| [ Total Views: 30188 | Total Replies: 442 | Thread Id: 64504 ] |
| Pages: 1 .. 6 7 8 9 10 .. 15 |
2443TT
A.k.a.: Ian
Threads: 69
| posted on February 1st, 2009 at 10:04 AM |
Sounds electrical. I'd be checking earths on the engine to the chassis, battery terminals and power circuits to the computer. Also checking all the
sensor wires for throttle, cam angle sensor, and the air and oil temp sensors.
The only reason the ecu will report 23.5psi (full scale I presume) is that either it actually achieved that boost level, or the voltages that the
ecu's internal ADC's use to calculate that value were off for some reason. All sensors use a common 5V reference voltage from the ecu, and if
something went wrong with the power relating to these sensors it throws the values out for all the sensors.
If it runs fine when idling and driving most of the time but misses and bitches when your on the loud pedal something is moving and a bad connection
is causing the ecu to go into an error state. As a result it drops a cylinder for a moment until things return to normal again.
Also, does the fuel map contain approximated fuel deivery values for up to 23.5psi? If it does the faulty sensoring data could simply be causing it
to massively over fuel for a moment, which drowns that cylinder out when the electrical glitch hapens. This may be visable on the wideband depending
on how long the glitch is occuring for.
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
| posted on February 4th, 2009 at 04:55 PM |
aaron managed to get into see matt at burleigh yesterday and tryto see whats happenin.he seems to thinkthere is smething wrong with the ignition
system. he said if the ignition is giving problems it will always read lean on the o2 sensor. aaron is going to call in there tomorrow with his laptop
which has my program on it and matt will look over it and he may be able to see whats wrong otherwise i will have to take the car to him, wil wait and
see. if the car goes to him i will get the tune increased to somewhere around 20psi, looking for that 300hp at the wheels would be nice but will have
to wait and see.
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
| posted on February 5th, 2009 at 11:10 AM |
Had a simmilar problem in my skyline and found just ONE plug wasn't up to the task of about 6-7000 rpm. (or what ever they rev to, my tacho's
broke.) Replaced with standard plugs, all good? might not aply here just puttin it out there? And it doesn't really explain the boost issue
though.
Cheers Dave!
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
| posted on February 6th, 2009 at 06:50 AM |
Plugs have been checked, cleaned and re gap done. Plus they aren't very old either!! Lucky if car has done 40km with them LOL
STOCK
Threads: 12
Mood: OK
| posted on February 6th, 2009 at 10:56 AM |
HEY TROY I SPOKE TO YOU & YOU PROMISED PICS & UPDATES
WHERE ARE THEY
STOCK
JEN056
Threads: 6
| posted on March 18th, 2009 at 01:42 AM |
Fantastic. Attention to detail and power to boot. Love it.
Moving is a Bitch
STOCK
Threads: 12
Mood: OK
| posted on March 20th, 2009 at 08:26 AM |
HEY TROY / BRENNDEN
PICS & UPDATES WHERE ARE THEY
STOCK
| posted on March 21st, 2009 at 10:43 AM |
Troy is waiting for K Rudd to hand over the 900 big ones so he can take it to another tuner and get it finished off.
Think the only thing he has done on the car in the last 3-4 months was fit the hydraulic handbrake. I'll hit him up for some pics.....
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on March 23rd, 2009 at 07:02 PM |
yeah handbrake is in but i need to replace one of the fitting that continues to leak, as for the dyno i booked it in today for the 14 april to get the
miss fire fixed and up the boost to somewhere around 20psi. i wil post once i get the car back from there...
STOCK
Threads: 12
Mood: OK
| posted on March 24th, 2009 at 02:43 PM |
2O PSI
I LIKE THE SOUND OF THAT
THANKS MATE KEEP US POSTED
STOCK
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on March 24th, 2009 at 06:07 PM |
yeah 20 has a nice ring to it, hopefully it will come out with around 300hp at the wheels, i think i will be happy with that!!
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on March 24th, 2009 at 07:17 PM |
| Quote: | Originally
posted by typethreeking
so where are the pics of your new gearbox bits?
| posted on March 24th, 2009 at 09:43 PM |
It has to go bang first
However long that will be who knows
| posted on March 29th, 2009 at 06:43 PM |
Here's a pic of the hydraulic handbrake fitted up ready to go....
Troy can fill in all the details....
