[ Total Views: 171120 | Total Replies: 341 | Thread Id: 68032 ]
 Pages:  1  ..  4  5  6  7  8  ..  12
Author: Subject:  NOW AVAILABLE: Kafer Cup, K Bar Style Bars
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on July 29th, 2009 at 05:18 PM
I knew you were good for it.....and I was sending out 6 kits so yours went as well !! :cool:
posted on July 29th, 2009 at 05:38 PM
and here i was thinking i was special with the only black one
thought i should also add im a lazy shit and installed mine without dropping the tranny
with some trick welding its easy as
Memberreub
VWRX is gone...
posted on July 29th, 2009 at 05:39 PM
The sprit of my kit is here in Darwin.... just waiting for the actual parts to turn up :spin:
Reub
MemberCraig Torrens
Threads: 347
posted on July 29th, 2009 at 08:47 PM
you were special.........but you didn't give me the love i wanted so I "put out" for others! :lol:
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on July 29th, 2009 at 08:56 PM
he hee........i wanted to paint mine flat black until i spotted yours Joel............spose the stainless allen head bolt up grade is now factory issue too ::fakesniff:
well, i finally got mine up and in........glad i stuck to the factory colour cause it blends well with my rust background :no:........if i can fit one of these with all the bonus spaghetti i have rigged up, they should fit anyones beetle.
they are certainly close tollerence engineered :!:......mine was welded in with the box and engine out, which normally would not cause any dramas.......
i couldn't get a couple of the bars to line up with the brackets until i realised that i had not loosened the berg hop bar back off the rear of the motor (this is used to pre load the motor and frame horns up and actually lifts the exhaust collector 15mm towards the body when tightened up)...
......SOOOOO after i did this, the Craig T bars went home and all was tightened up..........the berg bar didn't lift the exhaust collector near as far with the kafer bars now installed, indicating indeed they were doing their job stiffening the frame horns muchly gooderah....nice work Craig :!:
also backing off the curb and guttering out of my driveway, there is NOTICABLY LESS BODY CREAKING, infact there is barely a noise at all which is a far cry from the flexing evident only a few hours before installation...........i figure this increased body stiffness is coming from the two cast shockie towers now being tied together, and the body mounts from them having much less movement.......
happy days
http://i31.photobucket.com/albums/c365/dumone/P1040462Small.jpg
http://i31.photobucket.com/albums/c365/dumone/P1040447Small.jpg
http://i31.photobucket.com/albums/c365/dumone/P1040456Small.jpg
http://i31.photobucket.com/albums/c365/dumone/P1040445Small.jpg
MemberCraig Torrens
Threads: 347
posted on July 29th, 2009 at 09:28 PM
another unhappy customer !! :lol:
Hey Daimo, funny how the "factory colour" matches my ragtop :lol: !
Membertrickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on August 4th, 2009 at 07:31 PM
Well my mate just welded it in for me. Stiffened it right up! As well as the car :lol:
Thanks Craig!
http://i260.photobucket.com/albums/ii19/trickysimon/DSCF2102.jpg
http://i260.photobucket.com/albums/ii19/trickysimon/DSCF2104.jpg
Member56t4
Threads: 3
posted on August 15th, 2009 at 02:38 PM
kafer bar for oval pan
Hi Craig,can I order a 3 point kit to suit a 56 oval pan? The shocker mounts are on an angle.Of course I need it ASAP as the car is at the workshop on the hoist and the new trans is going in this week.Cheers Nick
MemberCraig Torrens
Threads: 347
posted on August 17th, 2009 at 10:27 PM
Sorry Nick, there's a three week wait for orders at the moment.............let me know if you still want one and i will send when ready. Cheers
Craig T
Glad to hear you got yours ok Humpty ;)
Memberhellbugged
A.k.a.: Daimo Pell
posted on August 18th, 2009 at 06:30 AM
Please Mr Craig, I need a new set of the tabs that weld to the frame horns as my kafer bars are moving homes, gearbox is out and i'm ready to weld in the tabs........pretty please:smilegrin:
MemberCraig Torrens
Threads: 347
posted on August 18th, 2009 at 08:59 AM
Tabs will leave tomorrow Daimo...................send a dvd to me, please pretty please!!
MemberCraig Torrens
Threads: 347
posted on September 10th, 2009 at 01:34 PM
New batch of K bars are less than a week away !!! Put your order in now if you want one.........before I sell out again!
Memberspdterence
Threads: 24
posted on September 12th, 2009 at 10:24 PM
Originally posted by Brad
Well I found a few spare minutes today to fit up one of Craig's 5 bar setups. This is in a 75 L Bug.
