[ Total Views: 125993 | Total Replies: 263 | Thread Id: 27343 ] |
Pages: 1 .. 4 5 6 7 8 9 |
BenettonVW
AVD Forum Founder
Threads: 185
posted on May 4th, 2005 at 10:16 PM |
Good on ya Kim, looks the ducks nuts bud! Well done. Not long now!!
Golde60
Threads: 73
posted on May 5th, 2005 at 05:37 PM |
looking forward to seeing the completed exhaust soon.
last time i saw it there was still the resonator to go on. so i wanna see and hear it now that its complete.
next issue is gonna be engineer.
damn.
dunno if i wanna go through the time and expense now or later. i have one possible lead.... through the vwcv
[Edited on 8-5-2005 by Golde60]
SPRINTSTAR
Threads: 187
posted on May 5th, 2005 at 09:01 PM |
Just like the corn flakes the car is, JUST RIGHT!
Beautiful Kim!
BLUE_62
Threads: 58
Mood: Dak Dak Dak
posted on May 7th, 2005 at 04:25 AM |
OK! I'm impressed..... :thumb
1958 Beetle, 1966 VW Beetle, 1996 Holden Statesman!
Its an obsesion for engines and fuel....
Golde60
Threads: 73
posted on May 15th, 2005 at 10:03 PM |
cheers guys....
is still progressing. here are the latest pics of the car now that the exhaust is in. i am very happy with the clearance that i have got with the
exhaust.
i was after something that fitted under the car, was quiet, didnt have a muffler or any signs indicating big exhaust from the rear (definately NOT a
cal look muffler hanging out the back), and no pipes showing.
has been acheived. only minor downside is the poor access to the valve covers, but the exhaust has been built with enough flanges to make it easily
removalble.
anyway, here it is.
Golde60
Threads: 73
posted on May 15th, 2005 at 10:11 PM |
as you can see it is a 4 into 1 system, with sharpbuilt headers leading into custom built everything else.
muffler on the left side, piped forward, and up over the gearbox, then out the right, back to the rear, through a resonator and down and out.
will be quiet with a nice note, which is just what i was after. definatley didnt want loud
anyway, here are some more pics that i took when all the wheels were off so that the engineer could give the car the once over.
still a few gremlins and compliance issues to sort out for engineering (damn i hope that i can get the CB dropped spindles backed up by some sort of
confirmation of strength - thats my biggest potention problem for the mo)
anyway, heres some more piccies
going forward into muffler and over gearbox
back out the other side and through the resonator
i will have to upgrade the rear (T1) brakes to the larger T3 brakes following my meeting with the engineer, and the rigorous brake testing that the
car will need to pass.
better to do it now rather than have to do the test twice!
Golde60
Threads: 73
posted on May 15th, 2005 at 10:12 PM |
you can see the clearance that has been acheived. the system actually sits higher up than the engine!
Golde60
Threads: 73
posted on May 15th, 2005 at 10:14 PM |
took some more pics of the front while it was up on the hoist.
narrowed beam
wide five disc kit
Golde60
Threads: 73
posted on May 15th, 2005 at 10:15 PM |
and just wanted to throw in some pics of the engine cos i like it so much....
traumin
Threads: 21
posted on May 16th, 2005 at 10:23 AM |
Very impressive |
pete wood
posted on May 16th, 2005 at 03:48 PM |
What is that fancy ignition module you're using? love the dizzy cap too.
in fact the whole car looks tops
Golde60
Threads: 73
posted on May 16th, 2005 at 04:42 PM |
ignition is a compufire dis-ex. basically a 009 without points. wired to the sparkplugs thru a hi-po twin coil pack (one per two cylinders rather than
one per four) that you can see mounted on the fire wall.
looks trick because it hides all the wires at the same time.
ruckus
Threads: 165
posted on May 16th, 2005 at 06:18 PM |
engine looks sweet Kim. Are those filter shorter than usual? |
Golde60
Threads: 73
posted on May 16th, 2005 at 06:22 PM |
i dont know what usual is mate, so .... ?
maybe someone else can pick the difference!
if they were any taller then there would be some clearance issues with the engine lid
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 295
posted on May 16th, 2005 at 06:35 PM |
they look good mate but i think there will be a little intake noise at high speed cause this is a similar setup that i had on mine but im changing to
an airbox setup
Golde60
Threads: 73
posted on May 16th, 2005 at 06:54 PM |
how does the airbox setup work barls, im not sure i understand what you mean
got any piccies?
pete wood
posted on May 16th, 2005 at 07:48 PM |
Barls, Make three and sell Golde and Daz one each
kombi_kid
Good Kid too many projects
Threads: 341
posted on May 16th, 2005 at 09:28 PM |
man that mnust suk that u already have to make changes for engineering!! its all a load of shizza!!!
beautiful car though!!
lovely
rhys
Bizarre
Threads: 730
posted on May 16th, 2005 at 09:51 PM |
Quote: | Originally
posted by Golde60
got any piccies?
