[ Total Views: 34489 | Total Replies: 295 | Thread Id: 104364 ] |
Pages: 1 .. 7 8 9 10 |
PorscheKombi
Threads: 12
posted on November 18th, 2014 at 11:29 AM |
hey mate, I love your build. I have just read both this and your KCW thread as I cant get enough of it hehe. You are so close now to the start of
your adventure!
I'd love to see some completed interior shots when you get the chance.
Also, any links to other snail conversion threads you know about please let me know... I've caught the bub...or is it snail
NaFe
NUG637
Threads: 24
posted on November 23rd, 2014 at 03:52 PM |
hey mate, yeah getting close now… 39 days i think….
i don't know of any other build threads to be honest… someone posted a link to one on kcw but thats about it?
will get some interior hots later on… i thought we had some up?
Al hooked me up with some 28mm venturi's so last night I found the time to swap them over from the 30mm's .. Along with changing my idle jets from
55 to 60's and my mains from 132's to to 115's...
Had to test drive it sitting on a plank of wood as the seats have been dropped off at the trimmers to have a number done on them... The springs poking
me in the ass got abit over rated... Should have them back on Tuesday... Then it's going up to Matt berry's to be plugged into the afr reader and
see where I'm at with the jetting 8)
Love the sound of the "dell whistle". It pulls like a tractor now 8)
NUG637
Threads: 24
posted on November 26th, 2014 at 08:24 AM |
Went and picked up my seats Last night! 2 day turn around is awesome! Replaced the broken springs, new foam and custom covers 8) performance
upholstery have done a great job..!
whacked the seats in at 9:30 last night and drove it home for the first time with the new set up (carbs and exhaust) and i couldn't wipe the smile
off my face! honestly if your looking for that little bit of pick up on your 1600 go dual dbl barrel carbies, a HUGE difference….
the seats look like they belong…. just need to work my ass groove into them now
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on November 26th, 2014 at 03:34 PM |
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on November 26th, 2014 at 09:56 PM |
NUG637
Threads: 24
posted on November 28th, 2014 at 03:30 PM |
Big old thanks to matt berry for fine tuning a few things on the snail. Went from 170 airs to 180 and tweaked my linkage and mixture scews but an even bigger thanks for the ride in bluey! My god that was fun!
I was probly smiling/giggling like a school girl!
Wasn't as nice of a trip home with the easterly that blew in... Causing me to take up 2 lanes most the way home... But the snail ran on song
matberry
posted on November 28th, 2014 at 06:45 PM |
Glad you enjoyed the trip into town, Blueys little 2 litre tends to
surprise most occupants...
It was a pleasure to help on such a fantastic vehicle today. The Snail drives beautifully and is a total credit to you Myles.
NUG637
Threads: 24
posted on November 28th, 2014 at 10:03 PM |
Thanks mate
vassy66T1
A.k.a.: Marcus Vass
posted on December 1st, 2014 at 07:43 AM |
Excellent
The airs would have opened up the top end a little and helped with the progression.
Wish I was driving around in a car with Dells on it :-/ ... might take Trish's Dormobile for a run.
vduboy
Threads: 41
Mood: Dying to get more buggy building time..
posted on December 3rd, 2014 at 10:25 AM |
Love your build mate. You have a good set of skills there! What
was the reasoning behind the smaller venturi's? Is there a formula used for figuring out the correct size when we use exotic carbs on our old german
machines? I know I have seen a few guidelines for selecting mains and pilots..
It will all be OK in the end, if it's not OK it's not the end!
modnrod
Threads: 50
Mood: Old School Volksies!
posted on December 3rd, 2014 at 12:43 PM |
http://www.aircoolednut.com/erkson/ttt/engine/carbs/dellorto.html
NUG637
Threads: 24
posted on December 3rd, 2014 at 03:16 PM |
I'm still learning alot to but from what i have learnt There are a lot of governing factors... Your engine size, heads, valve size, cam and General
driving needs/goals... for my application I'm running stock valve heads (very mild porting and nice valve grind job) with an engle 100 and the 74mm
crank which all scream torque. I could go bigger vents if I wanted more top end but would loose my low end torque, the next thing that would limit me
tho is my engle 100 cam and then maybe even my heads as I would struggle to make any usable power over 4500rpm deeming my bigger venturi's almost
useless and having a very sluggish feeling engine.. With 28mm vents it brings the torque curve lower down through the rpm range but in turn may steal
abit of potential top end that the 30's may have given me. I don't drive this thing much over 110 where its really comfortable so I'm happy with
where it's at. And being a heavy bus, having the torque curve lower down the rpm range Makes it super drive able. I think matt was pretty impressed
feeling the little 1699cc push my 2tone bus along
vduboy
Threads: 41
posted on December 3rd, 2014 at 08:52 PM |
Awesome link modnrod thanks for that. I basically want the same thing out of my buggy motor so was going a similar direction. Thanks for going through
all that Myles. The webers I plan to put on mine will be a big improvement over the kads I have on it now, and was thinking of going with
traditionally small venturi's for the webers. I'm pretty sure my kads only have 28mm venturis on a 1916. Look forward to seeing more about the
snail!
NUG637
Threads: 24
posted on December 5th, 2014 at 05:17 PM |
matt brought it to my attention that i missed the cylinder head tins…. they often get missed as aftermarket heads don't come with them.