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on March 30th, 2009 at 04:55 PM |
Handbrake finally fixed after a few issues with my joins in the rear brake line leaking. Had to replace one fitting and all good now. I decided to
turn the hand handle over like a normal handbrake cause while it was up the other way it had to much free play thats only adjustable buy disassembling
the handbrake which i really didnt feel like doing. So all working ok now and off to the dyno in a few weeks..
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on April 9th, 2009 at 08:04 PM |
dyno booking has been pushed back for a few weeks due to funds shortage, will be rebooking soon and will post up more then....
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 5th, 2009 at 05:50 PM |
dyno has been rebooked and will be dropping the car off on monday 11/05 and matt will be starting it on tuesday....cant wait!!!
hellbugged
A.k.a.: Daimo Pell
| posted on May 5th, 2009 at 07:25 PM |
| Quote: | Originally
dyno has been rebooked and will be dropping the car off on monday 05/11 and matt will be starting it on tuesday....cant wait!!!
.........damn dude, i'm dying for those broken gear box updates
20bkombi
Threads: 26
| posted on May 5th, 2009 at 09:10 PM |
That will happen unfortunitly, when he's at the track, or when racing my wife Bec, any excuse.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on May 5th, 2009 at 10:00 PM |
Nice one Troy - I'm sure you'll have more luck with Matt.....here's hoping for more boost! (without mishaps of course).
Al
V-Dubber
Threads: 14
Mood: Excited
| posted on May 6th, 2009 at 08:45 AM |
Its good to see another type 3 on here, epsecially with al lthe work done on the engine bay, very similar with what I have in mind, although I am
going completely custom on interior and exterior I like the look of yours and it gives me inspiration and hope that one day mine too will look as
clean and cut as that, keep up the good work
Even the Alphabet loves it!
abcdefghijklmnopqrstu VWxyz
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 6th, 2009 at 05:02 PM |
mate wheres the faith in the trusty vw box, she"ll be right and i promise i will be gentle, well heres hoping, as for v-dubber the only orginal part
of my interior is the dash, everthing else has been changed. post up some pics of your car for us to look at...Aaron, i will take it easy on beck, its
been so long since she driven her car, i dont wont her to get upset being beaten and take it off the road again for more mods. will hopefully have
nothing but good things to say next week when i get the car back.
STOCK
Threads: 12
Mood: OK
| posted on May 7th, 2009 at 12:40 PM |
| Quote: | Originally
I FEEL ANOTHER GRUDGE MATCH COMING FOR WARWICK 09
PAGEY & BRAD, WE DID PINK SHIRTS, WHAT CAN WE DO FOR TROY & BECK
STOCK
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 7th, 2009 at 04:50 PM |
mate im not counting my chickens yet, i will wait till i get to the track without issues first then we will talk
westi
what the
Threads: 28
Mood: not blue, pink
| posted on May 7th, 2009 at 09:36 PM |
what's wrong fat boy troy you going yellow.
down sharon.
matberry
| posted on May 7th, 2009 at 09:55 PM |
| Quote: | Originally
posted by STOCK
WARWICK 09
Pink shirts
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 8th, 2009 at 06:13 PM |
hey mate my whole car could do with a colour change, type 3 could look good in pink. hey westi, not yellow mate im just use to have problems when it
comes to high hp vw engines, you should know all about that!!!
| posted on May 9th, 2009 at 10:50 PM |
I think you car made more passes at Warwick last year Troy than Westi's did if my memory serves me correctly???
Roll on Tuesday I say!! I'll have fingers, toes and eyes crossed that everything will go smoothly without any more set backs. I want to see it at the
track running some nice numbers for fat heavy car.......
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 11th, 2009 at 09:58 PM |
well thanks to all those people putting the mockers on me about breaking my gearbox, cause as it happens it broke tonight on the dyno. Oh joy just
another thing to spend money on. We fixed the breaking down issue, it was leaking past the injectors under boost, so we made some changes and all was
good. Then matt proceeded to adjust the fuel map which made the car run heaps better and fix the idle. Then we started with the power pulls adjusting
as we went. Matt first tried 4th gear but was to tall so selected third gear and at 4100rpm and 14psi we found neutral, there was now only 1st,2nd and
4th gear. There was no noise to hear of over the engine noise, you can still select third gear but theres nothing there. So i will be picking the car
up tomorrow and bring it home for the start of the ppull down again, im getting good at it now. Will post up some picks once the box is apart.
matberry
| posted on May 11th, 2009 at 11:17 PM |
Did you know they call this progress?
