| [ Total Views: 339485 | Total Replies: 268 | Thread Id: 36884 ] |
| Pages: 1 .. 7 8 9 |
kroozzn63
Threads: 317
Mood: mmm coffee
| posted on June 9th, 2007 at 01:36 PM |
hmm Glenn wats happening??
show us your gates
VWCOOL
Threads: 235
Mood: happy to help
| posted on June 9th, 2007 at 03:42 PM |
brakes
The latest news is: after four months of no activity, it's been a busy two weeks! We have installed a set of the 'Stage One' 260mm rear discs to
two cars: Bat69's Pobjoy-powered 1916cc hill climb race car and my own 'new' L-Bug (stocko 1600cc for now!!) to check the performance of the rear
discs with the two respective chassis - Torsion bar and strut - and the two common types of callipers; standard L-Bug with the funny round pads, plus
new replacement 'twin-pin' callipers on BJ front beam, plus these twin-pins on the L-Bug front. Phew!
Bat69's car is BJ/IRS and I'll let him add to this thread in his own words. Suffice to say, the brakes worked beautifully in competition two weeks
ago with NO requirement for any rear bias (there was a bias valve installed, just in case, but it was fully open). Bat is racing again this weekend
(Grafton) and although hillclimb doesn't put much heat into the brakes, it's a great test of feel and bias under heavy-braking conditions.
On my road L-Bug, I was also very happy with the results. Fitted with Bendix Standard pads and teamed with standard L-Bug front brakes of unknown
mileage and pad material, the rears tended to lock just before the fronts on my fast-as-1600cc-can-go-downhill Old Highway runs, meaning the rear
discs were 'doing thier fair share of the work' with, possibly just a touch of bias intervention required. (It's always better to have too much
brake, and be able to bias it back, than too little)
After flogging the poor old thing for several hundred kliks, I installed the twin-pin front callipers that are, these days, fitted as replacement to
many Beetles. On disassembly, I noticed the 'old' L-Bug front callipers, pads and discs were in very poor condition: for instance, the inner front
pad on both discs was covering little more than half of the disc surface and the outer pads had 'cocked' in thier slides. It was obvious the front
brakes weren't working to full potential. Maybe this was altering the front/rear bias and causing the rears to lock a little earlier than ideal...
So, this week, I installed fresh front discs, new twin-pin callipers and performance pads (same as what is often installed on L-Bugs) but have not
driven the car yet (it is raining like hell in Sydney)
All indications from this car, plus Nathan's on-track testing, are that the 260mm rear disc brake package is a perfect, easy, bolt-on fit to any
Beetle with no other modifications required to front brakes, master cylinder or handbrake.
I am happy-as! :thumb
As for the front vented disc brakes: I have added another thousand or so kilometres to my Oval's odometer using fresh slotted discs with new Ferodo
pads. As I mentioned earlier in this thread, I reckon the Ferodos are a very good-value ($40) performance brake pad but I needed to test them and make
absolutely sure....
The only test I am yet to complete is the "try-kill-'em" ten-in-a-row 100-0km/h fade test but with discs and callipers designed for a V8 weighing
double what the VW does, I have little doubt the brakes will pass this "abuse" test with flying colours.
I am, of course, also working on the final $ figure.
At this stage, the 260mm rear kit looks like it will be:
*brand new hubs
*brand new 260x10mm discs
*eight brand new studs and nuts
*bearing housing spacers
*all machining and mods completed, ready to bolt-on
*second-hand callipers
Second-hand? yes. These callipers are no longer available new, but rebuild kits are readily available. To manufacture, I need to source the calliper
brackets to machine and it's simply less hassle - for myself and customers - to supply them 'no-exchange', with the second-hand callipers bolted to
them, than exchange.
The vented fronts:
*brand new hubs
*new bearings and seals
*new billet calliper brackets
*new 287x24mm vented, slotted DBA disc with VW stud pattern
*new studs and nuts
*modified stub axles (exchange stubs)
...Everything ready for the customer to install new or second-hand PBR-manufacture VL-VS V8 Commdoore front callipers and thier choice of pads
So, that's the latest!
[ Edited on 9-6-2007 by VWCOOL ]
Pay your debts, CxxT
VWCOOL
Threads: 235
Mood: happy to help
| posted on June 9th, 2007 at 03:56 PM |
yeah those red ones work great on a Commodore! Thanks for the links; I looked at VT callipers (fronts and rears - I have a spare set in my garage) and
those hubs several years ago as a potential for the VW stub, but even though the fit inside a Commodore 15-inch wheel, they are too large for a VW
rim. Plus, they are heavy...
