139
| posted on August 11th, 2006 at 07:40 PM |
Now i am all sad Das, but hey we can play with that type 4 give it a bit more oomph. Your documented build up is a credit to you mate, that car has
world wide respect, is it time for the panel build now Das?
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
ruckus
Threads: 165
| posted on August 11th, 2006 at 07:41 PM |
Damn!
Bring on the splitty then eh?!
bails
Threads: 9
| posted on August 11th, 2006 at 08:35 PM |
respect.
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on August 11th, 2006 at 08:50 PM |
wow, that is unbelieveable.. you've sold it! So you still working on that other beetle project?
h
| posted on August 11th, 2006 at 08:56 PM |
what the?
kombibob
Threads: 173
Mood: at by cows
| posted on August 11th, 2006 at 09:34 PM |
wow:o
hope you got $$$$$$$$$$$$$$$$$$$$$$$$$ for it
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on August 11th, 2006 at 10:22 PM |
Is it the 1st of April:jesus...........................I'm glad I have a part of the car to keep forever!
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on August 11th, 2006 at 10:34 PM |
oooooooooorrrkay ....
thanx for taking us along on the journey Alan, i'm glad i got to see it in the flesh at it's prime...
bring on the next Dasdubber build
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on August 11th, 2006 at 11:05 PM |
Yep I'll be finishing the second rebuild to sell (the dark blue 1970 bug) - that will pay for my carport which will give me some space to start the
panel eventually! I may have a couple of other "projects" which are part of the deal for the sale....so stay tuned
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on August 11th, 2006 at 11:07 PM |
| Quote: | Originally
posted by 66deluxe
Damn right Damo.....I think a split duration RAT cam, maybe some 103 nikkies....possibly fuel injection....hmmm....who knows - will wait to see what
happens!
squizy
| posted on August 11th, 2006 at 11:21 PM |
Al you've just blown me away. Hopefully the new owner will bring the car along to the next Valla or the Nats so that I can pay homage. I missed
Valla, and now I really, really regret it. Looking forward all the same to the quality of what you're going to do next.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on August 11th, 2006 at 11:35 PM |
Cheers guys....the new owner is a genuine VW enthusiast so I am sure he will keep the rag running and drive it like it should be! I am just glad it
will be driven and enjoyed which is a big part of the motivation behind restoring it in the first place. All is good
hellbugged
A.k.a.: Daimo Pell
| posted on August 11th, 2006 at 11:59 PM |
555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
| posted on August 12th, 2006 at 01:57 AM |
the wanting is always better than the having! congradulations on the sale I look forward to your future builds. |