Basically Webers / Dels is almost a straight line of down the barrel of the carb into the cylinder. The air box is just taking the inlet away so as
there is a few bends of PVC or something to absorb some of the noise.
Sort of like standing round the corner from the stereo rather then in a direct line to the speaker
BTW
Nice work!
ummm..... by any chance, are you running hydraulic lifters???
Man - is that gunna be a bitch doing the valves!
Golde60
Threads: 73
posted on May 16th, 2005 at 09:59 PM |
nope, no hydraulic lifters, just gotta unbolt the flanges from the exhaust to get to the valves.
rhys: the rules are the load of shite. the engineer that i have been talking to has been pretty good. hes just explaining/following the crap that some
pen pusher has written down. not his fault
the best one was the fact that i dont need to run external mirrors!
after upgrading the brakes, brake lines, resevoirs, rear brakes, extra seat belts, plates etc...
... rule book says that i dont need external mirrors. minimal to comply is internal rear mirror.
cant complain though, cost most of the stuff i have done for the right reasons, so i certainly wont be driving without mirrors.
was a good exercise to go through all the details with the engineer and after doing it i think that the car is definately gonna be safer.
apart from that it will be engineered, insurable and better from a resale value too!
damn rules.....
... dont get me started.:puke
barls
Threads: 295
posted on May 17th, 2005 at 04:52 PM |
Quote: | Originally
posted by pete wood
that i might do mate im making one for my bug and ill let you know how
much quieter it is.
Golde60
Threads: 73
posted on May 21st, 2005 at 09:57 AM |
yeah - that 'd be pretty cool.
i have seen the posts on your various airbox setups, and they give the engine bay a whole different look.
i will wait and see how noisy my setup is, as this will be my first engine with twin carbs, and i think i m gonna enjoy a little extra noise for a
while!!
in the mean time, my car is not getting any closer to looking like this:
and probably wont for another couple of weeks
oh, well.
only remaining issues are engineers and dyno time to get the carbs jetted right. then its off to vicroads.
and before anyone asks, i m sick of guessing how much longer, cos it always goes slower.
not long now!
barls
Threads: 295
posted on May 21st, 2005 at 10:16 AM |
fair enough cause both you and das are running webbers and im running the stock solexs
Chewy
Threads: 75
Mood: Buggered
posted on May 26th, 2005 at 12:55 PM |
Hey dude, just a little something..
On the underneath pic of the bug on the hoist it looks like your axle boots are positioned so the seam is facing upwards, if you can imagine with the
suspension going through its travel that seam is getting bent lengthways..
Its best to put them so the seam is to the side, makes them last longer..
Farkin nice buildup but, I love it.,
Golde60
Threads: 73
posted on May 26th, 2005 at 08:18 PM |
thanks for that. i will make the change
..... anyone help me get my spindles strength verified......
..... please |
jenz58
Postal Menace
Threads: 230
Mood: Cruisy
posted on May 27th, 2005 at 12:29 AM |
.......Kim it's looking so good...OMG the work you're putting into is brilliant...
Yes I can relate to how you feel about the question of finish time...so have deleted mine... I'd scolled up and saw someone else had already got in
before me
It looks pretty close now though
Golde60
Threads: 73
posted on May 28th, 2005 at 10:18 AM |
yeah, time is a second priority to quality.
it will be ready when its ready.
Golde60
Threads: 73
posted on June 5th, 2005 at 01:43 PM |
it has been a bit slow for the last couple of weeks, but i managed to get out and spend some time working on it yesterday.
didnt get much done, but i took some shots anyway, cos i cant help myself
here are the bits that i got back from the chromers a few weeks ago.
got all 4 overriders done.
other bits are the glovebox pull and the chrome strip for the glovebox, yet to go on
Golde60
Threads: 73
posted on June 5th, 2005 at 01:44 PM |
this is where they will end up - on my timber clad glovebox (which doesnt close yet!!)
Golde60
Threads: 73
posted on June 5th, 2005 at 01:46 PM |
pictures of the wiring (work in progress) under the bonnet
2nd pic with some speaker wire through to the body for the tweeters