[ Edited on 10-6-2007 by VWCOOL ]
bugzla
Threads: 240
Mood: always happy
| posted on June 9th, 2007 at 06:04 PM |
:bounce looks fantastic was looking at a swap with mazda discs and calipers from a place in canada but was a bit scared to out lay money to something
thatwont comply with qld rego
VWCOOL
Threads: 235
Mood: happy to help
| posted on June 9th, 2007 at 09:13 PM |
| Quote: | Originally
posted by bugzla
No worries with rego; one of the primary requirements of all these brakes is to be engineer-approvable (is that a word?!)
*The discs and callipers are sourced from Australian-market cars so are 'validated' for the safety, durability and performance aspects of ADRs
*Modified components are machined to exacting standards
*New-components (brackets and studs etc) exceed OE requirements: eg: wheel studs are high tensile
*As mentioned in this thread, I have tested for thousands of kilometres to ensure it all works to a standard that will satisfy any Recognised
Engineering Signatory
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
| posted on June 12th, 2007 at 03:30 PM |
Having completed two (2) full motor sport events (including practice days) using these rear disk brakes and, Im more then happy with their
performance. They are an excellent upgrade from the standard T1 drum I was previously running. I will be doing more testing with the race car / rear
disks on the track through out the year, so Ill keep you posted.
White Knuckle Racing Team
"Drive it like dirt"
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
| posted on November 4th, 2007 at 06:32 PM |
UPDATE RE DISK BRAKE REAR END:
I have now completed a number of motorsport events with this disk brake conversion as well as driven a number of klms on the road in normal every day
driving, both in the wet and dry. The performance of this disk brake conversation has been better then what I expected.
I run T3 front disks/calipers and VWCOOLS rear disk brake conversation. I initally fitted a bias valve in anticipation the rear brakes may have been a
little strong. This was not the case. The rear disk require no bias at all and the front / back ratio is excellent. Having driven some very hard klms
in testing on the track, the rear brakes continue to pull up stop after stop. Even in the wet the front back braking ration remaind th same. Having
driven this combo in traffic, the hand brake performs well as well. I have also pulled a few hand brake turns during competition (although I dont
recommend it) the hand brake still performed well. So after some hard testing I would recommend these rear disk brake combos.
Happy motoring.......
1SlowBeetle
Threads: 10
| posted on January 25th, 2008 at 07:21 PM |
I have been looking for this kind of thing and was wondering if the kits now have a price and are available. Sounds like bat69 is a pretty happy.
I'll be in Sydney soon so I would be keen to check these out as an option.
Cheers...
59 bug w 1916cc
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on January 25th, 2008 at 08:27 PM |
Kits are in production as we speak................front and rear.
kroozzn63
Threads: 317
Mood: mmm coffee
| posted on January 25th, 2008 at 09:12 PM |
hmm ,Glenn all you need some magnesium wheels i know a bloke whos got some cheap ...
show us your gates
GTMac
A.k.a.: Andrew
Threads: 246
Mood: Always asleep
| posted on January 25th, 2008 at 11:16 PM |
Ohh shite, this ugly thread again........lol
Well for those keen eye people you will see my front brake kit is Glenns PBR unit and the rear is his Ford jobby. Have I tested them, well 7000 miles
with a 182kw atw Type 3 Fastback, hell yeah, they have been tested and have never given up.
All the bickering (glad to see with some forum name changes some people have kissed and made up). All I can say is Glenn doesnt do things half hearted
and has done much R&D and forked out much more of his own $$$ than most would in doing so. He could have bought some pretty name brand brake
packages for his Beetle and made many people go oooooooooh ahhhhhhhhh but they would not have been his own.
They have helped me out of some sticky situations. One happy customer
1971 Type 3 Fasty - EJ20T
I love 242HP sleepers.
How many sets of lights does it take a $229k Carrera S to learn?
UPDATE: Cayman S, M3, B4 now added to the list.
JVLRacing
Threads: 30
| posted on January 25th, 2008 at 11:45 PM |
Well i have been one of those critics! i bite my tougue and have to say well done Glenn.If people are happy! that proves they are becoming a proven
item.....
JVL
VWCOOL
Threads: 235
Mood: happy to help
| posted on February 3rd, 2008 at 03:17 PM |
Hey tbanks for the thumbs-up Macca, I reckon you have done more miles than me now with these brakes
I am a little embarassed at the time this project has taken, but I am having 10 sets of these big front brakes made right now (jan 2008) to suit BJ
Beetle.
That production run will allow me to announce final cost, too, which seems on-target for under $1500 with all new parts:
PBR Corvette/Holden callipers, Ferodo 'street performance' pads, DBA 'kangaroo paw' slotted discs, new wheel bearings, CNC-machined hub, stub and
calliper brackets.