Went in without a hassle, everything fitted fine and the only thing I did differently was welded the rear tab to the cross member rather than the frame horn.
As luck would have it the supplied tabs fitted this application perfectly.
http://www.manxgallery.org/gallery/albums/BradBeetle/IMG_6327.sized.jpg
http://www.manxgallery.org/gallery/albums/BradBeetle/IMG_6328.sized.jpg
Out of 10 I would have to give it 10 at this stage. It was shipped fast, packed well and supplied as specified. Fitted perfectly and the quality is very good. Even with it just tacked in place it stiffens up the rear end.
:tu::tu::tu::tu:
Craig - looking at this set up - it appears that the rear mount is using the bolt into the fork? Is this correct? and I guess that means you only need to weld the front main member mounts then? Terry
Smile - It confuses people:D
Today:
Aussie 69 IRS pan Brazilian curves
1916cc of Stans magic
Fat boy stainless extractors
Craig & Tims 3 bar stiffy
Tomorrow
Cooookies
Better brakes
MemberAUSSIE_MICK
Theme: UltimaBB Pro Red
posted on September 13th, 2009 at 07:41 AM
I would hate to ruin the paint on my pan, how about you make up a bolt in kit Craig?
PLEASE!!!!!!!!!!!!!
MemberCraig Torrens
Threads: 347
posted on September 19th, 2009 at 08:14 PM
It is bolt in.............you just have to weld the tabs :lol:
OK guys and gals.....you wanted a quality k bar kit, well they're ready to be packed and posted!
I only have 10 kits so be quick :spin:
Mr Becker yours is ready to go ! ;)
Member66deluxe
Threads: 139
posted on September 19th, 2009 at 09:59 PM
Craig, your kit kicks arse i got one but my friend needs one for his oval, but the shock tower mounts are different do you have one to fit this application as he has installed a type 4 engine i built for him and it needs the bar kit for sure.
Damo.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
MemberCraig Torrens
Threads: 347
posted on September 19th, 2009 at 10:12 PM
The Kit fits Ovals with no probs :cool:
Member66deluxe
Threads: 139
posted on September 20th, 2009 at 08:16 AM
OK cool i will let him know.
MemberAUSSIE_MICK
posted on September 20th, 2009 at 11:44 AM
Thanks Craig
I know they are weld in but if you could fab them so they are bolt in you would sell squillions and retire early?
How about it?
MemberByronBug
Threads: 150
Mood: Bent
posted on September 24th, 2009 at 05:32 PM
Damo.
Hi Craig...yes I would like to order one for our 56...do you have any left?
59 Microbus Kombi (MERCY)
64 Microbus Kombi (CHANNON)
MemberCraig Torrens
Threads: 347
posted on September 24th, 2009 at 08:43 PM
yep new batch has just been plated...........just pm me your delivery details and I will send you my bank details.
Regards
Craig T
Memberjl_1303
Threads: 1
posted on October 8th, 2009 at 01:16 AM
Just sent you an email for a 3 bar kit. Please reply to my email address : jeremy_hk@hotmail.com
Thanks, Jeremy
posted on October 8th, 2009 at 07:29 AM
I didn't buy one from Craig, but I have one on my sons 1303, these things really work, check out his burnouts at Warwick http://www.youtube.com/watch?v=Jl2JzcSzJ0w
Memberrsaul
Threads: 0
posted on November 7th, 2009 at 11:56 AM
Hi Craig
After a 5 bar setup
Give me a buzz 0414250996
Chris
MemberCamo
A.k.a.: Kev
Threads: 209
posted on November 27th, 2009 at 08:22 PM
Craig,
Have replied to your PM, I will grab a 5 piece thanks.
Kev
Memberrobertocarlos
Threads: 10
posted on December 15th, 2009 at 03:58 PM
Hey Craig,
After a 5 bar setup give me a call on 0424343557
Rob
Member71-BEETLE-SEDAN
AKA Josh
Threads: 108
posted on December 15th, 2009 at 04:20 PM
Hey craig, i was wondering how much suppport people are getting from the three bar set up. I wanna know if itll give my stock 1.6 a tight rear end. Or should i go to the five bar and have it strengthened right up.
Memberstreeter
Threads: 2
posted on January 31st, 2010 at 10:26 AM
Hi Craig
New to this forum
have to do a few posts before i send a PM
Interested in your 5 bar setup for my Manx
can you give me pricing
thanks
streeter
Membertazkralc
Threads: 6
posted on January 31st, 2010 at 05:41 PM
Do these come in red.
Memberstreeter
Threads: 2
posted on February 3rd, 2010 at 08:08 AM
Just wanting to add up my posts so i can PM Craig