This is the first 1600 based motor I've worked on and never knew they came with tins under the heads…. always made a conscious effort to put the
under clinder tins on but i dont recall ever seeing these on 36ers? anyway spent the afternoon pulling the sled tins off and fitting these tricky
little suckers in…. job done! not the best picture but its proof
matberry
posted on December 6th, 2014 at 02:31 AM |
vassy66T1
A.k.a.: Marcus Vass
posted on December 6th, 2014 at 07:33 AM |
Terrible picture
vduboy
Threads: 41
posted on December 9th, 2014 at 07:24 PM |
Quote: | Originally
posted by NUG637
| Ill second that, I nearly missed the ones I put on the bosses KG motor.. but I think it saved the manufacturer 25 cents a head..
NUG637
Threads: 24
posted on December 23rd, 2014 at 05:57 PM |
Shana has been wanting to take bikes on our trip to make seeing the area abit easier and cheaper. Got some brackets laser cut to make a start thanks
to Foulcan and also a huge thanks to Tom for leaving the bike rack here for me to use
Had to make it very easily/quickly removable if i ever needed to get to the engine bay in a hurry, so decide to make it hinge out of the way.... in
hindsight i probably should of made it hinge to the passenger side so it was off the road if we were pulled over but not to worry
decided on a nice snug fit of 2 pieces of pipe to act as a pivot/hinge. Kept it a little longer for more support when swung out the way...
Ended up using a nice thick bit of right angle to locate it into it closed position and used a hitch pin to lock it in, nice easy removable item but
had to put it in an easily accessible position. Clamped it all down really tight when i welded it and drilled the hole, so its a tight fit with no
room to rattle or clunk *thank god*
Had to modify the bike rack to suit shana's 60's girls bike with the lower step through frame. Abit of Cut and shutting to make them sit reasonably
level when mounted to the rack. With My bike only, i can get it to swing nearly 180 degree's but with shana bike and the basket on it, i can get just
over 90 degrees which is more then enough to get into the engine bay.
Abit of rattle can enamel and this bitch is done!
Addressed a few minor issues while i was working under the rear end to.... pulled off the exhaust and fixed a few small leaks that i had looked past
when i first installed it and also fixed a kinked breather hose... no matter what i tried i could not stop it from kinking... Matt let me in on a
little tip to put an early carb return spring in the hose and it will stop it from kinking and still allow it to bend. The spring is just big enough
to not fall through into the tappet covers to.
feels good tho get all these small jobs out the way 8) the count down to when we leave it on
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on December 23rd, 2014 at 07:08 PM |
Sweet
Noticed the police down here hassling people with bike racks that hinder sight of the number plates... Even those with cardboard "number plates"
added to the rack. Not sure about qld , but you can purchase mini plates from the roads authority here to have hassle free touring with the bikes on
the back. Apparantley they need to be illuminated for night traveling too
http://www.qld.gov.au/transport/registration/numberplate/index.html
NUG637
Threads: 24
posted on December 23rd, 2014 at 07:16 PM |
Yeah I just purchased my "accessory plate" for the bike racks which is just a smaller copy of my actual plate. As far as I'm aware qld don't need
it illuminated for night driving tho? My actual number plate can still be seen... Just..... The accessory plate has the reflecting background to...
Guess I'll just take it as it comes... If we get hassled for no light I will Chuck one on
hellbugged
A.k.a.: Daimo Pell
posted on December 23rd, 2014 at 07:39 PM |
Too easy...... Thought you would be tuned in to it all.
NUG637
Threads: 24
posted on December 23rd, 2014 at 08:19 PM |
thanks Daimo
h
posted on December 24th, 2014 at 12:50 AM |
good work mate!
to my limited knowledge it's just as u said an accessory plate not for permanent use so it should be ok
NUG637
Threads: 24
posted on December 28th, 2014 at 10:46 PM |
Santa dropped off a few luxuries for the snail... One being a 12v tv which we were gonna do without but since it was a gift I'm sure we could put it
to use!
The tv itself is crazy lightweight but the adjustable wall mount bracket was crazy heavy... So a few speed holes and it dropped 2kg off... It all
counts
Mounted it for viewing on the day bed and from our sleeping bed above the cab. Wired it all in myself (electrical is my weakest link) and nothing
caught fire... Winning! Mind the mess... Midway between packing and worksite
Also got a 12v lavazza coffee espresso machine! My life is complete!
nils
Threads: 65
posted on December 29th, 2014 at 06:26 AM |
Beautifully built jalopy there NUG,!! I just cant believe you still have a type 1 motor an the back.
Quit calling rust patina
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on December 29th, 2014 at 06:39 AM |
Nice set-up there, NUG.
May I suggest you put some sort of 'steady' near the top of the bike rack...even occy straps would do the job. Eventually you would lose the lot,
due to 'working' back and forth.
Believe me, I know [ I am the 'MAC' in MAC-RAC ].
NUG637
Threads: 24
posted on December 29th, 2014 at 09:32 AM |
Quote: | Originally
posted by nils
Thanks mate, Why is that? It runs great! The 1699cc has plenty of torque to get this baby moving and up hills... From what I've read type 4 motors
tend to run abit hot and there is no way in hell you would see me going any kind of water cooled... I'm happy as Larry with my choice of engine...
Befor going the dual dellorto's I kinda wished I went the 1904 Route (90.5 p&c) but that just cus the old carbs where choking it down so much...
Yeah I have thought about the bike track fatiguing... The weakest link is the rack itself... All the brackets and everything are 10mm and I have
confidence in them.. But the off the shelf "rack" is my worry. It doesn't seem to move a lot under normal driving conditions but it's something I
plan on keeping and eye on regularly
oldturtle22
Threads: 57
posted on December 29th, 2014 at 06:43 PM |
Looks great mate.
Finky
posted on December 30th, 2014 at 12:33 PM |
what a masterpiece!
kombivw
A.k.a.: David
posted on February 21st, 2015 at 11:46 AM |
Whats next event yr going too ?
Like to see this one