Stubs will be exchange and there will be an 'option' of second-hand or rebuilt callipers for the real right-arses!
Craig Torrens
Threads: 347
| posted on February 3rd, 2008 at 04:14 PM |
| Quote: | Originally
posted by VWCOOL
Beetle.
No Probs..........take your time............its only been about 4 years now
Mick058
| posted on February 4th, 2008 at 08:44 AM |
i saw some of these callipers the other day, huge.
Now VWCOOL, i read most of the post, but there is alot there!
I have a set of fuchs 16x6 up front, do these system work for that wheel choice?? Can i run type 3 drums with these kits up front and how much does
the master cyclinder upgrade cost?
I'm looking at engineering my ride soon, so may aswell do breaks now.
Also, your in Syd right? Any sneak peaks?
BiX
Threads: 154
| posted on February 4th, 2008 at 09:19 AM |
Also will the bj front fit on a super?
Go hard or go home!!!!
VWCOOL
Threads: 235
Mood: happy to help
| posted on February 15th, 2008 at 08:59 AM |
| Quote: | Originally
posted by Mick058
Hi, yes I will initially be offering the CNC-machined hubs 'off the shelf' in VW 4x130 and Porsche 5x130 stud patterns so the 16x6-inch Fuchs will
be compatible!
Jap 4&5/100 and Ford/Holden will also be available by special order.
All my vented front brake testing has been with rear discs (two types: 260mm and 280mm as mentioned in this thread) as it was my intention (and
recommendation) that these big front brakes be fitted as a 'stage 2' upgrade AFTER rear discs have been fitted. However, testing with Type 3 drums
may be a good idea just so we all know if it works! The MC upgrade will be less than $200
You are welcome to take a look; my development car is now in Newcastle area. There are pics of the brake hardware earlier in this thread or I can
email.
Depending on other commitments, I hope to have the car/brakes on show (and on the track!) at Bug-In and Nationals at Easter
Bix, I will be offering these brakes to fit 2-bolt struts (L-bug cars with the 'better' neg-scrub front end geometry for handling) and as with the
BJ stubs, they will be offered exchange. 3-bolt cars will be offered later, depending on demand
Mick058
| posted on February 15th, 2008 at 09:32 PM |
Sounds good. Keep me posted. I will probably engineer around May/June but not sure if i'll have the dosh to go front and back. What kind of MC do you
use? Easy to fit?
VWCOOL
Threads: 235
Mood: happy to help
| posted on March 13th, 2008 at 11:32 AM |
For sale: ventilated high performance front disc brake kits for Beetles!
From $1250
This ventilated high performance brake kit features a massive 287x24mm ventilated disc rotor and brake pads with more than double the surface area of
the standard VW equipment. It provides 'Supercar' bite and fade resistance for high-performance VW Beetles and VW-based vehicles without supercar
expense.
ROTORS:
The rotors are top quality from Disc Brakes Australia (DBA). It features a unique ‘Kangaroo Paw’ internal pillar design that increases the
rotors’ heat-shedding ability and reduces disc thickness variation (DTV) when hot compared to conventional straight- or angle-vaned rotors.
CALIPERS:
The calliper is a PBR alloy single-piston unit. It was designed for the GM (USA) Corvette V8 and Holden (Australia) Commodore V8. Unlike many
aftermarket calipers, this design features the rubber seals required for long-term on-road durability and hassle-free street
certification/registration. Installed unmodified (no machining) maintains the integrity of PBR's original design and the validity of its OE
durability testing.
HUBS:
The hubs are CNC-machined from steel (not cast iron) and designed with appropriate back-side radii and face thickness to exceed OE specs. It is NOT a
machined-down VW disc with ribs on the back.
OTHER HARDWARE:
The calliper brackets are a one-piece unit CNC machined from steel. The design is 'ambidextrous' (left and right are the same) making installation
foolproof.
OTHER INTERESTING STUFF
Using components designed for large V8 sedans weighing in excess of 1500kg means these brakes are ‘doing it easy’ in VWs of half the weight, even
in extreme performance situations. Special ‘high performance’ pads are not required as the pad area and heat-shedding ability of these calipers
and rotors over standard Beetle discs means all materials remain way below their operational ceiling. They are not stressed beyond what thier
manufacturers intended.
The hub and calliper brackets are electro-plated to prevent corrosion. The spindles (provided on exchange basis) are inspected for damage and wear
before being CNC machined to accept the calliper bracket and although degreased prior to machining, are provided ‘as supplied’.
These brakes fit inside most 15-inch and larger wheels (eg Porsche Cookies and Fuchs, V-Force, Empis, Performance) but NOT widened VW steel rims.
This kit requires a master cylinder upgrade and an adjustable bias valve in the front brake circuit to prevent premature front-brake lockup. I can
provide both for an extra $200.
This kit was developed for and is intended as a ‘stage 2’ upgrade for Beetles with rear discs already installed and all testing (in excess of
6000km) was performed using VW Beetles with rear discs installed. However, the many different rear discs fitted to Beetles means some cars will
require extra attention to front/rear brake bias on installation.
As well as high-performance air-cooleds, these brakes are the perfect upgrade for Subaru or rotary engined VWs where 'equivalent to donor car’
vented front/four-wheel disc brake system is mandatory for engineering/mod plates and legal street registration.
AVAILABILITY/OPTIONS
The kit is available ‘off the shelf’ in 4x130 (VW) and 5x130 (Porsche) stud patterns for Ball Joint (both early/small tie rod taper size and late
with the large tie rod taper) and L-Bug (2-bolt).
Any stud pattern is possible on the CNC machined hub by special order: for example, Ford/Honda/Nissan GTR (5x114); Holden/Opel/BMW (5x120);
‘Japanese’ 4x100/5x100.
The base kit includes two hubs (studded - standard VW/Porsche thread); two modified spindles (exchange); two caliper brackets; two wheel
bearings/seals kits; DBA 'Kangaroo Paw' slotted (left and right) discs and all non-VW bolts and washers required. It does not include the callipers,
allowing you to choose either new, second hand or rebuilt calipers.
I can provide brand-new PBR calipers and Ferodo ‘street performance’ pads for an extra $300.
Installing the kit is simple R&R. VW rubber brake lines are compatible with the PBR caliper. You must retain your dust caps, bearing washers and
stub axle retaining nuts.
Add $100 for Porsche stud pattern.
‘Custom’ stud pattern $POA as stud prices/availability varies.
Contact via U2U or qik304@hotmail.com
Pick up/delivery Newcastle and Sydney or I can ship anywhere on the planet.
| Error |
reub
VWRX is gone...
| posted on March 13th, 2008 at 11:48 AM |
Congrats
Reub
andrewmurphy
Threads: 22
| posted on November 21st, 2008 at 03:07 PM |
THEY HAVE ARRIVED!!!!!!!!
They look AWESOME. i am dying to get my hands dirty. I will be installing them over christmas. i should be receiving the gear box that Dave Butler has
built for me.
I just have to figure out how to put them together.
Glen, I think that you have to to start a thread to summarise the final product range. I am sure that the moderators would allow for the thread to be
a sticky.
Again a HUGE thanks to both Glenn Torrens and Dave Butler for their patience with me and also for doing the VW community a massive service.
VWCOOL
Threads: 235
Mood: happy to help
| posted on December 12th, 2008 at 05:40 PM |
Good stuff Andrew... I should have shipped over some red caliper paint too!
I have a 'sales blurb' thread here:
http://forums.aussieveedubbers.com/viewtopic.php?tid=68055&page=1#pid646599
| Error |
| Error |
GTMac
A.k.a.: Andrew
Threads: 246
Mood: Always asleep
| posted on December 12th, 2008 at 06:27 PM |
Red calipers..................you RICER!
3 years on and mine going strong, yes I was one of the testing guinea pigs and lived to tell the story
STIDUB
Over it.
Threads: 57
| posted on December 13th, 2008 at 05:20 PM |
any idea whats better between these & 944T brakes? stopping wise, ease of install etc ive been curious for awhile, oh glenn, ill be down there in
early jan, mite give you a call if i have a free day
Volkswagen Drivers Club of Queensland - member
pete wood
| posted on December 13th, 2008 at 07:43 PM |
I can't tell you details, think about it this way. you'd be buying holden pads instead of Porsche pads. which do you think will be cheaper in the
long run.
VWCOOL
Threads: 235
Mood: happy to help
| posted on December 13th, 2008 at 09:38 PM |
Thanks Pete, and you are correct...
STIDUB, I'll be out of town most of Jan... PM me for dates and details and we'll work something out
VWCOOL
Threads: 235
Mood: happy to help
| posted on December 14th, 2008 at 11:52 AM |
| Quote: | Originally
posted by GTMac
Macca you GOTTA paint your callipers. Will look great against the black of your wheels and white of your paint... $18 at SuperCheap!
andrewmurphy
Threads: 22
| posted on December 15th, 2008 at 09:04 AM |
and red goes faster ....... or stops faster ........ oh i'm confused and need some drugs ...........
STIDUB
Over it.
Threads: 57
| posted on August 21st, 2009 at 11:48 PM |
bump for an imformative read, now im going to bed!
| Pages: 1 .. 7 8 9 |
